SDS100-PRW2-M37-SN00-1 数据手册
8
7
4
5
6
1
2
3
REVISIONS
DIMENSIONS
REV. ECO. NO
C
2637
D
2883
DESCRIPTION
DATE
BY
ADD WIRE SIZE NOTE 3
UPDATE TAIL LENGTH MALE 3.20 mm,
TOLERANCE 0.38 mm(WAS 0.25mm)
07/19/2012
LH
01/22/2014
LH
F
F
67.0 2.64
A 0.25[.010]
61.0 2.40
B 0.25[.010]
C
52.81 [2.079]
2.77 0.109
1
1
1
14
14
18
18
34
4.10 0.161
4.10 0.161
9.20 0.362 REF.
C
±3°
6.10 0.240
5.80 0.228
6.10 0.240
2X Ø3.05 [
6.10 0.240
10°
4.10 0.161
D
D
9.20 0.362 REF.
C
3.10 ±0.38 0.122 ±0.015
3.20 ±0.38 0.126 ±0.015
13.42 0.528
55.10 2.169
09,15,25,37 POSITIONS
50 POSITIONS
( PN EXAMPLE: SDS100-PRW2-M09-SN00-1)
A
0.120] CLEARANCE HOLE
10.72 0.422
F
B
34
2X Ø3.05 [Ø0.120] CLEARANCE HOLE
±3°
9.60 0.378 REF.
10°
15.35 0.604
2.84 0.112
5.68 0.224
44.32 1.745
4.10 0.161
1
11.28 0.444
2.77 0.109
E
52.20 [2.055]
12.55 0.494
7.90 0.311
E
2.84 0.112
8.36 0.329
D
10.90 0.429
E
(PN EXAMPLE: SDS100-PRW2-M50-SN00-1)
B
NOTES:
1. MATERIAL
INSULATOR : GLASS-FILLED THERMOPLASTIC PBT, UL94V-0
CONTACT: BRASS
SHELL : SPCC, .000100" TIN OVER .000050" MIN. COPPER (STANDARD, SEE PAGE 3)
CLINCH NUT : BRASS, NICKEL PLATED
SCREWLOCK : STEEL, NICKEL PLATED
OPERATING TEMPERATURE : -55 C TO +105 C
2. ELECTRICAL
CONTACT RESISTANCE : 20 MILLIOHMS MAX AT 1 AMP DC
INSULATION RESISTANCE : 1000 MAGOHMS AT 500 VDC
DIELECTRIC WITHSTANDING VOLTAGE : 1000 VAC/RMS 60Hz FOR 1 MINUTE
CURRENT RATING : 3 AMPS
VOLTAGE RATING : 250 VAC/RMS 60Hz
Pb
3. ACCEPTS WIRE SIZE: 22 AWG MAX
8
7
RoHS COMPLIANT
6
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN MM [INCHES]
TOLERANCES:
ANGULAR:
3
DECIMALS
X.= 0.38 [.015]
.X= 0.25 [.010]
.XX= 0.13 [.005]
DRAWN
DATE
NAME
07/01/2011 LH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
2
SDS100-PR_ _-_ _ _-_N_ _-_
CAGE CODE
54453
SCALE: 1:15
3
A
100 SERIES D-SUB SOLDER CUP TYPE
DWG. NO.
11745
SHEET 1 OF 3
1
REV
D
FILE NAME: 11745, SDS100-PR
8
7
4
5
6
1
2
3
F
F
h: POSITION OF CLINCH NUT
E
h: 0
E
Ø3.05[
D
D
h: 1
5.9 0.23
CONSULT SALES OR
FACTORY FOR OTHER
MOUNTING STYLE OPTIONS
C
5.9 0.23
h: 2
B
B
Pb
A
RoHS COMPLIANT
8
C
7
6
5
4
TOLERANCES:
ANGULAR:
3
DECIMALS
X.= 0.38 [.015]
.X= 0.25 [.010]
.XX= 0.13 [.005]
DRAWN
DATE
NAME
07/01/2011 LH
TITLE
PART NUMBER
SIZE
C
2
CAGE CODE
54453
SCALE: 1:8
3
A
DWG. NO.
11745
SHEET 2 OF 3
1
REV
D
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
Pb
A
RoHS COMPLIANT
8
7
6
5
4
TOLERANCES:
ANGULAR:
3
DECIMALS
X.= 0.38 [.015]
.X= 0.25 [.010]
.XX= 0.13 [.005]
DRAWN
DATE
NAME
07/01/2011 LH
TITLE
PART NUMBER
SIZE
C
2
CAGE CODE
54453
SCALE: 1:8
3
A
DWG. NO.
11745
SHEET 3 OF 3
1
REV
D
SDS100-PRW2-M37-SN00-1 价格&库存
很抱歉,暂时无法提供与“SDS100-PRW2-M37-SN00-1”相匹配的价格&库存,您可以联系我们找货
