4272-50P
4272-50P
    SCS
    COVERD-SUB50-MCOND(1000PCS)
4272-50P 数据手册
3 4270 Series Electrically Conductive Connector Covers BT 0806-1101 Nov 2001 Technical Information Conductive Composite 3M™ 4270 Series Connector Covers feature a new unique Conductive Composite material. The material is made intrinsically conductive by uniformly distributing a conductive matrix of fibers during compounding. The covers are permanently volume conductive and free of carbon black particulate. The 4270 Series Covers do not leave black marks and are more suited to clean situations. Noncorrosive 4270 Series Connector Covers are noncorrosive and produce no visible corrosion when tested to Federal Test Method 101C using Kovar test plates. Military Application Conformability 4270 Series Circular Connectors Covers were designed to meet the requirements and intentions of MS90376, and MIL PRF 5501/31A or 32A. Prominent military contractors have qualified these materials to their own specifications and are encouraging their use. The material used in the covers were also selected for its resilience. Properly sized, the covers provide a snug, secure fit. This helps keep connectors clean and prevents the cover from accidentally falling off. BT 0806-1101 1/4 Material Properties Property Chemical Susceptibility Test Method Resistivity Contact Corrosivity Metod 3005 (Kovar plate) Crayoning Elongation Tensile Vicat Softening Out Gassing Typical Value 5 ASTM D991 FTM 101C
4272-50P 价格&库存
很抱歉,暂时无法提供与“4272-50P”相匹配的价格&库存,您可以联系我们找货
