1mm Pitch FPC/FFC Connector
FH10A Series
■Features
1. ZIF Mechanism
ZIF mechanism allows a stable contact to slightly insert FPC
and FFC connectors and push movable members, so that
mounting serviceability can be secured.
2. 1mm Pitch Connector Suitable to SMT
This connector is installed in the board with high density, and
automatic mountable SMT type, while the contact pitch is 1mm.
3. Products Packaged in Embossed Tapes
Products packaged in embossed tapes are available,
correspondent to automatic mounting.
■Applications
HDD, facsimiles, printers, VTR, crystal liquid modules, etc.
■Product Specifications
Rating
Operating Temperature Range:-55~+85ç (Note 1) Storage Temperature Range:-10~+60ç (Note 2)
Rated Current: 0.5A
Rated Voltage: 50V AC
Operating Humidity Range:Relative humidity, 90% max. Storage Humidity Range:Relative humidity, 90% max.
(Not dewed)
Applicable FPC
(Not dewed)
t=0.3±0.5 Solder plating
Item
Specification
Condition
1. Insulation Resistance
500Mø min
Measured at 100V DC
2. Withstand voltage
Neither short or breakdown should occur
500V AC for 1 minute
3. Contact Resistance
25mø max.
* FPC conductor resistance included
Measured at 100A
4. Mechanical operation
Contact resistance : 25mø max.
No part should be broken, cracked or loosened
30 cycles
5. Vibration
Electrical discontinuity, 1µs min.
Frequency: 10~55Hz and full amplitude 1.52mm in
3 directions for 2 hours, respectively
6. Shock
Acceleration: 490m/S2, duration: 11ms, sine half-wave
in 3 directions for 3 times, respectively
7. Moisture Resistance in Steady State
Contact resistance: 25mø max.
Insulation resistance: 50Mø min.
Exposed to temperature 40ç and humidity 90~95% for 96 hours
8. Temperature Cycle
Temperature: -40ç→+15~35→+85→+15~+35ç
Time: 30→5~30 max.→ 5 minutes
5 cycles under conditions as follows
Neither appearance should be
Reflow: According to recommended temperature profile
Automatic soldering: 350±5 for 3 seconds
9. Resistance to Soldering heat
deformed nor contact remarkably loosened.
Note 1. Temperature rise included when energized
Note 2. This storage indicates a long-term storage state for the unusedproduct before board mounted.The operating temperature and
humidity ranges are applied to the non-energized state after the connector has been installed in the board.
Note 3. The above standards represent this series. The individual formal agreement should be based on the "Specification"
D10
■Material
Part
Material
Finish
Remarks
Insulator
PBT
Natural
UL94V-0
Contact
Phosphor bronze
Solder plating
■Ordering Information
Please determine the specific product. If needed, please select and order the product from the product No. as listed on
catalog page D12 and D13.
FH 10A - 10 S - 1 SH B (02)
q
w
e
r
t
y
u
i
q Series Name
: FH
y Contact Style
w Series No.
: 10A
u Positioning boss : No symbol : Without boss
: SH : SMT type
e Number of Contacts: 6 to 30
r Contact alignment: Single
t Contacts Pitch : 1mm
B : With boss
i Package style
: No symbol···Tube : packaging
(02)···Embossed tape packaging
BFPC · FFC Dimensions
Unit : mm
Size
Note: If FPC uses adhesive agent,
specify MIN 0.25 without
containing adhesive agent.
Number of Contacts
6
7
8
9
10
11
12
13
14
15
16
17
18
A
B
05
06
07
08
09
10
11
12
13
14
15
16
17
07
08
09
10
11
12
13
14
15
16
17
18
19
Size
Number of Contacts
19
22
23
24
25
26
27
28
29
30
A
B
18
19
22
23
24
25
26
27
28
29
22
23
24
25
26
27
28
29
30
31
BPCB Footprints
●Without boss
Unit : mm
Size
●With Boss
Number of Contacts
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
A
B
C
D
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
10.9
11.9
12.9
13.9
14.9
15.9
16.9
17.9
18.9
19.9
20.9
21.9
22.9
23.9
24.9
25.9
26.9
27.9
28.9
29.9
30.9
31.9
32.9
33.9
34.9
09.4
10.4
11.4
12.4
13.4
14.4
15.4
16.4
17.4
18.4
19.4
20.4
21.4
22.4
23.4
24.4
25.4
26.4
27.4
28.4
29.4
30.4
31.4
32.4
33.4
05
06
07
08
09
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
D11
■Without Boss Type
Unit:mm
Tube packed
Product No.
HRS No.
Number of Contacts
A
B
C
D
FH10A-06S-1SH
CL586-0495-2
6
12.2
11
05
07.15
39
FH10A-07S-1SH
CL586-0496-5
7
13.2
12
06
08.15
36
FH10A-08S-1SH
CL586-0497-8
8
14.2
13
07
09.15
33
FH10A-09S-1SH
CL586-0498-0
9
15.2
14
08
10.15
31
FH10A-10S-1SH
CL586-0499-3
10
16.2
15
09
11.15
29
FH10A-11S-1SH
CL586-0500-0
11
17.2
16
10
12.15
27
FH10A-12S-1SH
CL586-0501-3
12
18.2
17
11
13.15
26
FH10A-13S-1SH
CL586-0502-6
13
19.2
18
12
14.15
25
FH10A-14S-1SH
CL586-0503-9
14
20.2
19
13
15.15
23
FH10A-15S-1SH
CL586-0504-1
15
21.2
16.15
22
FH10A-16S-1SH
CL586-0505-4
16
22.2
21
15
17.15
21
FH10A-17S-1SH
CL586-0506-7
17
23.2
22
16
18.15
FH10A-18S-1SH
CL586-0507-0
18
24.2
23
17
19.15
19
FH10A-19S-1SH
CL586-0508-2
19
25.2
24
18
20.15
19
FH10A-20S-1SH
CL586-0509-5
25
19
21.15
18
FH10A-21S-1SH
CL586-0510-4
21
27.2
26
17
FH10A-22S-1SH
CL586-0511-7
22
28.2
27
21
23.15
17
FH10A-23S-1SH
CL586-0512-0
23
29.2
28
22
24.15
16
FH10A-24S-1SH
CL586-0513-2
24
30.2
29
23
25.15
15
FH10A-25S-1SH
CL586-0514-5
25
31.2
30
24
26.15
15
FH10A-26S-1SH
CL586-0515-8
26
32.2
31
25
27.15
14
FH10A-27S-1SH
CL586-0516-0
27
33.2
32
26
28.15
14
FH10A-28S-1SH
CL586-0517-3
28
34.2
33
27
29.15
14
FH10A-29S-1SH
CL586-0518-6
29
35.2
34
28
30.15
13
FH10A-30S-1SH
CL586-0519-9
30
36.2
35
29
31.15
13
Quantity (pcs.)
Note 1. Please order the products, thus multiplying the tube packaging quantity by an integer.
Note 2. The emboss package specification is also provided. If needed, please contact Hirose Sales Department.
(Number of contacts: 8, 10, 11, 12, 14, 15, 16, 18, 19, 20, 22, 24, 25, 30 and others will be sequentially specified.)
In addition, the emboss package contains 1,000 pcs./reel.
D12
■With Boss Type
Unit: mm
Tube packed
Product No.
HRS No.
Number of Contacts
A
B
C
D
E
FH10A-06S-1SHB
CL586-0470-1
6
12.2
11
5
7.15
10.9
39
FH10A-07S-1SHB
CL586-0471-4
7
13.2
12
6
8.15
11.9
36
FH10A-08S-1SHB
CL586-0472-7
8
14.2
13
7
9.15
12.9
33
FH10A-09S-1SHB
CL586-0473-0
9
15.2
14
8
10.15
13.9
31
FH10A-10S-1SHB
CL586-0474-2
10
16.2
15
9
11.15
14.9
29
FH10A-11S-1SHB
CL586-0475-5
11
17.2
16
10
12.15
15.9
27
FH10A-12S-1SHB
CL586-0476-8
12
18.2
17
11
13.15
16.9
26
FH10A-13S-1SHB
CL586-0477-0
13
19.2
18
12
14.15
17.9
25
FH10A-14S-1SHB
CL586-0478-3
14
20.2
19
13
15.15
18.9
23
FH10A-15S-1SHB
CL586-0479-6
15
21.2
16.15
19.9
22
FH10A-16S-1SHB
CL586-0480-5
16
22.2
21
15
17.15
20.9
21
FH10A-17S-1SHB
CL586-0481-8
17
23.2
22
16
18.15
21.9
FH10A-18S-1SHB
CL586-0482-0
18
24.2
23
17
19.15
22.9
19
FH10A-19S-1SHB
CL586-0483-3
19
25.2
24
18
20.15
23.9
19
FH10A-20S-1SHB
CL586-0484-6
25
19
21.15
24.9
18
FH10A-21S-1SHB
CL586-0485-9
21
27.2
26
25.9
17
FH10A-22S-1SHB
CL586-0486-1
22
28.2
27
21
23.15
26.9
17
FH10A-23S-1SHB
CL586-0487-4
23
29.2
28
22
24.15
27.9
16
FH10A-24S-1SHB
CL586-0488-7
24
30.2
29
23
25.15
28.9
15
FH10A-25S-1SHB
CL586-0489-0
25
31.2
30
24
26.15
29.9
15
FH10A-26S-1SHB
CL586-0490-9
26
32.2
31
25
27.15
30.9
14
FH10A-27S-1SHB
CL586-0491-1
27
33.2
32
26
28.15
31.9
14
FH10A-28S-1SHB
CL586-0492-4
28
34.2
33
27
29.15
32.9
14
FH10A-29S-1SHB
CL586-0493-7
29
35.2
34
28
30.15
33.9
13
FH10A-30S-1SHB
CL586-0494-0
30
36.2
35
29
31.15
34.9
13
Quantity (pcs.)
Note: Please order the products, thus multiplying the tube packaging quantity by an integer.
(ex.: in case of 6 contacts, 39 contacts, 78 contacts, 117 contacts....)
D13
BRecommended Temperature Profile
Applicable condition
Reflow method
Solder
: IR reflow
: Paste type 63Sn/37Pb
(Flux content: 11wt%)
Test board
: Glass epoxy · 40∞80∞1.6mm
Metal mask thickness : 0.15mm
This temperature profile is a recommendation.
The profile may be slightly changed according to the solder
paste type and amount.
D14
很抱歉,暂时无法提供与“FH10A-30S-1SHB”相匹配的价格&库存,您可以联系我们找货
