FH21-15S-1DSA
FH21-15S-1DSA
    HRS(广濑)
    CONN FFC FPC VERT 15POS 1MM PCB
FH21-15S-1DSA 数据手册
1mm Pitch FPC/FFC Connector FH 21 Series ■Features 1. LIF (Low Insertion Force) Mechanism LIF mechanism secures mounting serviceability. 2. Kink Mechanism DIP post is treated with kinks, and prevent connector floating in the soldering process. 3. Contact Structure on Both Sides The contact structure on both sides does restrict directionality of FPC and FFC conductors. ■Applications HDD, facsimiles, printers, and crystal liquie modules, etc. ■Product Specifications Rated Current: 0.5A Rating Operating Temperature Range: -30 ~ +70ç (Note 1) Storage Temperature Range: -10 ~ +50ç (Note 2) Rated Voltage: 50V AC Operating Humidity Range: Relative humidity 90% max. Storage Humidity Range: Relative Humidity: 90% max. (Not dewed) Applicable FPC (Not dewed) t=0.3±0.05 Solder plating Item Specification Condition 1. Insulation Resistance 500Mø min. Measured at 100V DC 2. Withstand voltage Neither short nor breakdown should occur 150V AC for 1 minute 3. Contact Resistance 4. Mechanical Operation 5. Vibration 40mø *FPC conductor resistance included Contact resistance: 40mø max. Measured at 100mA 10 cycles No part should be damaged, cracked, or loosened Electrical discontinuity, 1µS max. Frequency 10~55Hz and single amplitude 0.75mm in Contact resistance: 40mø 3 directions for 2 hours, respectively. No part should be damaged, cracked, or loosened Electrical discontinuity, 1µS max. 6. Shock Contact resistance: 40mø max. No part should be damaged, cracked, or loosened 7. Moisture Resistance 7. in Steady State Note 1. Note 2. Note 2. Note 3. Contact resistance: 40mø max. Insulation resistance: 50Mø max. Acceleration: 490m/s, duration: 11ms, sine half-wave in 3 directions for 3 cycles, respectively Exposed to temperature 60ç and humidity 90~95% for 96 hours No part should be damaged, cracked, or loosened Temperature rise included when energized This storage indicates a long-term storage state for the unused product before the board mounted. The operating temperature and humidity ranges are applied to the non-energized state after the connector has been installed in the board. The above standards represent this series. The individual formal agreement should be based on the "Specification". D15 ■Material Part Material Finish Remarks Insulator PBT Black UL94V-0 Contact Phosphor bronze Solder plating --------------- ■Ordering Information Please determine the specific product. If needed, please select and order the product from the product No. as listed in this catalog on page D17 and D18. FH 21 - 10 S - 1 DS q w e r t y q Series Name : FH r Contact Alignment: Single w Series No. : 21 t Contacts Pitch: 0.3mm e Number of Contacts: 5, 6, 8, 10, 12, 14, 15, 16, y Contact Type: DS : Right angle type 18, 20, 22, 24, 25, 28, 30 DSA : Straight type BFPC•FFC Dimensions Note: In case of FPC, specify 0.25, excluding adhesive agent included in FFC. Unit: mm Number of Contacts Size 5 6 8 10 12 14 15 16 18 20 22 24 26 28 30 A 4.0 5.0 7.0 9.0 11.0 13.0 14.0 15.0 17.0 19.0 21.0 23.0 25.0 27.0 29.0 B 6.0 7.0 9.0 11.0 13.0 15.0 16.0 17.0 19.0 21.0 23.0 25.0 27.0 29.0 31.0 BPCB Footprints Unit: mm Number of Contacts Size A D16 5 6 8 10 12 14 15 16 18 20 22 24 26 28 30 4.0 5.0 7.0 9.0 11.0 13.0 14.0 15.0 17.0 19.0 21.0 23.0 25.0 27.0 29.0 ■Right Angle Type Unit: mm Product No. HRS No. Number of Contacts A B C FH21-05S-1DS CL586-0410-0 5 07 06.15 04 FH21-06S-1DS CL586-0411-2 6 08 07.15 05 FH21-08S-1DS CL586-0412-5 8 10 09.15 07 FH21-10S-1DS CL586-0413-8 10 12 11.15 09 FH21-12S-1DS CL586-0414-0 12 14 13.15 11 FH21-14S-1DS CL586-0415-3 14 16 15.15 13 FH21-15S-1DS CL586-0416-6 15 17 16.15 14 FH21-16S-1DS CL586-0417-9 16 18 17.15 15 FH21-18S-1DS CL586-0418-1 18 20 19.15 17 FH21-20S-1DS CL586-0419-4 20 22 21.15 19 FH21-22S-1DS CL586-0420-3 22 24 23.15 21 FH21-24S-1DS CL586-0421-6 24 26 25.15 23 FH21-26S-1DS CL586-0422-9 26 28 27.15 25 FH21-28S-1DS CL586-0423-1 28 30 29.15 27 FH21-30S-1DS CL586-0424-4 30 32 31.15 29 D17 ■Straight Type Unit: mm D18 Product No. HRS No. Number of Contacts A B C FH21-05S-1DSA CL586-0425-7 5 7 06.15 4 FH21-06S-1DSA CL586-0426-0 6 8 07.15 5 FH21-08S-1DSA CL586-0427-2 8 10 09.15 7 FH21-10S-1DSA CL586-0428-5 10 12 11.15 9 FH21-12S-1DSA CL586-0429-8 12 14 13.15 11 FH21-14S-1DSA CL586-0430-7 14 16 15.15 13 FH21-15S-1DSA CL586-0431-0 15 17 16.15 14 FH21-16S-1DSA CL586-0432-2 16 18 17.15 15 FH21-18S-1DSA CL586-0433-5 18 20 19.15 17 FH21-20S-1DSA CL586-0434-8 20 22 21.15 19 FH21-22S-1DSA CL586-0435-0 22 24 23.15 21 FH21-24S-1DSA CL586-0436-3 24 26 25.15 23 FH21-26S-1DSA CL586-0437-6 26 28 27.15 25 FH21-28S-1DSA CL586-0438-9 28 30 29.15 27 FH21-30S-1DSA CL586-0439-1 30 32 31.15 29
FH21-15S-1DSA 价格&库存
很抱歉,暂时无法提供与“FH21-15S-1DSA”相匹配的价格&库存,您可以联系我们找货
