12FMN-BMTTR-A-TB(LF)(SN) 数据手册
FMN CONNECTOR
Emboss Tape
1.0 mm pitch/Connectors for PC board/For FFC・Non-ZIF Type
FMN
FMN CONNECTOR
Specifications
DIP type
• Current rating: 0.5 A DC
• Voltage rating: 50 V DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 30 mΩ max.
After environmental tests/ 50 mΩ max.
• Insulation resistance: 500 MΩ min.
• Withstanding voltage: 500 VAC/minute
• Applicable FFC: Conductor pitch/ 1.0 mm
Conductor width/ 0.7 mm
Mating part thickness/ 0.3 ± 0.05 mm
• Applicable PC board thickness: 1.6 mm
SMT type
This connector is 1.0 mm pitch for FFC
connection. Realized low cost multi-core by
adopting contact structure on one side.
In addition, it is a multi-entry type connector
that has both DIP and SMT types.
● Compact, High-density design
● Contact structure on one side
● Heat resistant design suitable for surface
mounting
● Applicable to automatic mounting by
embossed-taping
Note: FFC to be actually used should be checked for applicability.
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
Standards
Recognized E60389
Certified LR20812
1
FMN CONNECTOR
PC board layout and Assembly layout
Top entry type
Side entry type
●Normal type
●Normal type
0.75 ±0.05
Contact
side
2 ±0.05
Even number
circuits
Odd number
circuits
1 ±0.05
φ0.75 ±0.05
2 ±0.05
Odd number
circuits
Circuit No.1
Even number
circuits
5.1
Circuit No.1
●Reverse type
3
2 ±0.05
Odd number
circuits
φ0.75 ±0.05
2 ±0.05
2 ±0.05
0.75
±0.05
Even number
circuits
0.65
±0.05
2.65
2 ±0.05
Even number
circuits
5.1
Contact
side
1 ±0.05
●Reverse type
1
Circuit No.1
3
2 ±0.05
2 ±0.05
Odd number
circuits
Circuit No.1
1 ±0.05
Top entry type
0.2
1.8
1.9
1.2
Circuit No.1
0.7
●Normal type
Contact
side
Circuit No.1
1 ±0.05
1.7
5.15
Circuit No.1
0.6
Circuit No.1
0.6
5.1
3.05
Contact
side
1.7
1.2
3
5.1
1.8
1.2 1.2
0.2
Side entry type
1 ±0.05
Note:
1. The above figure is the figure viewed from the connector mounting side.
2. Tolerances are non-cumulative: ± 0.05 mm for all centers.
3. Hole dimensions differ according to the type of PC board and piercing method.
The dimensions above should serve as a guideline. Contact JST for details.
2
1±0.05
5.15
0.7
1.9
0.7
1.8
1.7
0.6
Contact
side
1.9
●Reverse type
1.2
1.8
1 ±0.05
Circuit No.1
5.15
1.8
2.7
4.4
0.6
Contact
side
1±0.05
0.6
0.2
1.2
0.7
●Reverse type
Contact
side
5.15
●Normal type
FMN CONNECTOR
Lead section dimensions of FFC
DIP type Connector
Top entry type
Side entry type
FMN/Thr/Top
B
B
C
3
5.1
FMN CONNECTOR
3
FMN/Led
±0.1
1×
(N-1)
3
5.1
±0.12
1×
(N+1)
1 ±0.1
1±0.15
0.7 ±0.1
Circuit No.1
<Note>
0.4
1
1 ±0.15
A
3
0.3 ±0.05
B
C
6.5
5.1
3
0.65
N
ormal type: The solder tail for
cricuit No.1 contact is positioned
in front.
Reverse type: The solder tail for
behind.
FMNコネクタ表4
2
Side entry type with stop
2
A
2.65
3
3.7 min.
0.4
1
Circuit No.1
<Note>
0.4
1
Circuit No.1
<Note>
A
2.65
2
Note: N --- Number of circuits
No. of
circuits
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
Top entry type
Model No.
Side entry type
Dimensions (mm)
Normal type
Reverse type
Normal type
Reverse type
Normal type
Reverse type
A
B
C
04FMN-BTK-A
05FMN-BTK-A
06FMN-BTK-A
07FMN-BTK-A
08FMN-BTK-A
09FMN-BTK-A
10FMN-BTK-A
11FMN-BTK-A
12FMN-BTK-A
13FMN-BTK-A
14FMN-BTK-A
15FMN-BTK-A
16FMN-BTK-A
17FMN-BTK-A
18FMN-BTK-A
19FMN-BTK-A
20FMN-BTK-A
21FMN-BTK-A
22FMN-BTK-A
23FMN-BTK-A
24FMN-BTK-A
25FMN-BTK-A
26FMN-BTK-A
27FMN-BTK-A
28FMN-BTK-A
29FMN-BTK-A
30FMN-BTK-A
31FMN-BTK-A
32FMN-BTK-A
33FMN-BTK-A
34FMN-BTK-A
35FMN-BTK-A
36FMN-BTK-A
37FMN-BTK-A
38FMN-BTK-A
39FMN-BTK-A
40FMN-BTK-A
04FMN-BTRK-A
05FMN-BTRK-A
06FMN-BTRK-A
07FMN-BTRK-A
08FMN-BTRK-A
09FMN-BTRK-A
10FMN-BTRK-A
11FMN-BTRK-A
12FMN-BTRK-A
13FMN-BTRK-A
14FMN-BTRK-A
15FMN-BTRK-A
16FMN-BTRK-A
17FMN-BTRK-A
18FMN-BTRK-A
19FMN-BTRK-A
20FMN-BTRK-A
21FMN-BTRK-A
22FMN-BTRK-A
23FMN-BTRK-A
24FMN-BTRK-A
25FMN-BTRK-A
26FMN-BTRK-A
27FMN-BTRK-A
28FMN-BTRK-A
29FMN-BTRK-A
30FMN-BTRK-A
31FMN-BTRK-A
32FMN-BTRK-A
33FMN-BTRK-A
34FMN-BTRK-A
35FMN-BTRK-A
36FMN-BTRK-A
37FMN-BTRK-A
38FMN-BTRK-A
39FMN-BTRK-A
40FMN-BTRK-A
04FMN-STK-A
05FMN-STK-A
06FMN-STK-A
07FMN-STK-A
08FMN-STK-A
09FMN-STK-A
10FMN-STK-A
11FMN-STK-A
12FMN-STK-A
13FMN-STK-A
14FMN-STK-A
15FMN-STK-A
16FMN-STK-A
17FMN-STK-A
18FMN-STK-A
19FMN-STK-A
20FMN-STK-A
21FMN-STK-A
22FMN-STK-A
23FMN-STK-A
24FMN-STK-A
25FMN-STK-A
26FMN-STK-A
27FMN-STK-A
28FMN-STK-A
29FMN-STK-A
30FMN-STK-A
31FMN-STK-A
32FMN-STK-A
33FMN-STK-A
34FMN-STK-A
35FMN-STK-A
36FMN-STK-A
37FMN-STK-A
38FMN-STK-A
39FMN-STK-A
40FMN-STK-A
04FMN-STRK-A
05FMN-STRK-A
06FMN-STRK-A
07FMN-STRK-A
08FMN-STRK-A
09FMN-STRK-A
10FMN-STRK-A
11FMN-STRK-A
12FMN-STRK-A
13FMN-STRK-A
14FMN-STRK-A
15FMN-STRK-A
16FMN-STRK-A
17FMN-STRK-A
18FMN-STRK-A
19FMN-STRK-A
20FMN-STRK-A
21FMN-STRK-A
22FMN-STRK-A
23FMN-STRK-A
24FMN-STRK-A
25FMN-STRK-A
26FMN-STRK-A
27FMN-STRK-A
28FMN-STRK-A
29FMN-STRK-A
30FMN-STRK-A
31FMN-STRK-A
32FMN-STRK-A
33FMN-STRK-A
34FMN-STRK-A
35FMN-STRK-A
36FMN-STRK-A
37FMN-STRK-A
38FMN-STRK-A
39FMN-STRK-A
40FMN-STRK-A
04FMN-SSTK-A
05FMN-SSTK-A
06FMN-SSTK-A
07FMN-SSTK-A
08FMN-SSTK-A
09FMN-SSTK-A
10FMN-SSTK-A
11FMN-SSTK-A
12FMN-SSTK-A
13FMN-SSTK-A
14FMN-SSTK-A
15FMN-SSTK-A
16FMN-SSTK-A
17FMN-SSTK-A
18FMN-SSTK-A
19FMN-SSTK-A
20FMN-SSTK-A
21FMN-SSTK-A
22FMN-SSTK-A
23FMN-SSTK-A
24FMN-SSTK-A
25FMN-SSTK-A
26FMN-SSTK-A
27FMN-SSTK-A
28FMN-SSTK-A
29FMN-SSTK-A
30FMN-SSTK-A
31FMN-SSTK-A
32FMN-SSTK-A
33FMN-SSTK-A
34FMN-SSTK-A
35FMN-SSTK-A
36FMN-SSTK-A
37FMN-SSTK-A
38FMN-SSTK-A
39FMN-SSTK-A
40FMN-SSTK-A
04FMN-SSTRK-A
05FMN-SSTRK-A
06FMN-SSTRK-A
07FMN-SSTRK-A
08FMN-SSTRK-A
09FMN-SSTRK-A
10FMN-SSTRK-A
11FMN-SSTRK-A
12FMN-SSTRK-A
13FMN-SSTRK-A
14FMN-SSTRK-A
15FMN-SSTRK-A
16FMN-SSTRK-A
17FMN-SSTRK-A
18FMN-SSTRK-A
19FMN-SSTRK-A
20FMN-SSTRK-A
21FMN-SSTRK-A
22FMN-SSTRK-A
23FMN-SSTRK-A
24FMN-SSTRK-A
25FMN-SSTRK-A
26FMN-SSTRK-A
27FMN-SSTRK-A
28FMN-SSTRK-A
29FMN-SSTRK-A
30FMN-SSTRK-A
31FMN-SSTRK-A
32FMN-SSTRK-A
33FMN-SSTRK-A
34FMN-SSTRK-A
35FMN-SSTRK-A
36FMN-SSTRK-A
37FMN-SSTRK-A
38FMN-SSTRK-A
39FMN-SSTRK-A
40FMN-SSTRK-A
3.0
4.0
5.0
6.0
5.0
6.0
7.0
8.0
9.0
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
19.0
20.0
21.0
22.0
23.0
24.0
25.0
26.0
27.0
28.0
29.0
30.0
31.0
32.0
33.0
34.0
35.0
36.0
37.0
38.0
39.0
7.0
8.0
9.0
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
19.0
20.0
21.0
22.0
23.0
24.0
25.0
26.0
27.0
28.0
29.0
30.0
31.0
32.0
33.0
34.0
35.0
36.0
37.0
38.0
39.0
40.0
41.0
42.0
6.0
7.0
8.0
9.0
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
19.0
20.0
21.0
22.0
23.0
24.0
25.0
26.0
27.0
28.0
29.0
30.0
31.0
32.0
33.0
34.0
35.0
36.0
37.0
38.0
39.0
40.0
41.0
Q'ty/box
Top entry Side entry Side entry
type
type type with stop
3,600
3,100
2,700
2,160
1,860
1,620
1,600
1,500
1,400
1,300
960
900
840
780
2,400
2,100
1,900
1,800
1,200
1,200
1,100
1,000
1,000
900
900
900
800
800
800
700
700
700
700
600
600
600
600
600
500
500
500
500
500
500
1,440
1,260
1,140
1,080
720
720
660
600
600
540
540
540
480
480
480
420
420
420
420
360
360
360
360
360
300
300
300
300
300
300
2,520
2,170
1,890
1,680
1,470
1,330
1,260
1,120
1,050
980
910
840
840
770
700
700
630
630
630
560
560
560
490
490
490
490
420
420
420
420
420
350
350
350
350
350
350
Material and Finish
Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment)
Housing: 4 to 22 circuits/PBT, UL94V-0, Normal type...gray Reverse type...brown
23 to 40 circuits/PA 6T, UL94V-0, Normal type...gray Reverse type...black
RoHS2 compliance This product displays (LF)(SN) on a label.
3
FMN CONNECTOR
SMT type Connector
Side entry type
Top entry type
B
C
A
●Reverse type
0.4
1
B
C
A
1
●Normal type
Circuit No.1
Circuit No.1
0.4
B
0.4
1.5
0.7
●Reverse
type
FMN/SMT/Sid
B
C
A
1
Circuit No.1
B
0.7
3
Circuit No.1
B
C
A
0.7
No. of
circuits
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
5.1
1.5
0.2
1.5
0.7
Circuit No.1
Model No.
Top entry type
In-line
Staggered
Reverse type
Normal type
Reverse type
Normal type
04FMN-BMT-A-TF
04FMN-BMTR-A-TB
04FMN-BMTTN-A-TF 04FMN-BMTTR-A-TB
05FMN-BMT-A-TF
05FMN-BMTR-A-TB
05FMN-BMTTN-A-TF 05FMN-BMTTR-A-TB
06FMN-BMT-A-TF
06FMN-BMTR-A-TB
06FMN-BMTTN-A-TF 06FMN-BMTTR-A-TB
07FMN-BMT-A-TF
07FMN-BMTR-A-TB
07FMN-BMTTN-A-TF 07FMN-BMTTR-A-TB
08FMN-BMT-A-TF
08FMN-BMTR-A-TB
08FMN-BMTTN-A-TF 08FMN-BMTTR-A-TB
09FMN-BMT-A-TF
09FMN-BMTR-A-TB
09FMN-BMTTN-A-TF 09FMN-BMTTR-A-TB
10FMN-BMT-A-TF
10FMN-BMTR-A-TB
10FMN-BMTTN-A-TF 10FMN-BMTTR-A-TB
11FMN-BMT-A-TF
11FMN-BMTR-A-TB
11FMN-BMTTN-A-TF 11FMN-BMTTR-A-TB
12FMN-BMT-A-TF
12FMN-BMTR-A-TB
12FMN-BMTTN-A-TF 12FMN-BMTTR-A-TB
13FMN-BMT-A-TF
13FMN-BMTR-A-TB
13FMN-BMTTN-A-TF 13FMN-BMTTR-A-TB
14FMN-BMT-A-TF
14FMN-BMTR-A-TB
14FMN-BMTTN-A-TF 14FMN-BMTTR-A-TB
15FMN-BMT-A-TF
15FMN-BMTR-A-TB
15FMN-BMTTN-A-TF 15FMN-BMTTR-A-TB
16FMN-BMT-A-TF
16FMN-BMTR-A-TB
16FMN-BMTTN-A-TF 16FMN-BMTTR-A-TB
17FMN-BMT-A-TF
17FMN-BMTR-A-TB
17FMN-BMTTN-A-TF 17FMN-BMTTR-A-TB
18FMN-BMT-A-TF
18FMN-BMTR-A-TB
18FMN-BMTTN-A-TF 18FMN-BMTTR-A-TB
19FMN-BMT-A-TF
19FMN-BMTR-A-TB
19FMN-BMTTN-A-TF 19FMN-BMTTR-A-TB
20FMN-BMT-A-TF
20FMN-BMTR-A-TB
20FMN-BMTTN-A-TF 20FMN-BMTTR-A-TB
21FMN-BMT-A-TF
21FMN-BMTR-A-TB
21FMN-BMTTR-A-TB
22FMN-BMTTN-A-TF 22FMN-BMTTR-A-TB
22FMN-BMT-A-TF
22FMN-BMTR-A-TB
23FMN-BMTTN-A-TF 23FMN-BMTTR-A-TB
23FMN-BMT-A-TF
23FMN-BMTR-A-TB
24FMN-BMTTN-A-TF 24FMN-BMTTR-A-TB
24FMN-BMT-A-TF
24FMN-BMTR-A-TB
25FMN-BMTTN-A-TF 25FMN-BMTTR-A-TB
25FMN-BMT-A-TF
25FMN-BMTR-A-TB
26FMN-BMTTN-A-TF
26FMN-BMT-A-TF
26FMN-BMTR-A-TB
27FMN-BMTTN-A-TF 27FMN-BMTTR-A-TB
27FMN-BMT-A-TF
27FMN-BMTR-A-TB
28FMN-BMTTN-A-TF 28FMN-BMTTR-A-TB
28FMN-BMTR-A-TB
29FMN-BMT-A-TF
29FMN-BMTTN-A-TF 29FMN-BMTTR-A-TB
29FMN-BMTR-A-TB
30FMN-BMT-A-TF
30FMN-BMTTN-A-TF 30FMN-BMTTR-A-TB
30FMN-BMTR-A-TB
31FMN-BMT-A-TF
31FMN-BMTTN-A-TF 31FMN-BMTTR-A-TB
31FMN-BMTR-A-TB
32FMN-BMT-A-TF
32FMN-BMTTN-A-TF 32FMN-BMTTR-A-TB
32FMN-BMTR-A-TB
33FMN-BMT-A-TF
33FMN-BMTTN-A-TF 33FMN-BMTTR-A-TB
34FMN-BMT-A-TF
34FMN-BMTTN-A-TF 34FMN-BMTTR-A-TB
35FMN-BMTR-A-TB
35FMN-BMT-A-TF
35FMN-BMTTN-A-TF 35FMN-BMTTR-A-TB
36FMN-BMTR-A-TB
36FMN-BMT-A-TF
36FMN-BMTTN-A-TF 36FMN-BMTTR-A-TB
37FMN-BMTR-A-TB
37FMN-BMT-A-TF
37FMN-BMTTN-A-TF 37FMN-BMTTR-A-TB
38FMN-BMTR-A-TB
38FMN-BMT-A-TF
38FMN-BMTTN-A-TF 38FMN-BMTTR-A-TB
39FMN-BMTR-A-TB
39FMN-BMT-A-TF
39FMN-BMTTN-A-TF 39FMN-BMTTR-A-TB
40FMN-BMTR-A-TB
40FMN-BMT-A-TF
40FMN-BMTTN-A-TF 40FMN-BMTTR-A-TB
Dimensions (mm)
Side entry type
04FMN-SMT-A-TF
05FMN-SMT-A-TF
06FMN-SMT-A-TF
07FMN-SMT-A-TF
08FMN-SMT-A-TF
09FMN-SMT-A-TF
10FMN-SMT-A-TF
11FMN-SMT-A-TF
12FMN-SMT-A-TF
13FMN-SMT-A-TF
14FMN-SMT-A-TF
15FMN-SMT-A-TF
16FMN-SMT-A-TF
17FMN-SMT-A-TF
18FMN-SMT-A-TF
19FMN-SMT-A-TF
20FMN-SMT-A-TF
21FMN-SMT-A-TF
22FMN-SMT-A-TF
23FMN-SMT-A-TF
24FMN-SMT-A-TF
25FMN-SMT-A-TF
26FMN-SMT-A-TF
27FMN-SMT-A-TF
28FMN-SMT-A-TF
29FMN-SMT-A-TF
30FMN-SMT-A-TF
31FMN-SMT-A-TF
32FMN-SMT-A-TF
33FMN-SMT-A-TF
34FMN-SMT-A-TF
35FMN-SMT-A-TF
36FMN-SMT-A-TF
37FMN-SMT-A-TF
38FMN-SMT-A-TF
39FMN-SMT-A-TF
40FMN-SMT-A-TF
A
3.0
4.0
5.0
6.0
7.0
8.0
9.0
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
19.0
20.0
21.0
22.0
23.0
24.0
25.0
26.0
27.0
28.0
29.0
30.0
31.0
32.0
33.0
34.0
35.0
36.0
37.0
38.0
39.0
B
Top entry type Side entry type
6.0
7.0
8.0
9.0
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
19.0
20.0
21.0
22.0
23.0
24.0
25.0
26.0
27.0
28.0
29.0
30.0
31.0
32.0
33.0
34.0
35.0
36.0
37.0
38.0
39.0
40.0
41.0
42.0
Material and Finish
Housing: PA 6T, UL94V-0, black
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
RoHS2 compliance This product displays(LF)(SN)on a label.
Note: 1 . The products listed above are supplied on embossed tape.
2. Contact JST for the top entry type headers with suction cap.
4
5.1
Circuit No.1
1
1
Circuit No.1
0.4
1
0.4
5.1
FMN表-1
0.7
3
B
C
A
3
●Normal type
7.0
8.0
9.0
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
19.0
20.0
21.0
22.0
23.0
24.0
25.0
26.0
27.0
28.0
29.0
30.0
31.0
32.0
33.0
34.0
35.0
36.0
37.0
38.0
39.0
40.0
41.0
42.0
43.0
Q'ty/reel
C
5.0
6.0
7.0
8.0
9.0
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
19.0
20.0
21.0
22.0
23.0
24.0
25.0
26.0
27.0
28.0
29.0
30.0
31.0
32.0
33.0
34.0
35.0
36.0
37.0
38.0
39.0
40.0
41.0
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
1,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
