FH3-8S-1.25DS(01)
FH3-8S-1.25DS(01)
    HRS(广濑)
    CONN FFC FPC TOP 8POS 1.25MM R/A
FH3-8S-1.25DS(01) 数据手册
1.25mm Pitch FPC/FFC Connector FH3 Series ■Features 1. 1.25mm FPC and FFC DIP Connector The contact pitch is 1.25mm. 2. Contact Reliability This connector has high contact reliability for high voltage contact. 3. Sixteen Types of Contact Numbers This connector consists of 16 kinds of 6, 8, 9, 10, 12, 13, 14, 15, 15, 17, 18, 19, 20, 21, 22, 24, and 30 contacts. ■Applications HDD, facsimiles, printers, VTR, etc. ■Product Specifications Rating Operating Temperature Range:-40~+85ç (Note 1) Storage Temperature Range:-10~+60ç (Note 2) Rated Current: 1A Rated Voltage: 200V AC Operating Humidity Range:Relative humidity, 90% max. Storage Humidity Range:Relative humidity, 90% max. (Not dewed) Applicable FPC t=0.2~0.35 Tin plating Item Specification Condition 1. Insulation Resistance 500Mø min. Measured at 500V DC 2. Withstand voltage Neither short or breakdown should occur 500V AC for 1 minute 3. Contact Resistance (Not dewed) 20mø max. Measured at 0.1A π FPC conductor resistance included 4. Mechanical operation Contact resistance: 40mø max. 30 cycles No part should be broken, cracked or loosened 5. Vibration No part should be broken, cracked or loosened Frequency: 10~55Hz and full amplitude 1.50mm in 3 directions for 2 hours, respectively 6. Shock No part should be broken, cracked or loosened Acceleration: 490m/S2, duration: 11ms, sine half-wave: in 3 directions for 3 times, respectively 7. Moisture Resistance in Steady State Insulation resistance: 50Mø min. Exposed to temperature 40ç and humidity 90~95% for 96 hours 5 cycles under conditions as follows; 8. Temperature Cycle No part should be broken, cracked or loosened Temperature: -55ç→+15~+35→+85→+5~+35ç Time: 30→5 max.→ 30→5 max. for 5 minutes Note 1. Temperature rise included when energized Note 2. This storage indicates a long-term storage state for the unused product before board mounted. The operating temperature and humidity ranges are applied to the non-energized state after the connector has been installed in the board. Note 3. The above standards represent this series. The individual formal agreement should be based on the "Specification". D6 ■Material Part Material Finish Remarks Insulator PBT Black UL94V-0 Contact Phosphor bronze Tin plating ––––––– ■Ordering Information Please determine the specific product. If needed, please select and order the product from the product No. as listed on catalog page D8 and D9. FH 3 - 17 S 1.25 DS (01) q w e r t y u q Series Name : FH t Contacts Pitch : 1.25mm w Series No. :3 y Contact Style : DS : Right angle type e Number of Contacts : 4, 6, 8, 10, 12, 13, 14, 15, 16, DSA : Straight type u 17, 18, 19, 20, 22, 24, 30 (01): Tube r Contact alignment : Single ■FPC · FFC Dimensions Unit: mm Number of Contacts 4 6 8 10 12 13 14 A 3.75 6.25 B 6.25 8.75 11.25 13.75 16.25 17.5 18.75 15 16 17 18 20 22 24 30 Size 8.75 11.25 13.75 15 16.25 17.5 18.75 20 20 21.25 23.75 26.25 28.75 36.25 21.25 22.5 23.75 26.25 28.75 31.25 38.75 BPCB Footprints Unit: mm Number of Contacts 4 6 8 10 12 13 14 15 16 17 18 20 22 24 30 2.5 5 7.5 10 12.5 15 15 17.5 17.5 20 20 22.5 25 27.5 35 Size A D7 ■Right Angle Type Unit:mm Product No. D8 HRS No. Number of Contacts A B C Tube Case Packed Quantity FH3-04S-1.25DS(01) CL586-0038-0-01 4 08.70 06.27 03.75 55 FH3-06S-1.25DS(01) CL586-0065-3-01 6 11.20 08.77 06.25 42 FH3-08S-1.25DS(01) CL586-0039-3-01 8 13.70 11.27 08.75 35 FH3-10S-1.25DS(01) CL586-0057-5-01 10 16.20 13.77 11.25 29 FH3-12S-1.25DS(01) CL586-0058-8-01 12 18.70 16.27 13.75 25 FH3-13S-1.25DS(01) CL586-0040-2-01 13 19.95 17.52 15.00 24 FH3-14S-1.25DS(01) CL586-0041-5-01 14 21.20 18.77 16.25 22 FH3-15S-1.25DS(01) CL586-0078-5-01 15 22.45 20.02 17.50 21 FH3-16S-1.25DS(01) CL586-0047-1-01 16 23.70 21.27 18.75 20 FH3-18S-1.25DS(01) CL586-0081-0-01 18 26.20 23.77 21.25 17 FH3-20S-1.25DS(01) CL586-0048-4-01 20 28.70 26.27 23.75 16 FH3-22S-1.25DS(01) CL586-0049-7-01 22 31.20 28.77 26.25 15 FH3-24S-1.25DS(01) CL586-0060-0-01 24 33.70 31.27 28.75 14 FH3-30S-1.25DS(01) CL586-0050-6-01 30 41.20 38.77 36.25 11 ■Straight Type Unit:mm Product No. HRS No. Number of Contacts A B C Tube Case Packed Quantity FH3-04S-1.25DSA(01) CL586-0043-0-01 4 08.70 06.27 03.75 55 FH3-06S-1.25DSA(01) CL586-0069-4-01 6 11.20 08.77 06.25 42 FH3-08S-1.25DSA(01) CL586-0044-3-01 8 13.70 11.27 08.75 35 FH3-10S-1.25DSA(01) CL586-0061-2-01 10 16.20 13.77 11.25 29 FH3-12S-1.25DSA(01) CL586-0062-5-01 12 18.70 16.27 13.75 25 FH3-13S-1.25DSA(01) CL586-0052-1-01 13 19.95 17.52 15.00 24 FH3-14S-1.25DSA(01) CL586-0045-6-01 14 21.20 18.77 16.25 22 FH3-16S-1.25DSA(01) CL586-0053-4-01 16 23.70 21.27 18.75 20 FH3-17S-1.25DSA(01) CL586-0063-8-01 17 24.95 22.52 20.00 19 FH3-18S-1.25DSA(01) CL586-0080-7-01 18 26.20 23.77 21.25 17 FH3-20S-1.25DSA(01) CL586-0054-7-01 20 28.70 26.27 23.75 16 FH3-22S-1.25DSA(01) CL586-0055-0-01 22 31.20 28.77 26.25 15 FH3-24S-1.25DSA(01) CL586-0064-0-01 24 33.70 31.27 28.75 14 FH3-30S-1.25DSA(01) CL586-0056-2-01 30 41.20 38.77 36.25 11 D9
FH3-8S-1.25DS(01) 价格&库存
很抱歉,暂时无法提供与“FH3-8S-1.25DS(01)”相匹配的价格&库存,您可以联系我们找货
