FTSH-110-01-L-DV-K-A 数据手册
REVISION FQ
DO NOT
SCALE FROM
THIS PRINT
FTSH-1XX-XX-XXX-DV-XXX-XXX
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. PARTS MAY BE CUT TO POSITION.
No OF POSITIONS
3. MAXIMUM CUT FLASH: .015[0.38], LOOSE FLASH MUST BE REMOVED.
-02 THRU -50
4. MINIMUM PUSHOUT FORCE: 1.0 LB.
(PER ROW)
5. MEASURED AT BEND RADIUS, NOT AT END OF PIN.
6. TUBE ONLY -04 THROUGH -50 POSITIONS (SEE TABLE 2).
LEAD STYLE
7. SHEAR TAILS TO DIMENSION SHOWN.
-01: .120 [3.05]
8. MAXIMUM BURR ALLOWANCE: .003 [0.08]
-02: .075 [1.91]
9. GOLD PLATING TO BE ON POST, TIN PLATING TO BE ON TAIL.
-03: .065 [1.65]
10. FILL WITH ALIGNMENT PIN HOLES TO TAIL SIDE.
-04: .150 [3.81]
11. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, LOCKING CLIPS
-05 .170 [4.32]
ARE NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS
-14: .150 [3.81](NOT AVAILABLE
MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH LOCKING CLIPS.
12. VOIDS MAY OR MAY NOT BE PRESENT ON POSITIONS 5 THRU 8 AND CAN
WITH -SM, FM, LM PLATING
BE MIXED WITHIN AN ORDER.
OPTIONS)
13. ON LEAD STYLES -02 THROUGH -03 THE T-1S15-18-XXX CAN
BE SUBSTITUTED FOR T-1S15-16-XXX.
PLATING SPECIFICATION
14. ON LEAD STYLES -01 AND -04, T-1S15-17 CAN BE
SUBSTITUTED FOR T-1S15-15-XXX.
-L: 10µ" SELECTIVE GOLD IN CONTACT AREA,
15. NO TIN PLATING ALLOWED ON THE POST FOR
MATTE TIN ON TAIL
LEAD STYLES -01, -02, -03 & -04 IN COMBINATION WITH THE
-F: 3µ" SELECTIVE GOLD IN CONTACT AREA,
T-1S15-XX-XXX TERMINAL.
MATTE TIN ON TAIL
16. MAXIMUM HEIGHT VARIATION .005[0.13] BETWEEN ROWS.
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
17. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL,
MATTE TIN ON TAIL
BASED ON OPTIONS SELECTED.
-H: 30µ" GOLD IN CONTACT AREA,
18. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE
PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY
3µ" GOLD ON TAIL
STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM
-LM: 10µ" SELECTIVE GOLD IN CONTACT AREA,
C
+0.13
No OF POS x .0500 +.005
-.014 [ -0.36 ]
(No OF POS x .0500[1.27]) - .050[1.27]
02
50
.135 3.43
REF
01
FTSH-50-D
.016 0.41 SQ
REF (TYP)
2 MAX SWAY
(EITHER DIRECTION)
POLARIZING OPTION
XXX INDICATES POSITION TO BE OMITTED
(NOT AVAILABLE WITH EXX OPTIONS)
(ONLY AVAILABLE WITH -F, -FM, -L, -LM PLATING OPTIONS)
TAIL OPTION
-DV: DOUBLE VERTICAL
* = NOT ENGINEERING APPROVED
C
.050±.008 1.27±0.20
2 MAX SWAY
(EITHER DIRECTION)
SEE TABLE 1
C 90°±3°
"A" C
(SEE NOTE 16)
.099 2.51
REF
SEE NOTE 3
(2 PLCS)
5713755 / 5961339
MATTE TIN ON TAIL
-FM: 3µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-SM: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-LTL: 10µ" SELECTIVE GOLD IN CONTACT AREA,
TIN/LEAD (90/10+/-5%) TAIL
-G: 10µ" GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
-STL: 30µ" SELECTIVE GOLD IN CONACT AREA,
TIN/LEAD (90/10 +/-5%) ON TAIL
49
2 MAX SWAY
(EITHER DIRECTION)
"B"
CONTACT AREA
(SEE NOTE 9 & TABLE 1)
PATENT NUMBERS
OPTIONS
-P: PICK & PLACE PAD (4 POS MIN)
(SEE FIG 11, SHT 4 & TABLE 5)
-TR: TAPE & REEL PACKAGING (SEE NOTE 18)
(NOT AVAILABLE WITH -EJC, -EC & -EPC. SEE NOTE 11)
-FR: FULL REEL QTY. TAPE AND REEL (SEE NOTE17)
-ES: END SHROUDS (SEE FIG 6, SHT 3)
(MOLDED IN 5 POS MIN; -02 & -03 LEAD STYLE ONLY)
(SNAP SHROUDS 9 POS MIN; -02 & -03 LEAD STYLE ONLY)
-EJ: EJECTOR SHROUDS: SEE FIG 4, SHT 2)
(10 POS MIN; -01 LEAD STYLE ONLY)
-EJM: EJECTOR SHROUDS WITH MOLDED ALIGNMENT PIN
(SEE FIG 5, SHT 2; 10 POS MIN; -01 LEAD STYLE ONLY)
(NOT VALID WITH -A OPTION)
-EJC: EJECTOR SHROUDS WITH LOCKING CLIP
(SEE FIG 5, SHT 2 & NOTE 11)
(10 POS MIN; -01 LEAD STYLE ONLY; NOT VALID WITH -A OPTION)
-EC: LOCKING CLIP (SEE FIG 7, SHT 3 & NOTE 11)
(9 POS MIN; -02 & -03 LEAD STYLE ONLY)
-EP: GUIDE POST (SEE FIG 8, SHT 3; 9 POS MIN; -02 & -03 LEAD STYLE
ONLY)(USE ONLY WHEN MATING WITH CLP)
-EL: BOARD LOCK (SEE FIG 9, SHT 3)
-EPC: GUIDE POST & LOCKING CLIP
(SEE FIG 10, SHT 3 & NOTE 11; USE ONLY WHEN MATING WITH CLP)
(9 POS MIN; -02 & -03 LEAD STYLE ONLY; NOT VALID
WITH -A OPTION)
-A: ALIGNMENT PIN (MOLDED OR STAKED; SEE FIG 3, SHT 2)
(MOLDED: 3 POS MIN; STAKED: 6 POS MIN)
(SAMTEC DISCRETION ON WHICH -A PIN USED)
-K: KEYING OPTION FOR MATING WITH FFSD
(SEE TABLE 3, SHT 2; 05 THRU 25 AVAILABLE AS STANDARD)
(POSITION 13, 17, 20 & 25 AVAILABLE WITH -EXX OPTION)
(LEAD STYLE -01 ONLY, SEE FIG 2, SHT 2 & NOTE 12)
(ALIGNMENT PIN AVAILABLE WITH -K OPTION BUT MUST BE MOLDED)
USE FTSH-50-CN-XX-X OR FTSHC-50-CN-XX-X)
* -M:(MUST
METAL PICK & PLACE PAD (5 POS MIN; USE MPP-22-5)
(SEE FIG 12, SHT 4; NOT AVAILABLE WITH -K OPTION)
+.005
SEE TABLE 6
FIG 1
+0.13
.115 - .003 2.92 - 0.08
(SEE NOTE 5)
FTSH-1XX-XX-XXX-DV SHOWN
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
1
.XXX: .005 [.13]
.XXXX: .0010 [.025]
MATERIAL:
PROPRIETARY NOTE
HAND FILL USING T-1S40
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 5:1
INSULATOR: LCP UL 94 VO
TERMINAL: PHOSPHOR BRONZE
* = SEE NOTE 13
*** = SEE NOTE 14
.230 5.84 REF
.23 5.8
(SEE NOTE 7)
SEE NOTE 8
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.050 x .050 CL DOUBLE VERTICAL SMT TERMINAL STRIP
DWG. NO.
F:\DWG\MISC\MKTG\FTSH-1XX-XX-XXX-DV-XXX-XXX-MKT.SLDDRW
BY: PURVIS
10/12/1995
SHEET 1 OF 5
USE SUB-FTSH-EJEHA
(2 REQ'D PER ASSEMBLY, EACH
USES 1 EHA-02 & 1 FTSH-EJ)
REVISION FQ
(No OF POS x
02
+.005
.0500[1.270]) - .014
+0.13
-0.36
.222 5.65
REF
.440 11.18
REF
.135 3.43
REF
01
CL
(No OF POS x .050[1.27])+.621[15.77]
±.010[0.25] C
.085 2.16 REF
.200 5.08 REF
(No OF POS x .050[1.27])+.772[19.61] REF
.126 3.20 REF
FTSH-50-D
.392 9.96
REF
SEE NOTE 12
FIG 2
FTSH-50-CN-XX-X
OR FTSHC-50-CN-XX-X
-EJ OPTION (SHROUDS OPEN)
-K OPTION
(LEAD STYLE -01 ONLY)
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)
-EXX OPTION)
CL
FIG 4
-EJ OPTION
(-01 LEAD STYLE ONLY)
FTSH-50-D
(SEE NOTE 10)
CL
.034 0.86
(No OF POS - 2)
x .050[1.27]
C
SM-A9H
.035 0.89
REF
(STAKED ALIGNMENT PINS)
2 MAX SWAY
(EITHER DIRECTION)
LC-05-TM
-EJC
+.005
.050 1.27 REF
FULL R
(MOLDED ALIGNMENT PINS)
-A OPTION
(6 POSITION MINIMUM FOR STAKED ALIGNMENT PINS)
(3 POSITION MINIMUM FOR MOLDED ALIGNMENT PINS)
+0.13
0.00
.085 - .000 2.16
.034 0.86
CL
NO CLEARANCE
ALLOWED HERE
FTSH-50-D-XX
FIG 3
USE SUB-FTSH-EJEHA-A
USES 1 EHA-02 & 1 FTSH-EJ-A)
USE SUB-FTSH-EJEHA
C
CL
(No OF POS - 2)
x .050[1.27]
.076 1.93 REF
.010 0.25 REF
-EJC
.05 1.3
REF
-EJM
FIG 5
-EJC & -EJM OPTIONS
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 4)
.035 0.89
REF
.035 0.89
REF
-EJM
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY:
PURVIS
10/12/1995
SHEET 2 OF 5
REVISION FQ
(No OF POS x .050[1.27])+.231[5.87]±.008[0.20]
.265 6.73 REF
02
.075 1.91 REF
.188 4.78
REF
.139 3.53
REF
01
C
(No OF POS x .050[1.27])+.101[2.57]±.008[0.20]
.288 7.32
REF
C
(No OF POS x .050[1.27])+.156[3.96] REF
.032[0.81] REF
CHAMFER
FTSH-EP
.120 3.05 REF
.314 7.96
FIG 8
ES-FTSH
.168 4.27
REF
-EP OPTION
(DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 6)
.194 4.91
(No OF POS x .050[1.27])+.257[6.53] REF
(SNAP SHROUDS)
.293 7.44
REF
(No OF POS (PER FINISHED ASSEMBLY)
+2) X .050 [1.27] REF
02
.1750 4.445
REF
.319 8.09
(No OF POS x .050[1.27])+.223[5.66] .008[0.20]
.0960 2.438
REF
FIG 9
-EL OPTION
01
FTSH-49-ES-XX-X
C
.178 4.51
REF
.0990 2.515 REF
(MOLDED SHROUDS)
-ES OPTION
(USE -02 OR -03 LEAD STYLE ONLY)
(9 POS MIN FOR SNAP SHROUDS)
(5 POS MIN FOR MOLDED SHROUDS)
(No OF POS x .050[1.27])+.131[3.32]±.008[0.20]
C
.280 7.11
REF
.075 1.91 REF
.288 7.32
REF
FIG 6
FTSH-EC
LC-05-TM
(No OF POS x .050[1.27])+.079[3.30]±.008[0.20]
FIG 7
-EC OPTION
.032[0.81] REF
CHAMFER
FTSH-EP
.120 3.05 REF
.314 7.96
LC-05-TM
.055 1.40
(No OF POS x .050[1.27])+.079[2.01]±.008[.20]
FIG 10
-EPC OPTION
.055 1.40
.125 3.18
REF
(No OF POS x .050[1.27])+.153[3.89] REF
FTSH-EL
FTSH-50-D
(SEE NOTE 10)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: PURVIS
10/12/1995
SHEET 3 OF 5
REVISION FQ
"M" REF
.20 5.1
REF
"P"
.060 1.52 REF
.065 1.65 REF
.16 4.1
REF
"M" REF = OVERALL LENGTH
"P" ={("M" -.200 [5.08]) / 2} .020 [.51]
.230 5.84
REF
.13 3.3 REF
PPP-25
.13 3.3
REF
.20 5.1
REF
PPP-25-KT
-P
FIG 11
.23 5.8 REF
-P OPTION
CL
FTSH-50-D
FTSH-50-CN-XX
-K-P-TR/FR
OTHERWISE SAME AS FIG 2)
PPP-25-NT
*MOLDED SHROUD ONLY
** USE PPP-25-NT WITH -TR
-P-TR
PACKAGING ONLY
NOTE: TAPE & REEL ORIENTATION:
POLARIZATION NOTCH TO THE RIGHT
"M" REF
"P"
.32 8.1
REF
.32 8.1
REF
PPP-41
.16 4.1
REF
-EJ-P & -EJX -P
"P" ={("M" -.32 [8.1]) / 2} .020 [.51]
OTHERWISE SAME AS FIGS 4 & 5)
"M" REF
TAPE & REEL VIEW
"P"
.250 6.35
REF
USER DIRECTION OF UN-REELING
POCKET NOT DETAILED
.100 2.55 REF
MPP-22-5
"B"
FTSH-50-D
"P" = {("M" - .250[6.35]) / 2} ± .020[0.51]
FIG 12
*-M: METAL PICK & PLACE PAD
(NOT AVAILABLE WITH -K OPTION)(5 POS MIN)
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: PURVIS
10/12/1995
SHEET 4 OF 5
REVISION FQ
PT-FTSH006-DV-EJC-K-P
PT-FTSH002-DV-A-P-M
PT-FTSH004-DV-EX-A-P-M
PT-FTSH002-DV-A-P-M
PT-FTSH002-DV-A-P-M
-ES, -ES-A
-ES-P, -ES-A-P
-DV
(NONE)
-A, -A-P
-DV, -P
PT-FTSH003-DV-EJC-K
PT-FTSH007-DV-K-P
-EJ, EJX AND -EJ-X
PT-FTSH007-DV-K-P
-K-P
-K, -K-A
(FOR -01 LEAD STYLE ONLY)
ALL -EJ-K OPTIONS
FIG 13
TUBE VIEWS
"A" - .034 0.864
"A" - .034 0.864
"C" REF
(SEE TABLE 1)
"A" - .034 0.864
.125±.010 3.18±0.25
(SEE NOTE 7)
.050±.005 1.270±0.127
IN PROCESS 3
IN PROCESS 2
W/O A PINS
W/O A PINS
IN PROCESS 1
W/O A PINS
"A" - .084 2.134
"A" - .084 2.134
"A" -.084[2.134]
"C" REF
(SEE TABLE 1)
.175±.010 4.445±0.254
(SEE NOTE 7)
.100±.005 2.540±0.127
IN PROCESS 1
WITH A PINS*
IN PROCESS 2
WITH A PINS*
* = FOR -01, -04, -05 AND -14 LEAD STYLES ONLY
IN PROCESS 3
WITH A PINS*
PROPRIETARY NOTE
SHEET SCALE: 2:1
IN-PROCESS VIEWS ARE FOR HANDFILL ONLY
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY:
PURVIS
10/12/1995
SHEET 5 OF 5
