12FMN-BMT-A-TF(LF)(SN)
    JST
    CONN FFC VERT 12POS 1.00MM SMD
12FMN-BMT-A-TF(LF)(SN) 数据手册
FMN CONNECTOR Emboss Tape 1.0 mm pitch/Connectors for PC board/For FFC・Non-ZIF Type FMN FMN CONNECTOR Specifications DIP type • Current rating: 0.5 A DC • Voltage rating: 50 V DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 30 mΩ max. After environmental tests/ 50 mΩ max. • Insulation resistance: 500 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable FFC: Conductor pitch/ 1.0 mm Conductor width/ 0.7 mm Mating part thickness/ 0.3 ± 0.05 mm • Applicable PC board thickness: 1.6 mm SMT type This connector is 1.0 mm pitch for FFC connection. Realized low cost multi-core by adopting contact structure on one side. In addition, it is a multi-entry type connector that has both DIP and SMT types. ● Compact, High-density design ● Contact structure on one side ● Heat resistant design suitable for surface  mounting ● Applicable to automatic mounting by  embossed-taping ® Note: FFC to be actually used should be checked for applicability. * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Standards ® ® Recognized E60389 Certified LR20812 ® ® 1 FMN CONNECTOR PC board layout and Assembly layout Top entry type Side entry type ●Normal type ●Normal type 0.75 ±0.05 Contact side 2 ±0.05 Even number circuits Odd number circuits 1 ±0.05 φ0.75 ±0.05 2 ±0.05 Odd number circuits Circuit No.1 Even number circuits 5.1 Circuit No.1 ●Reverse type 3 2 ±0.05 Odd number circuits φ0.75 ±0.05 2 ±0.05 2 ±0.05 0.75 ±0.05 Even number circuits 0.65 ±0.05 2.65 2 ±0.05 Even number circuits 5.1 Contact side 1 ±0.05 ●Reverse type 1 Circuit No.1 3 2 ±0.05 2 ±0.05 Odd number circuits Circuit No.1 1 ±0.05 Top entry type 0.2 1.8 1.9 1.2 Circuit No.1 0.7 ●Normal type Contact side Circuit No.1 1 ±0.05 1.7 5.15 Circuit No.1 0.6 Circuit No.1 0.6 5.1 3.05 Contact side 1.7 1.2 3 5.1 1.8 1.2 1.2 0.2 Side entry type 1 ±0.05 Note:  1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method.   The dimensions above should serve as a guideline. Contact JST for details. 2 1±0.05 5.15 0.7 1.9 0.7 1.8 1.7 0.6 Contact side 1.9 ●Reverse type 1.2 1.8 1 ±0.05 Circuit No.1 5.15 1.8 2.7 4.4 0.6 Contact side 1±0.05 0.6 0.2 1.2 0.7 ●Reverse type Contact side 5.15 ●Normal type FMN CONNECTOR Lead section dimensions of FFC DIP type Connector Top entry type Side entry type FMN/Thr/Top B B C 3 5.1 FMN CONNECTOR 3 FMN/Led ±0.1 1× (N-1) 3 5.1 ±0.12 1× (N+1) 1 ±0.1 1±0.15 0.7 ±0.1 Circuit No.1 <Note> 0.4 1 1 ±0.15 A 3 0.3 ±0.05 B C 6.5 5.1 3 0.65 N  ormal type: The solder tail for cricuit No.1 contact is positioned in front. Reverse type: The solder tail for cricuit No.1 contact is positioned behind. FMNコネクタ表4 2 Side entry type with stop 2 A 2.65 3 3.7 min. 0.4 1 Circuit No.1 <Note> 0.4 1 Circuit No.1 <Note> A 2.65 2 Note: N --- Number of circuits No. of circuits 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 Top entry type Model No. Side entry type Side entry type with stop Dimensions (mm) Normal type Reverse type Normal type Reverse type Normal type Reverse type A B C 04FMN-BTK-A 05FMN-BTK-A 06FMN-BTK-A 07FMN-BTK-A 08FMN-BTK-A 09FMN-BTK-A 10FMN-BTK-A 11FMN-BTK-A 12FMN-BTK-A 13FMN-BTK-A 14FMN-BTK-A 15FMN-BTK-A 16FMN-BTK-A 17FMN-BTK-A 18FMN-BTK-A 19FMN-BTK-A 20FMN-BTK-A 21FMN-BTK-A 22FMN-BTK-A 23FMN-BTK-A 24FMN-BTK-A 25FMN-BTK-A 26FMN-BTK-A 27FMN-BTK-A 28FMN-BTK-A 29FMN-BTK-A 30FMN-BTK-A 31FMN-BTK-A 32FMN-BTK-A 33FMN-BTK-A 34FMN-BTK-A 35FMN-BTK-A 36FMN-BTK-A 37FMN-BTK-A 38FMN-BTK-A 39FMN-BTK-A 40FMN-BTK-A 04FMN-BTRK-A 05FMN-BTRK-A 06FMN-BTRK-A 07FMN-BTRK-A 08FMN-BTRK-A 09FMN-BTRK-A 10FMN-BTRK-A 11FMN-BTRK-A 12FMN-BTRK-A 13FMN-BTRK-A 14FMN-BTRK-A 15FMN-BTRK-A 16FMN-BTRK-A 17FMN-BTRK-A 18FMN-BTRK-A 19FMN-BTRK-A 20FMN-BTRK-A 21FMN-BTRK-A 22FMN-BTRK-A 23FMN-BTRK-A 24FMN-BTRK-A 25FMN-BTRK-A 26FMN-BTRK-A 27FMN-BTRK-A 28FMN-BTRK-A 29FMN-BTRK-A 30FMN-BTRK-A 31FMN-BTRK-A 32FMN-BTRK-A 33FMN-BTRK-A 34FMN-BTRK-A 35FMN-BTRK-A 36FMN-BTRK-A 37FMN-BTRK-A 38FMN-BTRK-A 39FMN-BTRK-A 40FMN-BTRK-A 04FMN-STK-A 05FMN-STK-A 06FMN-STK-A 07FMN-STK-A 08FMN-STK-A 09FMN-STK-A 10FMN-STK-A 11FMN-STK-A 12FMN-STK-A 13FMN-STK-A 14FMN-STK-A 15FMN-STK-A 16FMN-STK-A 17FMN-STK-A 18FMN-STK-A 19FMN-STK-A 20FMN-STK-A 21FMN-STK-A 22FMN-STK-A 23FMN-STK-A 24FMN-STK-A 25FMN-STK-A 26FMN-STK-A 27FMN-STK-A 28FMN-STK-A 29FMN-STK-A 30FMN-STK-A 31FMN-STK-A 32FMN-STK-A 33FMN-STK-A 34FMN-STK-A 35FMN-STK-A 36FMN-STK-A 37FMN-STK-A 38FMN-STK-A 39FMN-STK-A 40FMN-STK-A 04FMN-STRK-A 05FMN-STRK-A 06FMN-STRK-A 07FMN-STRK-A 08FMN-STRK-A 09FMN-STRK-A 10FMN-STRK-A 11FMN-STRK-A 12FMN-STRK-A 13FMN-STRK-A 14FMN-STRK-A 15FMN-STRK-A 16FMN-STRK-A 17FMN-STRK-A 18FMN-STRK-A 19FMN-STRK-A 20FMN-STRK-A 21FMN-STRK-A 22FMN-STRK-A 23FMN-STRK-A 24FMN-STRK-A 25FMN-STRK-A 26FMN-STRK-A 27FMN-STRK-A 28FMN-STRK-A 29FMN-STRK-A 30FMN-STRK-A 31FMN-STRK-A 32FMN-STRK-A 33FMN-STRK-A 34FMN-STRK-A 35FMN-STRK-A 36FMN-STRK-A 37FMN-STRK-A 38FMN-STRK-A 39FMN-STRK-A 40FMN-STRK-A 04FMN-SSTK-A 05FMN-SSTK-A 06FMN-SSTK-A 07FMN-SSTK-A 08FMN-SSTK-A 09FMN-SSTK-A 10FMN-SSTK-A 11FMN-SSTK-A 12FMN-SSTK-A 13FMN-SSTK-A 14FMN-SSTK-A 15FMN-SSTK-A 16FMN-SSTK-A 17FMN-SSTK-A 18FMN-SSTK-A 19FMN-SSTK-A 20FMN-SSTK-A 21FMN-SSTK-A 22FMN-SSTK-A 23FMN-SSTK-A 24FMN-SSTK-A 25FMN-SSTK-A 26FMN-SSTK-A 27FMN-SSTK-A 28FMN-SSTK-A 29FMN-SSTK-A 30FMN-SSTK-A 31FMN-SSTK-A 32FMN-SSTK-A 33FMN-SSTK-A 34FMN-SSTK-A 35FMN-SSTK-A 36FMN-SSTK-A 37FMN-SSTK-A 38FMN-SSTK-A 39FMN-SSTK-A 40FMN-SSTK-A 04FMN-SSTRK-A 05FMN-SSTRK-A 06FMN-SSTRK-A 07FMN-SSTRK-A 08FMN-SSTRK-A 09FMN-SSTRK-A 10FMN-SSTRK-A 11FMN-SSTRK-A 12FMN-SSTRK-A 13FMN-SSTRK-A 14FMN-SSTRK-A 15FMN-SSTRK-A 16FMN-SSTRK-A 17FMN-SSTRK-A 18FMN-SSTRK-A 19FMN-SSTRK-A 20FMN-SSTRK-A 21FMN-SSTRK-A 22FMN-SSTRK-A 23FMN-SSTRK-A 24FMN-SSTRK-A 25FMN-SSTRK-A 26FMN-SSTRK-A 27FMN-SSTRK-A 28FMN-SSTRK-A 29FMN-SSTRK-A 30FMN-SSTRK-A 31FMN-SSTRK-A 32FMN-SSTRK-A 33FMN-SSTRK-A 34FMN-SSTRK-A 35FMN-SSTRK-A 36FMN-SSTRK-A 37FMN-SSTRK-A 38FMN-SSTRK-A 39FMN-SSTRK-A 40FMN-SSTRK-A 3.0 4.0 5.0 6.0 5.0 6.0 7.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 23.0 24.0 25.0 26.0 27.0 28.0 29.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 7.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 23.0 24.0 25.0 26.0 27.0 28.0 29.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 40.0 41.0 42.0 6.0 7.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 23.0 24.0 25.0 26.0 27.0 28.0 29.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 40.0 41.0 Q'ty/box Top entry Side entry Side entry type type type with stop 3,600 3,100 2,700 2,160 1,860 1,620 1,600 1,500 1,400 1,300 960 900 840 780 2,400 2,100 1,900 1,800 1,200 1,200 1,100 1,000 1,000 900 900 900 800 800 800 700 700 700 700 600 600 600 600 600 500 500 500 500 500 500 1,440 1,260 1,140 1,080 720 720 660 600 600 540 540 540 480 480 480 420 420 420 420 360 360 360 360 360 300 300 300 300 300 300 2,520 2,170 1,890 1,680 1,470 1,330 1,260 1,120 1,050 980 910 840 840 770 700 700 630 630 630 560 560 560 490 490 490 490 420 420 420 420 420 350 350 350 350 350 350 Material and Finish Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Housing: 4 to 22 circuits/PBT, UL94V-0, Normal type...gray Reverse type...brown 23 to 40 circuits/PA 6T, UL94V-0, Normal type...gray Reverse type...black RoHS2 compliance This product displays (LF)(SN) on a label. 3 FMN CONNECTOR SMT type Connector Side entry type Top entry type B C A ●Reverse type 0.4 1 B C A 1 ●Normal type Circuit No.1 Circuit No.1 0.4 B 0.4 1.5 0.7 ●Reverse type FMN/SMT/Sid B C A 1 Circuit No.1 B 0.7 3 Circuit No.1 B C A 0.7 No. of circuits 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 5.1 1.5 0.2 1.5 0.7 Circuit No.1 Model No. Top entry type In-line Staggered Reverse type Normal type Reverse type Normal type 04FMN-BMT-A-TF 04FMN-BMTR-A-TB 04FMN-BMTTN-A-TF 04FMN-BMTTR-A-TB 05FMN-BMT-A-TF 05FMN-BMTR-A-TB 05FMN-BMTTN-A-TF 05FMN-BMTTR-A-TB 06FMN-BMT-A-TF 06FMN-BMTR-A-TB 06FMN-BMTTN-A-TF 06FMN-BMTTR-A-TB 07FMN-BMT-A-TF 07FMN-BMTR-A-TB 07FMN-BMTTN-A-TF 07FMN-BMTTR-A-TB 08FMN-BMT-A-TF 08FMN-BMTR-A-TB 08FMN-BMTTN-A-TF 08FMN-BMTTR-A-TB 09FMN-BMT-A-TF 09FMN-BMTR-A-TB 09FMN-BMTTN-A-TF 09FMN-BMTTR-A-TB 10FMN-BMT-A-TF 10FMN-BMTR-A-TB 10FMN-BMTTN-A-TF 10FMN-BMTTR-A-TB 11FMN-BMT-A-TF 11FMN-BMTR-A-TB 11FMN-BMTTN-A-TF 11FMN-BMTTR-A-TB 12FMN-BMT-A-TF 12FMN-BMTR-A-TB 12FMN-BMTTN-A-TF 12FMN-BMTTR-A-TB 13FMN-BMT-A-TF 13FMN-BMTR-A-TB 13FMN-BMTTN-A-TF 13FMN-BMTTR-A-TB 14FMN-BMT-A-TF 14FMN-BMTR-A-TB 14FMN-BMTTN-A-TF 14FMN-BMTTR-A-TB 15FMN-BMT-A-TF 15FMN-BMTR-A-TB 15FMN-BMTTN-A-TF 15FMN-BMTTR-A-TB 16FMN-BMT-A-TF 16FMN-BMTR-A-TB 16FMN-BMTTN-A-TF 16FMN-BMTTR-A-TB 17FMN-BMT-A-TF 17FMN-BMTR-A-TB 17FMN-BMTTN-A-TF 17FMN-BMTTR-A-TB 18FMN-BMT-A-TF 18FMN-BMTR-A-TB 18FMN-BMTTN-A-TF 18FMN-BMTTR-A-TB 19FMN-BMT-A-TF 19FMN-BMTR-A-TB 19FMN-BMTTN-A-TF 19FMN-BMTTR-A-TB 20FMN-BMT-A-TF 20FMN-BMTR-A-TB 20FMN-BMTTN-A-TF 20FMN-BMTTR-A-TB 21FMN-BMT-A-TF 21FMN-BMTR-A-TB 21FMN-BMTTR-A-TB 22FMN-BMTTN-A-TF 22FMN-BMTTR-A-TB 22FMN-BMT-A-TF 22FMN-BMTR-A-TB 23FMN-BMTTN-A-TF 23FMN-BMTTR-A-TB 23FMN-BMT-A-TF 23FMN-BMTR-A-TB 24FMN-BMTTN-A-TF 24FMN-BMTTR-A-TB 24FMN-BMT-A-TF 24FMN-BMTR-A-TB 25FMN-BMTTN-A-TF 25FMN-BMTTR-A-TB 25FMN-BMT-A-TF 25FMN-BMTR-A-TB 26FMN-BMTTN-A-TF 26FMN-BMT-A-TF 26FMN-BMTR-A-TB 27FMN-BMTTN-A-TF 27FMN-BMTTR-A-TB 27FMN-BMT-A-TF 27FMN-BMTR-A-TB 28FMN-BMTTN-A-TF 28FMN-BMTTR-A-TB 28FMN-BMTR-A-TB 29FMN-BMT-A-TF 29FMN-BMTTN-A-TF 29FMN-BMTTR-A-TB 29FMN-BMTR-A-TB 30FMN-BMT-A-TF 30FMN-BMTTN-A-TF 30FMN-BMTTR-A-TB 30FMN-BMTR-A-TB 31FMN-BMT-A-TF 31FMN-BMTTN-A-TF 31FMN-BMTTR-A-TB 31FMN-BMTR-A-TB 32FMN-BMT-A-TF 32FMN-BMTTN-A-TF 32FMN-BMTTR-A-TB 32FMN-BMTR-A-TB 33FMN-BMT-A-TF 33FMN-BMTTN-A-TF 33FMN-BMTTR-A-TB 34FMN-BMT-A-TF 34FMN-BMTTN-A-TF 34FMN-BMTTR-A-TB 35FMN-BMTR-A-TB 35FMN-BMT-A-TF 35FMN-BMTTN-A-TF 35FMN-BMTTR-A-TB 36FMN-BMTR-A-TB 36FMN-BMT-A-TF 36FMN-BMTTN-A-TF 36FMN-BMTTR-A-TB 37FMN-BMTR-A-TB 37FMN-BMT-A-TF 37FMN-BMTTN-A-TF 37FMN-BMTTR-A-TB 38FMN-BMTR-A-TB 38FMN-BMT-A-TF 38FMN-BMTTN-A-TF 38FMN-BMTTR-A-TB 39FMN-BMTR-A-TB 39FMN-BMT-A-TF 39FMN-BMTTN-A-TF 39FMN-BMTTR-A-TB 40FMN-BMTR-A-TB 40FMN-BMT-A-TF 40FMN-BMTTN-A-TF 40FMN-BMTTR-A-TB Dimensions (mm) Side entry type 04FMN-SMT-A-TF 05FMN-SMT-A-TF 06FMN-SMT-A-TF 07FMN-SMT-A-TF 08FMN-SMT-A-TF 09FMN-SMT-A-TF 10FMN-SMT-A-TF 11FMN-SMT-A-TF 12FMN-SMT-A-TF 13FMN-SMT-A-TF 14FMN-SMT-A-TF 15FMN-SMT-A-TF 16FMN-SMT-A-TF 17FMN-SMT-A-TF 18FMN-SMT-A-TF 19FMN-SMT-A-TF 20FMN-SMT-A-TF 21FMN-SMT-A-TF 22FMN-SMT-A-TF 23FMN-SMT-A-TF 24FMN-SMT-A-TF 25FMN-SMT-A-TF 26FMN-SMT-A-TF 27FMN-SMT-A-TF 28FMN-SMT-A-TF 29FMN-SMT-A-TF 30FMN-SMT-A-TF 31FMN-SMT-A-TF 32FMN-SMT-A-TF 33FMN-SMT-A-TF 34FMN-SMT-A-TF 35FMN-SMT-A-TF 36FMN-SMT-A-TF 37FMN-SMT-A-TF 38FMN-SMT-A-TF 39FMN-SMT-A-TF 40FMN-SMT-A-TF A 3.0 4.0 5.0 6.0 7.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 23.0 24.0 25.0 26.0 27.0 28.0 29.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 B Top entry type Side entry type 6.0 7.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 23.0 24.0 25.0 26.0 27.0 28.0 29.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 40.0 41.0 42.0 Material and Finish Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Housing: PA 6T, UL94V-0, black Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance This product displays(LF)(SN)on a label. Note: 1 . The products listed above are supplied on embossed tape. 2. Contact JST for the top entry type headers with suction cap. 4 5.1 Circuit No.1 1 1 Circuit No.1 0.4 1 0.4 5.1 FMN表-1 0.7 3 B C A 3 ●Normal type 7.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 23.0 24.0 25.0 26.0 27.0 28.0 29.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 40.0 41.0 42.0 43.0 Q'ty/reel C 5.0 6.0 7.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 23.0 24.0 25.0 26.0 27.0 28.0 29.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 40.0 41.0 Top entry type Side entry type 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000
物料型号:FMN CONNECTOR
器件简介:这是一种1.0毫米间距的FFC(柔性扁平电缆)连接器,采用单边接触结构实现低成本多芯线缆连接。它提供DIP(双列直插)和SMT(表面贴装)两种类型,具有多入口连接器设计。
引脚分配:文档中提供了DIP类型和SMT类型的不同引脚分配方式,包括顶入式和侧入式,以及正常型和反向型。
参数特性: - 电流额定值:0.5 A DC - 电压额定值:50 V DC - 温度范围:-25℃至+85℃ - 接触电阻:初始值30 mΩ最大,环境测试后50 mΩ最大 - 绝缘电阻:最小500 MΩ - 耐压:500 VAC/分钟 - 适用的FFC规格:导体间距1.0毫米,导体宽度0.7毫米,配合件厚度0.3 ±0.05毫米 - 适用的PC板厚度:1.6毫米
功能详解:FMN CONNECTOR设计紧凑、高密度,适用于自动贴装,并且适合表面贴装的耐热设计。
应用信息:文档中提到了FMN CONNECTOR的多种型号和尺寸,适用于不同的电路数量,从4至40个电路不等。
封装信息:接触材料为磷青铜,底层铜镀层,锡镀(回流处理)。外壳材料为4至22电路/PBT,UL94V-0,正常型为灰色,反向型为棕色;23至40电路/PA 6T,UL94V-0,正常型为灰色,反向型为黑色。产品符合RoHS2标准,并在标签上显示(LF)(SN)。
12FMN-BMT-A-TF(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“12FMN-BMT-A-TF(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
