17E18252
17E18252
    ARDUINO
    15SIZEDSUBBACKSHELL
17E18252 数据手册
45º Plated Plastic Backshell ACCESSORIES SPECIFICATIONS: Housing Material: Plating: Grommet Material: Mounting Hardware: ABS Polymer Nickel over copper PVC (UL 94 VO) Steel, clear zinc finish ASSEMBLY INSTRUCTIONS 1. Select the tightest insert that will fit over the cable and thread the cable through it, placing the end with the smaller O.D. (the end without the washer) towards the connector. 2. Cut the jacket, fold the shielding back over the outside of the insert Amphenol’s plated plastic backshell accommodates most standard and high-density D-Subminiature connectors and is appropriate for cable assemblies requiring compliance to FCC 20780. This version is highly durable and provides EMI/RFI protection. The rubber grommet compression insert forces the cable’s shielding against the inside of the cable exit area, assuring shielding. The 45° cable exit helps save space behind equipment. DIMENSIONS AND and cut it just short of the washer. 3. Install jackscrews and connector. 4. Place the washer in the outermost depression in the exit area of the hood and screw the cover closed. ORDERING INFORMATION Shell Size Standard # of Contacts Hi-Density # of Contacts Part # E 9 15 17E-1824-2 A 15 26 17E-1825-2 B 25 44 17E-1826-2 C 37 62 17E-1827-2 A B 1.217 (30.91) 1.545 (39.24) 2.090 (53.09) 2.734 (69.44) 1.430 (36.32) 1.568 (39.83) 1.735 (44.07) 1.976 (50.19) Dimensions C D 0.640 (16.26) 0.640 (16.26) 0.710 (18.03) 0.906 (23.01) TELEPHONE: (416) 754-5656 FAX: (416) 754-8668 E-MAIL: 0.640 (16.26) 0.640 (16.26) 0.640 (16.26) 0.640 (16.26) E F 0.400 (10.16) 0.400 (10.16) 0.522 (13.26) 0.726 (18.44) 0.984 (24.99) 1.312 (33.32) 1.857 (47.17) 2.500 (63.5) Cable Diameter Range Minimum Maximum 0.210 (5.33) 0.210 (5.33) 0.230 (5.84) 0.350 (8.89) SALES@AMPHENOLCANADA.COM 0.320 (8.13) 0.320 (8.13) 0.450 (11.43) 0.650 (16.51) 59
17E18252 价格&库存
很抱歉,暂时无法提供与“17E18252”相匹配的价格&库存,您可以联系我们找货
