Female Card Edge
.100” [2.54 mm] Contact Centers, .431” [10.95 mm] Insulator Height,
Dip Solder/Eyelet/Right Angle for .093” [2.36 mm] Mating PCB
Sullins Female Card Edge
SPECIFICATIONS
Accommodates .093” ± .008” [2.36 mm ± 0.20 mm] PC board
PBT, PPS, PA9T, or PEEK insulator
Molded-in key available
3 Amps current rating for one contact energized
30 milli Ohms maximum at rated current
UL Flammability Rating: 94V-0
READOUT
.265"[6.73]INSERTION DEPTH
FULL BELLOWS
BACK-UP
SPRING
LETTER
'A' SIDE
HALF LOADED (H)
DUAL (D)
TERMINATION TYPE
.125” [3.18]
.185” [4.70]
EYELET ACCEPTS 3-#26 AWG
.050” [1.27]
.225” [5.72]
.200” [5.08] (RT)
.440” [11.19] (RY)
LETTER B
SIDE
FITS Ø.043” [1.09]
.007” [0.18] THICK
.156” [3.96]
NARROW DIP SOLDER
(RT,RY)
RIGHT ANGLE
(RA)
EYELET
(RE)
FITS Ø.043” [1.09]
.200” [5.08]
MOUNTING STYLE
Ø.125” [3.18]
#4-40
Ø.116” [2.95]
CLEARANCE FOR
#4 SCREW
Ø.125” [3.18]
.135” [3.43]
CLEARANCE
HOLE (H)
48
THREADED
INSERT ( I )
FLOATING
BOBBIN (F)
NO MOUNTING EARS
(N)
SIDE MOUNTING
(S)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
PART NUMBER OPTIONS
E B
C 43 D RE H - S93
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze (Standard)
R = PPS/Phosphor Bronze
G = PA9T/Phosphor Bronze
H = PBT/Beryllium Copper
A = PPS/Beryllium Copper
J = PA9T/Beryllium Copper
*F = PPS/Spinodal (Overall Gold Plating Only)
Consult Factory for Special Soldering Guidelines
*C = PPS/Beryllium Nickel (Overall Gold Plating Only)
*W = PEEK/Beryllium Nickel (Overall Gold Plating Only)
*Consult factory for availability.
Refer to Page 7 for Operating/Processing Temperatures
MOUNTING STYLE (Opposite Page)
H = .125” [3.18 mm] Clearance Holes
N = No Mounting
S = Side Mounting
I = Threaded Insert
F = Floating Bobbin
TERMINATION TYPE (Opposite Page)
RA = Right Angle
RE = Eyelet
RT = .200” [5.08 mm] X .200” [5.08 mm] Dip Solder
RY = .200” [5.08 mm] X .440” [11.19 mm] Dip Solder
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
.000010” Gold
.000030” Gold
.000010” Gold
.000030” Gold
Contact Surface
S = .000010” Gold
M = .000030” Gold
E = .000100” Pure Tin, Matte
B
C
G
Y
MODIFICATION (Consult Factory)
-S93 = .093” ± .008” [2.36 mm ± 0.20 mm] PCB,
.200” [5.08 mm] Row Spacing (RT, RY)
Termination
.000005” Gold
.000005” Gold
Overall Plating
.000010” Gold
.000010” Gold
READOUT (Opposite Page)
D = Dual
H = Half Loaded
NUMBER OF CONTACT POSITIONS
See Chart Below
CONTACT CENTERS
C = .100” [2.54 mm]
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
.265 [6.73]INSERTION DEPTH
B
A
C
REFER TO
MOUNTING
STYLE
F
.025
[0.64]
.100 [2.54]
D
E
CONTACT MARKINGS
B 1 2 3 ... 58 59 60 B
A 1 2 3 ... 58 59 60 A
.431 [10.95]
B 1 2
59 60 B
A 1 2
59 60 A
.245 [6.22]
REFER TO TERMINATION TYPE
Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory.
POSITIONS/
CONTACTS
04/08*
05/10
06/12
07/14
08/16
10/20
12/24
13/26
15/30
17/34
18/36
19/38
20/40
22/44
23/46*
25/50
26/52
28/56
30/60
31/62
35/70
36/72
40/80
43/86
44/88
49/98
50/100
52/104*
60/120
65/125
INCHES
MILLIMETERS
A±.008 B±.008 C±.015 D±.010 E±.020
0.300
0.400
0.500
0.600
0.700
0.900
1.100
1.200
1.400
1.600
1.700
1.800
1.900
2.100
2.200
2.400
2.500
2.700
2.900
3.000
3.400
3.500
3.900
4.200
4.300
4.800
4.900
5.100
5.900
6.400
0.500
0.600
0.700
0.800
0.900
1.100
1.300
1.400
1.600
1.800
1.900
2.000
2.100
2.300
2.400
2.600
2.700
2.900
3.100
3.200
3.600
3.700
4.100
4.400
4.500
5.000
5.100
5.300
6.100
6.600
0.675
0.775
0.875
0.975
1.075
1.275
1.475
1.575
1.775
1.975
2.075
2.175
2.275
2.475
2.575
2.775
2.875
3.075
3.275
3.375
3.775
3.875
4.275
4.575
4.675
5.175
5.275
5.475
6.275
6.775
0.975
1.075
1.175
1.275
1.375
1.575
1.775
1.875
2.075
2.275
2.375
2.475
2.575
2.775
2.875
3.075
3.175
3.375
3.575
3.675
4.075
4.175
4.575
4.875
4.975
5.475
5.575
5.775
6.575
7.075
1.275
1.375
1.475
1.575
1.675
1.875
2.075
2.175
2.375
2.575
2.675
2.775
2.875
3.075
3.175
3.375
3.475
3.675
3.875
3.975
4.375
4.475
4.875
5.175
5.275
5.775
5.875
6.075
6.875
7.375
F+.005/-.015
0.330
0.400
A±0.20
B±0.20
C±0.38
D±0.25
E±0.51
7.62
10.16
12.70
15.24
17.78
22.86
27.94
30.48
35.56
40.64
43.18
45.72
48.26
53.34
55.88
60.96
63.50
68.58
73.66
76.20
86.36
88.90
99.06
106.68
109.22
121.92
124.46
129.54
149.86
162.56
12.70
15.24
17.78
20.32
22.86
27.94
33.02
35.56
40.64
45.72
48.26
50.80
53.34
58.42
60.96
66.04
68.58
73.66
78.74
81.28
91.44
93.98
104.14
111.76
114.30
127.00
129.54
134.62
154.94
167.64
17.15
19.69
22.23
24.77
27.31
32.39
37.47
40.01
45.09
50.17
52.71
55.25
57.79
62.87
65.41
70.49
73.03
78.11
83.19
85.73
95.89
98.43
108.59
116.21
118.75
131.45
133.99
139.07
159.39
172.09
24.77
27.31
29.85
32.39
34.93
40.01
45.09
47.63
52.71
57.79
60.33
62.87
65.41
70.49
73.03
78.11
80.65
85.73
90.81
93.35
103.51
106.05
116.21
123.83
126.37
139.07
141.61
146.69
167.01
179.71
32.39
34.93
37.47
40.01
42.55
47.63
52.71
55.25
60.33
65.41
67.95
70.49
73.03
78.11
80.65
85.73
88.27
93.35
98.43
100.97
111.13
113.67
123.83
131.45
133.99
146.69
149.23
154.31
174.63
187.33
F+0.13/-0.38
8.38
10.16
* Consult factory for availability.
49
很抱歉,暂时无法提供与“GCC25DRYN-S93”相匹配的价格&库存,您可以联系我们找货
