2.54mm Pitch Miniature Connector for Flexible Board
FH1 Series
■Features
1. 2.54mm FPC and FFC Connector
The contact pitch is 2.54mm.
2. Contact Reliability
This connector assures high contact reliability for high voltage
contact.
3. Eighteen Types of Contact Numbers
This connector consists of 18 kinds of 8, 9, 10, 11, 12, 13, 14,
15, 15, 17, 18, 19, 20, 21, 22, 27, and 29 contacts.
■Applications
HDD, facsimiles, printers, VTR, etc.
■Product Specifications
Rating
Operating Temperature Range:_40~+85ç (Note 1) Storage Temperature Range:_10~+60ç (Note 2)
Rated Current: 1A
Rated Voltage: 200V AC
Operating Humidity Range:Relative humidity, 90% max. Storage Humidity Range: Relative humidity, 90% max.
(Not dewed)
Applicable FPC
t=0.13~0.3 Tin plating
Item
Specification
Condition
1. Insulation Resistance
5000Mø min.
Measured at 500V DC
2. Withstand voltage
Neither short or breakdown should occur.
500V AC for 1 minute
3. Contact Resistance
(Not dewed)
20mømax.
Measured at DC 1A
π FPC conductor resistance included
4. Mechanical operation
Contact resistance : 40mø max.
30 cycles
No part should be broken, cracked or loosened
5. Vibration
Frequency: 10~55Hz and full amplitude 1.50mm in 3 directions for 2 hours, respectively
6. Shock
Acceleration: 490m/S2, duration: 11ms, sine half-wave: in 3 directions for 3 times, respectively
7. Moisture Resistance in Steady State
Insulation resistance: 500Mø min.
Exposed to temperature 40ç and humidity 90~95% for 96 hours
5 cycles under conditions as follows;
8. Temperature Cycle
Temperature: _55ç→+5~+35→85→+5~+35ç
Time: 30→10~15→ 30~10~15 minutes
9.Resistance to Soldering heat Neither appearance should be deformed nor contact remarkably loosened. Automatic soldering: 260çœ for 10 seconds
Note 1. Temperature rise included when energized
Note 2. This storage indicates a long-term storage state for the unused product before board mounted.
The operating temperature and humidity ranges are applied to the non-energized state after the connector has been installed
in the board.
Note 3. The above standards represent this series. The individual formal agreement should be based on the "Specification".
D2
■Material
Part
Material
Finish
Remarks
Insulator
PBT
Black
UL94V-0
Contact
Phosphor bronze
Tin plating
■Ordering Information
Please determine the specific product. If needed, please select and order the product from the product No. as listed on
catalog page D4 and D5.
FH 1 - 17 S -2.54 DS
q
w
e
r
t
y
q Series Name
: FH
r Contact alignment : Single
w Series No.
:1
t Contacts Pitch
: 2.54mm
y Contact Type
: DS : Right angle type
e Number of Contacts : 6, 8, 9, 10, 11, 12, 13, 14, 15,
16, 17, 18, 19, 20, 21, 22, 27, 29
DSA : Straight type
■FPC · FFC Dimensions
Unit: mm
Number of Contacts
5
8
9
10
11
12
13
14
15
16
17
18
19
22
27
29
Size
A
10.16 17.78 20.32 22.86 25.40 27.94 30.48 33.02 35.56 38.10 40.64 43.18 45.72 48.26 50.80 53.34 66.04 71.12
B
15.29 22.91 25.45 27.99 30.53 33.07 35.61 38.15 40.69 43.23 45.77 48.31 50.85 53.39 55.93 58.47 69.90 76.25
D3
■Right Angle Type
Unit:mm
D4
Product No.
HRS No.
Number of Contacts
A
B
C
FH1-08S-2.54DS
CL586-0015-5
8
26.0
23.01
17.78
FH1-09S-2.54DS
CL586-0016-8
9
28.5
25.55
20.32
FH1-10S-2.54DS
CL586-0017-0
10
31.0
28.09
22.86
FH1-11S-2.54DS
CL586-0018-3
11
33.6
30.63
25.40
FH1-12S-2.54DS
CL586-0019-6
12
36.1
33.17
27.94
FH1-13S-2.54DS
CL586-0020-5
13
38.7
35.71
30.48
FH1-14S-2.54DS
CL586-0027-4
14
41.3
38.25
33.02
FH1-15S-2.54DS
CL586-0028-7
15
43.8
40.79
35.56
FH1-16S-2.54DS
CL586-0029-0
16
46.3
43.33
38.10
FH1-17S-2.54DS
CL586-0001-0
17
48.8
45.87
40.64
FH1-18S-2.54DS
CL586-0002-3
18
51.4
48.41
43.18
FH1-19S-2.54DS
CL586-0003-6
19
53.9
50.95
45.72
FH1-20S-2.54DS
CL586-0004-9
53.49
48.26
FH1-21S-2.54DS
CL586-0005-1
21
59.0
56.03
50.80
FH1-22S-2.54DS
CL586-0006-4
22
61.5
58.57
53.34
FH1-27S-2.54DS
CL586-0007-7
27
73.0
70.00
66.04
■Straight Type
Unit: mm
Product No.
HRS No.
Number of Contacts
A
B
C
D
E
F
FH1-05S-2.54DSA
CL586-0036-5
5
18.3
15.39
10.16
5.5
4
4.5
FH1-08S-2.54DSA
CL586-0021-8
8
26.0
23.01
17.78
5.5
4
4.5
FH1-10S-2.54DSA
CL586-0023-3
10
31.0
28.09
22.86
5.5
4
4.5
FH1-11S-2.54DSA
CL586-0024-6
11
33.6
30.63
25.40
5.5
4
4.5
FH1-12S-2.54DSA
CL586-0025-9
12
36.1
33.17
27.94
5.5
4
4.5
FH1-13S-2.54DSA
CL586-0026-1
13
38.7
35.71
30.48
5.5
4
4.5
FH1-14S-2.54DSA
CL586-0030-9
14
41.3
38.25
33.02
5.5
4
4.5
FH1-15S-2.54DSA
CL586-0031-1
15
43.8
40.79
35.56
5.5
4
4.5
FH1-16S-2.54DSA
CL586-0032-4
16
46.3
43.33
38.10
5.5
4
4.5
FH1-17S-2.54DSA
CL586-0008-0
17
48.8
45.87
40.64
5.5
4
4.5
FH1-18S-2.54DSA
CL586-0009-2
18
51.4
48.41
43.18
5.5
4
4.5
FH1-19S-2.54DSA
CL586-0010-1
19
53.9
50.95
45.72
5.5
4
4.5
FH1-20S-2.54DSA
CL586-0011-4
53.49
48.26
5.5
4
4.5
FH1-21S-2.54DSA
CL586-0012-7
21
59.0
56.03
50.80
5.5
4
4.5
FH1-22S-2.54DSA
CL586-0013-0
22
61.5
58.57
53.34
5.5
4
4.5
FH1-27S-2.54DSA
CL586-0014-2
27
73.0
70.00
66.04
5.5
4
4.5
FH1-29S-2.54DSA
CL586-0037-8
29
79.3
76.35
71.12
6.0
4.5
5.0
D5
