TFM-130-02-L-D-DS
TFM-130-02-L-D-DS
    SAMTEC(申泰)
    SMD
TFM-130-02-L-D-DS 数据手册
REVISION FQ DO NOT SCALE FROM THIS PRINT NOTES: TFM-1XX-XX-XXX-D-XXX 1. C REPRESENTS A CRITICAL DIMENSION. OPTION 2. MINIMUM PUSHOUT FORCE FOR CONTACTS, WELD TABS, C -A: ALIGNMENT PIN (USE TFM-XX-D-XX-A, No OF POSITIONS AND THREADED INSERTS: 12 OZ. SEE TABLE 1) (SEE FIG 8, SHT 3) 3. MINIMUM LOCKING CLIP RETENTION: 8 OZS. LEAD STYLE -01, -02, -03: -02 THRU -50 (ALL (NOT AVAILABLE FOR -RA OR -REX) 4. MAXIMUM HEIGHT VARIATION BETWEEN ANY TWO PINS: .005[0.13] POSITIONS AVAILABLE) -LC: LOCKING CLIP (USE LC-05-TM) 5. MAXIMUM TERMINAL BURR: .003[0.08] (NOT AVAILABLE FOR -RA OR -REX) LEAD STYLES -11, -12, -13: (-05 THRU -50 MULTIPLES OF 5) 6. COPLANARITY: .004[0.10] = POS 02 THRU 26 (SEE FIG 10, SHT 3 & NOTES 3 & 11) POSITIONS 12, 16, 17 ALSO AVAILABLE .006[0.15] = POS 27 THRU 50 C -P: PICK AND PLACE PAD (USE PPP-04) LEAD STYLES -21, 22, 23: (-05 THRU -50 MULTIPLES OF 5) 7. MEASURED FROM BEND. (AVAILABLE IN ALL POSITIONS -05 THRU POSITIONS 12 & 13 ALSO AVAILABLE 8. DIMENSION CHANGED PER REVISION AD. CONTACT ENGINEERING LEAD STYLES 31, 32: 12 POSITION ALSO AVAILABLE -50 EXCEPT -05 WITH -WT) FOR INFORMATION. (NOT AVAILABLE FOR -RA OR -REX, 9. MEASURE FROM TIPS OF PIN. SEE FIG 7, SHT 3) LEAD STYLE 10. NOTE DELETED. -RA: RIGHT ANGLE(AVAILABLE ONLY IN LEAD STYLE: -01 11. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, SEE FIG 5, SHT 2) THROUGH HOLE SURFACE MOUNT THE –LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC -TR: TAPE AND REEL (SEE FIG 4, SHT 7(NOT AVAILABLE -01, -03 (SEE FIG 1) -02 (SEE FIG 2) RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE WITH -DS OPTION OR THROUGH HOLE LEAD STYLE) -11, -13 (SEE FIG 1) -12 (SEE FIG 2) (SEE NOTES 14&15) –LC OPTION. -21,-23 (SEE FIG 1) -22 (SEE FIG 2) -SA: STAKED ALIGNMENT PIN (SEE FIG 9, SHT 3) -31 (SEE FIG 1) -32 (SEE FIG 2) 12. SIDES OF PLASTIC BODIES ON ALL LEAD STYLES EXCEPT THE -01, -02 & -03 (ONLY AVAILABLE ON SURFACE MOUNT LEAD STYLE) WILL BE SOLID AND WITHOUT SIDE SLOTS. PLATING SPECIFICATION -K: POLYIMIDE FILM (SEE FIG 3, SHT 2) 13. NOTE DELETED. (USE K-DOT-.217-.313-.005) 14. NOT ALL PARTS FOLLOW EIA-481 ORIENTATION IN THE T&R POCKET. -S: 30µ" SELECTIVE GOLD ON CONTACT AREA, (NOT AVAILABLE FOR -RA OR -REX) MATTE TIN TAIL 15. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED -L: 15µ" SELECTIVE GOLD ON CONTACT AREA, (ALL LEAD STYLES EXCEPT -21 AVAILABLE) ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND MATTE TIN TAIL -WT: WELD TABS (USE WT-25-XX-T) ON WWW.SAMTEC.COM. -F: 3µ" FLASH GOLD ON CONTACT AREA, (AVAILABLE ON -01, -02 & -03 LEAD 16. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON MATTE TIN TAIL STYLES ONLY) (SEE FIG 6, SHT 2) OPTIONS SELECTED. -H: 30µ" SELECTIVE GOLD ON CONTACT AREA, (MATES WITH SFSS/SFSD -SR & -DR ONLY) (No OF POSITIONS x .050[1.27]) + .125[3.18] REF 3µ" FLASH GOLD ON TAIL (NOT AVAILABLE WITH -A, -LC, -SM: 30µ" SELECTIVE GOLD ON CONTACT AREA, (No OF POSITIONS x .050[1.27]) + .025[.64] REF -RA, OR -SA OPTIONS) MATTE TIN TAIL -RE1: RIGHT ANGLE ELEVATED .062 PCB .110 2.79 REF -LM: 15µ" SELECTIVE GOLD ON CONTACT AREA, 02 (USE TFM-XX-D-01-RE, NOT AVAILABLE MATTE TIN TAIL WITHOUT -WT, AVAILABLE IN LEAD -FM: 3µ" FLASH GOLD ON CONTACT AREA, STYLE -01 ONLY, -03 THRU -50 POS) .155 3.94 MATTE TIN TAIL (MATES WITH SFSS/SFSD -SR & -DR ONLY) -STL: 30µ" SELECTIVE GOLD ON CONTACT AREA, REF (SEE FIG 11, SHT 4) TIN/LEAD (90/10 ±5%) TAIL -RE2: RIGHT ANGLE ELEVATED .093 PCB (USE TFM-XX-D-01-RE, NOT AVAILABLE 01 .050 1.27 BODY SPECIFICATION WITHOUT -WT, AVAILABLE IN LEAD .225 5.72 -D: DOUBLE ROW .075 1.91 REF STYLE -01 ONLY, -03 THRU -50 POS) REF (MATES WITH SFSS/SFSD -SR & -DR ONLY) REF C (SEE FIG 11, SHEET 4) .050 1.27 (No OF POSITIONS x .050[1.27]) - .050[1.27] -SN: SOLDER NAIL FOR .062 BOARD (TFM-XX-D-01-SN AND WT-27-01-T) 2 MAX SWAY (SEE FIG12, SHT 3) (EITHER DIRECTION) "D" REF .018 0.46 REF (ONLY AVAILABLE WITH -02 LEAD STYLE) (SEE TABLE 1, .135 3.43 REF 2 MAX SWAY (NOT AVAILABLE WITH OPTIONS -A, -LC, "A" (EITHER DIRECTION) SHT 7) -RA, -SA, -WT, -RE1 OR -RE2) -SN2: SOLDER NAIL FOR .093 BOARD (TFM-XX-D-01-SN AND WT-27-02-T) .096 2.44 (SEE FIG12, SHT 3) "A" REF .1635 4.153 (SEE NOTE 8) (ONLY AVAILABLE WITH -02 LEAD STYLE) REF (SEE TABLE 1, (NOT AVAILABLE WITH OPTIONS -A, -LC, SHT 7) -RA, -SA, -WT, -RE1 OR -RE2) -DS: DUAL SCREW DOWN FOR .062 BOARD (SEE FIG 18, SHT 5) SEE NOTE 12 (ONLY AVAILABLE WITH -01 & -02 LEAD STYLE) .010 0.25 REF (NOT AVAILABLE WITH OPTIONS -A, -LC, -P, C .014 0.36 REF -RA, -TR, -SA, -K, -WT, -RE1, -RE2, -SN, -SN2) .050 1.27 "A" C 2 MAX SWAY (-01 LEAD STYLE USES TFM-XX-D-01-DSL "J" ± .003 [0.08] 2 MAX SWAY & T1-M2-4-VSFM-T, 02 LEAD STYLE USES (EITHER DIRECTION) (SEE TABLE 1, SHT 7) (EITHER DIRECTION) TFM-XX-D-01-DSA & T1-M2-4-VSFM-T) C -FR: FULL REEL QTY. TAPE & REEL (NOT AVAILABLE WITH SECTION "A"-"A" -DS OPTION OR THROUGH HOLE LEAD STYLE) (No OF POSITIONS x .050[1.27]) - .050[1.27] (SEE NOTES 14 & 16) PROPRIETARY NOTE C UNLESS OTHERWISE SPECIFIED, * * DIMENSIONS ARE IN INCHES. FIG 1 "C"±.003 [0.08] C (SEE TABLE 1, SHT 7) (APPLY FOR BOTH ROWS) IN-PROCESS THROUGH HOLE -01, -03, -11, -13, -21, -23, -31 TOLERANCES ARE: DECIMALS ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, UL 94-VO COLOR: BLACK TERMINAL: PHOSPHOR BRONZE F:\DWG\MISC\MKTG\TFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 TERMINAL STRIP TFM-1XX-XX-XXX-D-XXX BY: garyp 11/5/2014 SHEET 1 OF 7 REVISION FQ SEE NOTE 12 01 03 02 2 C 3 SEE NOTE 6 C "B" FLUSH TO .012 [0.30] MAX (SEE NOTE 7) .235 5.97 MAX C 3 MAX SWAY (EITHER DIRECTION) NOTCH TO BE ORIENTED AS SHOWN "C" "E" (SEE TABLE 1, SHT 7) .217 5.51 REF 90° "S" (SEE NOTE) 7 (-12, -22 & -32 STYLES) 3 (-02 STYLE ONLY) SECTION "B"-"B" No OF POSITIONS x .050) - .050[1.27] (TOL ACCUM ±.005[0.13] FIG 2 OVER 50 POS) SURFACE MOUNT -02, -12, -22, -32 DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 02 01 "K"±.006[0.15] (SEE TABLE 1,SHT 7) C "B" C "C"±.003 [0.08] (SEE TABLE 1, SHT 7) (APPLY FOR BOTH ROWS) "R" (SEE NOTE) .005±.020 0.13±0.51 NOTE: “R” = OVERALL LENGTH (REF) “S” = {(“R” - .216[5.49] /2} ±.020[.51] FIG 3 IN-PROCESS "A" REF (SEE TABLE 1, SHT 7) "E" (SEE TABLE 1, SHT 7) -K: POLYIMIDE FILM PAD TERMINAL 2 (SEE TABLE 1, SHT 7) TERMINAL 1 (SEE TABLE 1, SHT 7) TFM-XX-D-XX-WT (No OF POSITIONS X .050[1.27]) + .263[6.68] REF "D" WT-25-04-T .075 1.91 REF .014 0.36 REF (TYP) "C" 2 MAX SWAY (EITHER DIRECTION) C .020 0.51 C (SEE NOTE 9 & TABLE 1, SHT 7) C 90° .050 1.27 C (SEE NOTE 9 & TABLE 1, SHT 7) FIG 5 C .093 2.36 (TYP) .010 0.25 REF (TYP) (No OF POSITIONS x .050[1.27]) + .154[3.91] .422 10.72 "A" REF (SEE TABLE 1, SHT 7) .025 0.64 REF SECTION "D"-"D" 2 MAX SWAY (EITHER DIRECTION) SECTION "C"-"C" FIG 6 -RA OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 TERMINAL 2 (SEE TABLE 1, SHT 7) "D" -WT OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 .422 10.72 TERMINAL 2 (SEE TABLE 1, SHT 7) F:\DWG\MISC\MKTG\TFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW TERMINAL 1 (SEE TABLE 1, SHT 7) .075 1.91 REF CARRIER STRIP TERMINAL 1 (SEE TABLE 1, SHT 7) I.D.MARK C 90° .020 0.51 C PROPRIETARY NOTE DO NOT SCALE DRAWING IN-PROCESS 1 (ORIENT I.D. MARK AS SHOWN) (FOR -RA OPTION ONLY) * IN-PROCESS 2 * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 TERMINAL STRIP TFM-1XX-XX-XXX-D-XXX BY: garyp 11/5/2014 SHEET 2 OF 7 REVISION FQ "M" (SEE NOTE) "P" (SEE NOTE) C .045 1.14 REF (No OF POSITIONS x .050[1.27]) + .075[1.91] .050 1.27 REF R.025 [0.64] REF FIG 8 .394 10.01 REF .050 1.27 *PPP-04 .225 5.72 REF "E" CL -A OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 "E" CL SECTION "E"-"E" NOTE: “M” = (No. OF POSITIONS X .050[1.27]) + .125[3.18] (REF) WITH -WT “M” = (No. OF POSITIONS X .050[1.27]) + .263[6.68] (REF) “P” = {(“M” - .394[10.01]) /2} ±.020[.51] * NOTCH ON PAD TO BE ON SAME END AS THE NOTCH IN THE TFM BODY (No OF POSITIONS x .050[1.27]) + .075[1.91] +.008[0.20] FIG 9 (No OF POSITIONS x .050[1.27]) + .275 REF TFM-XX-D-01-SN CL "B" REF "K" FLUSH TO .005[0.13] ABOVE .075 1.91 REF .026 0.66 REF .050 1.27 C SECTION "K"-"K" 2 MAX SWAY (EITHER DIRECTION) LC-05-TM (No OF POSITIONS x .050[1.27]) + .175[4.45] .056 1.42 REF 2 MAX SWAY (EITHER DIRECTION) ((No OF POS x .050[1.27]) + .075[1.91])±.002[0.05] CL "K" WT-27-XX-T .010 0.25 REF 2 MAX SWAY (EITHER DIRECTION) -SA OPTION: STAKED ALIGNMENT PIN DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 FIG 7 2 MAX SWAY (EITHER DIRECTION) .035 0.89 REF .050 1.27 -.009[0.23] -P OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 (PAD TO BE POSITIONED ON C.L. AS SHOWN) TFM-1XX-02-D-LC SM-A5 FIG 12 -SNX: SOLDER NAIL DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 F:\DWG\MISC\MKTG\TFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW * FIG 10 -LC OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 (NOT AVAILBLE ON -RA) PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 TERMINAL STRIP TFM-1XX-XX-XXX-D-XXX BY: garyp 11/5/2014 SHEET 3 OF 7 REVISION FQ .775 19.69 "A" REF (SEE TABLE 1, SHT 7) .014 0.36 REF .220 5.59 REF TERMINAL 2 (SEE TABLE 1, SHT 7) .555 14.10 TERMINAL 1 (SEE TABLE 1, SHT 7) I.D. MARK IN-PROCESS 1 .255 6.48 REF "J" .225 5.72 REF 2 MAX SWAY "J" (EITHER DIRECTION) C .010 0.25 REF (TYP) 2 MAX SWAY (EITHER DIRECTION) (ORIENT I.D. MARK AS SHOWN) (FOR -RA OPTION ONLY) TFM-XX-D-01-RE CL .555 14.10 "A" REF (SEE TABLE 1, SHT 7) TERMINAL 2 (SEE TABLE 1, SHT 7) "F" REF "F" .075 1.91 C (SEE NOTE 9 & TABLE 1, SHT 7) C 90° (No OF POSITIONS x .050[1.27]) + .154[3.91] TERMINAL 1 (SEE TABLE 1, SHT 7) C 90° .020 0.50 C (SEE NOTE 9 & TABLE 1, SHT 7) .020 0.50 C (SEE NOTE 9 & TABLE 1, SHT 7) (No OF POSITONS x .050[1.27]) + .263[6.68] REF IN-PROCESS 2 "H" TERMINAL 2 (SEE TABLE 1, SHT 7) C "G" "F" TERMINAL 1 (SEE TABLE 1, SHT 7) .025 0.64 REF C 90° .075 1.91 C (SEE NOTE 9 & TABLE 1, SHT 7) .097 2.46 IN-PROCESS 3 SECTION "J"-"J" F:\DWG\MISC\MKTG\TFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. FIG 11 -REX: RIGHT ANGLE ELEVATED TFM-120-XX-XXX-D-RE2 SHOWN DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 TERMINAL STRIP TFM-1XX-XX-XXX-D-XXX BY: garyp 11/5/2014 SHEET 4 OF 7 REVISION FQ (No OF POSITIONS x .050[1.27]) + .600[15.24] C (No OF POSITIONS x .050[1.27]) + .360[9.14] 02 CL CL 01 TFM-XX-01-D-DSA POSITION 1 INDICATOR CL T1-M2-4-VSFM-X .157 3.98 REF SEE NOTE 6 C .079 1.99 .150 3.81 REF .025 0.64 SQ REF (3 PLCS) .150 3.81 REF (No OF POSITIONS x .050[1.27]) + .075[1.91] REF CL F:\DWG\MISC\MKTG\TFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW FIG 18 -DS: DUAL SCREW DOWN TFM-110-02-XXX-D-DS SHOWN DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 X .050 TERMINAL STRIP DWG. NO. TFM-1XX-XX-XXX-D-XXX BY: garyp 11/5/2014 SHEET 5 OF 7 PARTS TO BE PACKAGED IN TUBES AS SHOWN REVISION FQ LOADING DIRECTION ARROW LOADING DIRECTION ARROW POLARIZATION NOTCH POLARIZATION NOTCH PT-1-24-18-09 (SEE TABLE 2) PT-1-24-XX-09 (SEE TABLE 2) FIG 13 FIG 14 PT-1-24-18-09 PT-1-24-XX-09 LOADING DIRECTION ARROW LOADING DIRECTION ARROW POLARIZATION NOTCH PT-1-24-09F-109 (SEE TABLE 2) PT-1-24-05-17 (SEE TABLE 2) FIG 15 FIG 16 PT-1-24-05-17 POLARIZATION NOTCH PT-1-24-09F-109 F:\DWG\MISC\MKTG\TFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. NOTE: 1. PARTS TO BE PACKAGED WITH THE LOADING DIRECTION ARROW POINTED IN SAME DIRECTION AS THE ARROW ON TUBE. 2. A PART WITH -SA OPTION WILL USE THE SAME TUBE AS THE CORRESPONDING PART WITH THE -A OPTION DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 TERMINAL STRIP TFM-1XX-XX-XXX-D-XXX BY: garyp 11/5/2014 SHEET 6 OF 7 REVISION FQ ROUND HOLES LOADING DIRECTION ARROW PAD NOTCH PART NOTCH POLARIZATION NOTCH PT-FTSH002-DV-A-P-M (SEE TABLE 2) OBLONG HOLES USER DIRECTION OF UN-REELING POCKET NOT DETAILED FIG 17 FIG 4 PT-FTSH002-DV-A-P-M -TR: TAPE AND REEL (SEE NOTE 14) F:\DWG\MISC\MKTG\TFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .050 X .050 TERMINAL STRIP TFM-1XX-XX-XXX-D-XXX BY: garyp 11/5/2014 SHEET 7 OF 7
TFM-130-02-L-D-DS
PDF文档包含了详细的技术规格和设计信息,但未明确列出“物料型号”、“器件简介”、“引脚分配”、“参数特性”、“功能详解”和“应用信息”等部分。
文档主要包含以下内容:
1. 多种引脚样式的详细机械尺寸和公差。
2. 不同选项的描述,例如-A(对齐销)、-LC(锁定夹)、-P(拾取和放置垫)、-RA(直角)、-TR(胶带和卷轴)等。
3. 电镀规格,例如选择性金和锡尾。
4. 包装信息,包括卷轴和管的规格。
5. 专有权利声明,强调文档包含机密和专有信息。
如果需要更具体的信息,请提供更明确的查询或文档中的特定部分。
TFM-130-02-L-D-DS 价格&库存
很抱歉,暂时无法提供与“TFM-130-02-L-D-DS”相匹配的价格&库存,您可以联系我们找货
