FH10A-14S-1SH
FH10A-14S-1SH
    HRS(广濑)
    CONN FFC FPC TOP 14POS 1MM R/A
FH10A-14S-1SH 数据手册
1mm Pitch FPC/FFC Connector FH10A Series ■Features 1. ZIF Mechanism ZIF mechanism allows a stable contact to slightly insert FPC and FFC connectors and push movable members, so that mounting serviceability can be secured. 2. 1mm Pitch Connector Suitable to SMT This connector is installed in the board with high density, and automatic mountable SMT type, while the contact pitch is 1mm. 3. Products Packaged in Embossed Tapes Products packaged in embossed tapes are available, correspondent to automatic mounting. ■Applications HDD, facsimiles, printers, VTR, crystal liquid modules, etc. ■Product Specifications Rating Operating Temperature Range:-55~+85ç (Note 1) Storage Temperature Range:-10~+60ç (Note 2) Rated Current: 0.5A Rated Voltage: 50V AC Operating Humidity Range:Relative humidity, 90% max. Storage Humidity Range:Relative humidity, 90% max. (Not dewed) Applicable FPC (Not dewed) t=0.3±0.5 Solder plating Item Specification Condition 1. Insulation Resistance 500Mø min Measured at 100V DC 2. Withstand voltage Neither short or breakdown should occur 500V AC for 1 minute 3. Contact Resistance 25mø max. * FPC conductor resistance included Measured at 100A 4. Mechanical operation Contact resistance : 25mø max. No part should be broken, cracked or loosened 30 cycles 5. Vibration Electrical discontinuity, 1µs min. No part should be broken, cracked or loosened Frequency: 10~55Hz and full amplitude 1.52mm in 3 directions for 2 hours, respectively 6. Shock Electrical discontinuity, 1µs min. No part should be broken, cracked or loosened Acceleration: 490m/S2, duration: 11ms, sine half-wave in 3 directions for 3 times, respectively 7. Moisture Resistance in Steady State Contact resistance: 25mø max. Insulation resistance: 50Mø min. No part should be broken, cracked or loosened Exposed to temperature 40ç and humidity 90~95% for 96 hours 8. Temperature Cycle Contact resistance: 25mø max. Insulation resistance: 50Mø min. No part should be broken, cracked or loosened Temperature: -40ç→+15~35→+85→+15~+35ç Time: 30→5~30 max.→ 5 minutes 5 cycles under conditions as follows Neither appearance should be Reflow: According to recommended temperature profile Automatic soldering: 350±5 for 3 seconds 9. Resistance to Soldering heat deformed nor contact remarkably loosened. Note 1. Temperature rise included when energized Note 2. This storage indicates a long-term storage state for the unusedproduct before board mounted.The operating temperature and humidity ranges are applied to the non-energized state after the connector has been installed in the board. Note 3. The above standards represent this series. The individual formal agreement should be based on the "Specification" D10 ■Material Part Material Finish Remarks Insulator PBT Natural UL94V-0 Contact Phosphor bronze Solder plating ––––––– ■Ordering Information Please determine the specific product. If needed, please select and order the product from the product No. as listed on catalog page D12 and D13. FH 10A - 10 S - 1 SH B (02) q w e r t y u i q Series Name : FH y Contact Style w Series No. : 10A u Positioning boss : No symbol : Without boss : SH : SMT type e Number of Contacts: 6 to 30 r Contact alignment: Single t Contacts Pitch : 1mm B : With boss i Package style : No symbol···Tube : packaging (02)···Embossed tape packaging BFPC · FFC Dimensions Unit : mm Size Note: If FPC uses adhesive agent, specify MIN 0.25 without containing adhesive agent. Number of Contacts 6 7 8 9 10 11 12 13 14 15 16 17 18 A B 05 06 07 08 09 10 11 12 13 14 15 16 17 07 08 09 10 11 12 13 14 15 16 17 18 19 Size Number of Contacts 19 20 21 22 23 24 25 26 27 28 29 30 A B 18 19 20 21 22 23 24 25 26 27 28 29 20 21 22 23 24 25 26 27 28 29 30 31 BPCB Footprints ●Without boss Unit : mm Size ●With Boss Number of Contacts 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 A B C D 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 10.9 11.9 12.9 13.9 14.9 15.9 16.9 17.9 18.9 19.9 20.9 21.9 22.9 23.9 24.9 25.9 26.9 27.9 28.9 29.9 30.9 31.9 32.9 33.9 34.9 09.4 10.4 11.4 12.4 13.4 14.4 15.4 16.4 17.4 18.4 19.4 20.4 21.4 22.4 23.4 24.4 25.4 26.4 27.4 28.4 29.4 30.4 31.4 32.4 33.4 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 D11 ■Without Boss Type Unit:mm Tube packed Product No. HRS No. Number of Contacts A B C D FH10A-06S-1SH CL586-0495-2 6 12.2 11 05 07.15 39 FH10A-07S-1SH CL586-0496-5 7 13.2 12 06 08.15 36 FH10A-08S-1SH CL586-0497-8 8 14.2 13 07 09.15 33 FH10A-09S-1SH CL586-0498-0 9 15.2 14 08 10.15 31 FH10A-10S-1SH CL586-0499-3 10 16.2 15 09 11.15 29 FH10A-11S-1SH CL586-0500-0 11 17.2 16 10 12.15 27 FH10A-12S-1SH CL586-0501-3 12 18.2 17 11 13.15 26 FH10A-13S-1SH CL586-0502-6 13 19.2 18 12 14.15 25 FH10A-14S-1SH CL586-0503-9 14 20.2 19 13 15.15 23 FH10A-15S-1SH CL586-0504-1 15 21.2 20 14 16.15 22 FH10A-16S-1SH CL586-0505-4 16 22.2 21 15 17.15 21 FH10A-17S-1SH CL586-0506-7 17 23.2 22 16 18.15 20 FH10A-18S-1SH CL586-0507-0 18 24.2 23 17 19.15 19 FH10A-19S-1SH CL586-0508-2 19 25.2 24 18 20.15 19 FH10A-20S-1SH CL586-0509-5 20 26.2 25 19 21.15 18 FH10A-21S-1SH CL586-0510-4 21 27.2 26 20 22.15 17 FH10A-22S-1SH CL586-0511-7 22 28.2 27 21 23.15 17 FH10A-23S-1SH CL586-0512-0 23 29.2 28 22 24.15 16 FH10A-24S-1SH CL586-0513-2 24 30.2 29 23 25.15 15 FH10A-25S-1SH CL586-0514-5 25 31.2 30 24 26.15 15 FH10A-26S-1SH CL586-0515-8 26 32.2 31 25 27.15 14 FH10A-27S-1SH CL586-0516-0 27 33.2 32 26 28.15 14 FH10A-28S-1SH CL586-0517-3 28 34.2 33 27 29.15 14 FH10A-29S-1SH CL586-0518-6 29 35.2 34 28 30.15 13 FH10A-30S-1SH CL586-0519-9 30 36.2 35 29 31.15 13 Quantity (pcs.) Note 1. Please order the products, thus multiplying the tube packaging quantity by an integer. Note 2. The emboss package specification is also provided. If needed, please contact Hirose Sales Department. (Number of contacts: 8, 10, 11, 12, 14, 15, 16, 18, 19, 20, 22, 24, 25, 30 and others will be sequentially specified.) In addition, the emboss package contains 1,000 pcs./reel. D12 ■With Boss Type Unit: mm Tube packed Product No. HRS No. Number of Contacts A B C D E FH10A-06S-1SHB CL586-0470-1 6 12.2 11 5 7.15 10.9 39 FH10A-07S-1SHB CL586-0471-4 7 13.2 12 6 8.15 11.9 36 FH10A-08S-1SHB CL586-0472-7 8 14.2 13 7 9.15 12.9 33 FH10A-09S-1SHB CL586-0473-0 9 15.2 14 8 10.15 13.9 31 FH10A-10S-1SHB CL586-0474-2 10 16.2 15 9 11.15 14.9 29 FH10A-11S-1SHB CL586-0475-5 11 17.2 16 10 12.15 15.9 27 FH10A-12S-1SHB CL586-0476-8 12 18.2 17 11 13.15 16.9 26 FH10A-13S-1SHB CL586-0477-0 13 19.2 18 12 14.15 17.9 25 FH10A-14S-1SHB CL586-0478-3 14 20.2 19 13 15.15 18.9 23 FH10A-15S-1SHB CL586-0479-6 15 21.2 20 14 16.15 19.9 22 FH10A-16S-1SHB CL586-0480-5 16 22.2 21 15 17.15 20.9 21 FH10A-17S-1SHB CL586-0481-8 17 23.2 22 16 18.15 21.9 20 FH10A-18S-1SHB CL586-0482-0 18 24.2 23 17 19.15 22.9 19 FH10A-19S-1SHB CL586-0483-3 19 25.2 24 18 20.15 23.9 19 FH10A-20S-1SHB CL586-0484-6 20 26.2 25 19 21.15 24.9 18 FH10A-21S-1SHB CL586-0485-9 21 27.2 26 20 22.15 25.9 17 FH10A-22S-1SHB CL586-0486-1 22 28.2 27 21 23.15 26.9 17 FH10A-23S-1SHB CL586-0487-4 23 29.2 28 22 24.15 27.9 16 FH10A-24S-1SHB CL586-0488-7 24 30.2 29 23 25.15 28.9 15 FH10A-25S-1SHB CL586-0489-0 25 31.2 30 24 26.15 29.9 15 FH10A-26S-1SHB CL586-0490-9 26 32.2 31 25 27.15 30.9 14 FH10A-27S-1SHB CL586-0491-1 27 33.2 32 26 28.15 31.9 14 FH10A-28S-1SHB CL586-0492-4 28 34.2 33 27 29.15 32.9 14 FH10A-29S-1SHB CL586-0493-7 29 35.2 34 28 30.15 33.9 13 FH10A-30S-1SHB CL586-0494-0 30 36.2 35 29 31.15 34.9 13 Quantity (pcs.) Note: Please order the products, thus multiplying the tube packaging quantity by an integer. (ex.: in case of 6 contacts, 39 contacts, 78 contacts, 117 contacts....) D13 BRecommended Temperature Profile Applicable condition Reflow method Solder : IR reflow : Paste type 63Sn/37Pb (Flux content: 11wt%) Test board : Glass epoxy · 40∞80∞1.6mm Metal mask thickness : 0.15mm This temperature profile is a recommendation. The profile may be slightly changed according to the solder paste type and amount. D14
FH10A-14S-1SH 价格&库存
很抱歉,暂时无法提供与“FH10A-14S-1SH”相匹配的价格&库存,您可以联系我们找货
