TFM-120-02-S-DH
TFM-120-02-S-DH
    SAMTEC(申泰)
    SMD,P=1.27mm,卧贴
TFM-120-02-S-DH 数据手册
REVISION J DO NOT SCALE FROM THIS PRINT NOTES: 1. 2. 3. 4. 5. 6. 7. 8. TFM-1XX-XX-X-DH-XX REPRESENTS A CRITICAL DIMENSION. MINIMUM PUSHOUT FORCE TO BE 12 OZ RETENTION FOR CONTACTS AND WELD TABS. MAXIMUM TERMINAL BURR: .003[0.08] MAXIMUM HEIGHT VARIATION BETWEEN ANY TWO PINS: .005[0.13] PARTS SHALL BE PACKAGED IN TUBES UNLESS OTHERWISE SPECIFIED. SEE SHEET 2. NOTE DELETED. NOTE DELETED. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM 9. ATTACH LABEL TO EACH REEL. C LEAD STYLE -02 ROW SPECIFICATION -DH: DOUBLE HORIZONTAL PLATING SPECIFICATION -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" FLASHED SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL ((No OF POSITIONS x .050[1.27]) + .271[6.88]) REF ((No OF POSITIONS x .050[1.27])) + .025[0.64] REF C ((No OF POSITIONS - 1) x .050[1.27]) PACKAGING BLANK: TUBES (SEE NOTE 5) -TR: TAPE & REEL PACKAGING (SEE NOTES 8 & 9) -FR: FULL REEL QTY. TAPE & REEL (SEE NOTES 8 & 9) No OF POSITIONS -02 THRU -50 (PER ROW) "A" WT-81-01-T .225 5.72 REF .110 2.79 REF 02 .100 2.54 REF 01 .135 3.43 REF .050 1.27 REF .0100 0.254 "A" REF (TYP) C .094±.004 2.39±0.10 .155 3.94 REF .025 0.64 REF (TYP) (No OF POSITIONS x .050[1.27]) + .154[3.91] .057 1.44 REF 2 MAX SWAY (EITHER DIRECTION) 2 MAX SWAY (EITHER DIRECTION) "B" TFM-XX-DH .089 2.26 REF SECTION "A"-"A" SCALE 4 : 1 .018 0.46 REF (TYP) .096 2.44 REF .329 8.36 REF 2 MAX SWAY (EITHER DIRECTION) .150 3.810 REF .244 6.20 REF .1635 4.153 REF T-1R46-01-XXX T-1R45-01-XXX C .050 1.27 C "A" (SEE TABLE 2) .018 0.46 REF (TYP) .0500 1.270 (TOL. NON-ACCUMULATIVE) .135 3.43 REF "B" .030 0.762 REF (TYP) C .304±.003 7.72±0.08 FIG 1 TFM-125-02-X-DH SHOWN SECTION "B"-"B" SCALE 3 : 1 C .244±.003 6.20±0.07 (VIEW ROTATED 90°) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [0.3] 2 .XXX: .005 [0.13] .XXXX: .0020 [0.051] MATERIAL: FIG 2 BACK VIEW TFM-125-02-X-DH SHOWN C 2 MAX SWAY (EITHER DIRECTION) * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, UL 94-VO COLOR: BLACK TERMINAL: COPPER ALLOY F:\DWG\MISC\MKTG\TFM-1XX-XX-X-DH-XX-MKT.SLDDRW SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 X .050 DOUBLE HORIZONTAL TERMINAL STRIP DWG. NO. TFM-1XX-XX-X-DH-XX BY: J. BROWNING 04/12/2010 SHEET 1 OF 2 REVISION J .010 0.25 REF C .050 1.27 .010 0.25 REF C .244±.003 6.20±0.08 C .304±.003 7.72±0.08 +0.025 .0105+-.0010 .0020 0.267 - 0.051 C +0.051 .0110+-.0020 .0010 0.279 - 0.025 C .004[0.10] C "A" (SEE TABLE 2, SHT 1) IN-PROCESS 2 IN-PROCESS 1 FILL T-1R46-01-XXX FILL T-1R45-01-XXX F:\DWG\MISC\MKTG\TFM-1XX-XX-X-DH-XX-MKT.SLDDRW * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS TUBE VIEW PT-1-24-01-124 TP-07 WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 DESCRIPTION: .050 X .050 DOUBLE HORIZONTAL TERMINAL STRIP DWG. NO. TFM-1XX-XX-X-DH-XX BY: J. BROWNING 04/12/2010 SHEET 2 OF 2
TFM-120-02-S-DH 价格&库存
很抱歉,暂时无法提供与“TFM-120-02-S-DH”相匹配的价格&库存,您可以联系我们找货
TFM-120-02-S-DH
  • 1+65.485851+8.50113
  • 10+61.4415510+7.97611
  • 25+57.2256825+7.42883
  • 50+53.5117250+6.94670
  • 100+53.19308100+6.90533
库存:49
TFM-120-02-S-DH
    • 1+61.78680
    • 10+59.54040
    库存:10
