1mm Pitch FPC/FFC Connector
FH 21 Series
■Features
1. LIF (Low Insertion Force) Mechanism
LIF mechanism secures mounting serviceability.
2. Kink Mechanism
DIP post is treated with kinks, and prevent connector
floating in the soldering process.
3. Contact Structure on Both Sides
The contact structure on both sides does restrict
directionality of FPC and FFC conductors.
■Applications
HDD, facsimiles, printers, and crystal liquie modules, etc.
■Product Specifications
Rated Current: 0.5A
Rating
Operating Temperature Range: -30 ~ +70ç (Note 1) Storage Temperature Range: -10 ~ +50ç (Note 2)
Rated Voltage: 50V AC Operating Humidity Range: Relative humidity 90% max. Storage Humidity Range: Relative Humidity: 90% max.
(Not dewed)
Applicable FPC
(Not dewed)
t=0.3±0.05 Solder plating
Item
Specification
Condition
1. Insulation Resistance
500Mø min.
Measured at 100V DC
2. Withstand voltage
Neither short nor breakdown should occur
150V AC for 1 minute
3. Contact Resistance
4. Mechanical Operation
5. Vibration
40mø
*FPC conductor resistance included
Contact resistance: 40mø max.
Measured at 100mA
10 cycles
No part should be damaged, cracked, or loosened
Electrical discontinuity, 1µS max.
Frequency 10~55Hz and single amplitude 0.75mm in
3 directions for 2 hours, respectively.
6. Shock
7. Moisture Resistance
7. in Steady State
Note 1.
Note 2.
Note 2.
Note 3.
Insulation resistance: 50Mø max.
Acceleration: 490m/s, duration: 11ms, sine half-wave
in 3 directions for 3 cycles, respectively
Exposed to temperature 60ç and humidity 90~95%
for 96 hours
Temperature rise included when energized
This storage indicates a long-term storage state for the unused product before the board mounted.
The operating temperature and humidity ranges are applied to the non-energized state after the connector has been
installed in the board.
The above standards represent this series. The individual formal agreement should be based on the "Specification".
D15
■Material
Part
Material
Finish
Remarks
Insulator
PBT
Black
UL94V-0
Contact
Phosphor bronze
Solder plating
■Ordering Information
Please determine the specific product. If needed, please select and order the product from the product No. as listed in this
catalog on page D17 and D18.
FH 21 - 10 S - 1 DS
q
w
e
r
t
y
q Series Name
: FH
r Contact Alignment: Single
w Series No.
: 21
t Contacts Pitch: 0.3mm
e Number of Contacts: 5, 6, 8, 10, 12, 14, 15, 16,
y Contact Type: DS : Right angle type
18, 20, 22, 24, 25, 28, 30
DSA : Straight type
BFPC•FFC Dimensions
Note: In case of FPC, specify 0.25, excluding adhesive agent
included in FFC.
Unit: mm
Number of Contacts
Size
5
6
8
10
12
14
15
16
18
24
26
28
30
A
4.0
5.0
7.0
9.0
11.0
13.0
14.0
15.0
17.0
19.0
21.0
23.0
25.0
27.0
29.0
B
6.0
7.0
9.0
11.0
13.0
15.0
16.0
17.0
19.0
21.0
23.0
25.0
27.0
29.0
31.0
BPCB Footprints
Unit: mm
Number of Contacts
Size
A
D16
5
6
8
10
12
14
15
16
18
24
26
28
30
4.0
5.0
7.0
9.0
11.0
13.0
14.0
15.0
17.0
19.0
21.0
23.0
25.0
27.0
29.0
■Right Angle Type
Unit: mm
Product No.
HRS No.
Number of Contacts
A
B
C
FH21-05S-1DS
CL586-0410-0
5
07
06.15
04
FH21-06S-1DS
CL586-0411-2
6
08
07.15
05
FH21-08S-1DS
CL586-0412-5
8
10
09.15
07
FH21-10S-1DS
CL586-0413-8
10
12
11.15
09
FH21-12S-1DS
CL586-0414-0
12
14
13.15
11
FH21-14S-1DS
CL586-0415-3
14
16
15.15
13
FH21-15S-1DS
CL586-0416-6
15
17
16.15
14
FH21-16S-1DS
CL586-0417-9
16
18
17.15
15
FH21-18S-1DS
CL586-0418-1
18
17
FH21-20S-1DS
CL586-0419-4
21.15
19
FH21-22S-1DS
CL586-0420-3
22
24
23.15
21
FH21-24S-1DS
CL586-0421-6
24
26
25.15
23
FH21-26S-1DS
CL586-0422-9
26
28
27.15
25
FH21-28S-1DS
CL586-0423-1
28
30
29.15
27
FH21-30S-1DS
CL586-0424-4
30
32
31.15
29
D17
■Straight Type
Unit: mm
D18
Product No.
HRS No.
Number of Contacts
A
B
C
FH21-05S-1DSA
CL586-0425-7
5
7
06.15
4
FH21-06S-1DSA
CL586-0426-0
6
8
07.15
5
FH21-08S-1DSA
CL586-0427-2
8
10
09.15
7
FH21-10S-1DSA
CL586-0428-5
10
12
11.15
9
FH21-12S-1DSA
CL586-0429-8
12
14
13.15
11
FH21-14S-1DSA
CL586-0430-7
14
16
15.15
13
FH21-15S-1DSA
CL586-0431-0
15
17
16.15
14
FH21-16S-1DSA
CL586-0432-2
16
18
17.15
15
FH21-18S-1DSA
CL586-0433-5
18
17
FH21-20S-1DSA
CL586-0434-8
21.15
19
FH21-22S-1DSA
CL586-0435-0
22
24
23.15
21
FH21-24S-1DSA
CL586-0436-3
24
26
25.15
23
FH21-26S-1DSA
CL586-0437-6
26
28
27.15
25
FH21-28S-1DSA
CL586-0438-9
28
30
29.15
27
FH21-30S-1DSA
CL586-0439-1
30
32
31.15
29
很抱歉,暂时无法提供与“FH21-14S-1DS”相匹配的价格&库存,您可以联系我们找货
