UB-MC5BR3-SDWP604-4S-TF
    JST
    SMD
    线对板针座 SMT
UB-MC5BR3-SDWP604-4S-TF 数据手册
UB CONNECTOR Micro USB Emboss Tape USB (Universal Serial bus) Conforming Connector (Waterproof) Specifications This connector is an interface connector for cellular phone and mobile equipment conforming to Micro USB (Universal Serial Bus) Standard that is grade 7 ingress protection of JIS C 0920 (IPX7 of IEC 60529). *Grade 7 ingress protection of JIS C 0920 (IPX7 of IEC 60529) : Leave it at a depth of 1 m for 30 minutes. ● Waterproof performance ● Assuring 10,000 cycles insertion and withdrawal as durability ● Strong structure which welded to caulking part by laser welding ● SMT configuration • Current rating : When using only signal line Signal line (when using the contacts from No.2 to 4.) : 1.0 A/Line AC/DC When using power supple line Power supply line (when using the contacts No.1 and 5.) : 1.8 A/Line AC/DC Signal line (when using the contacts from No.2 to 4.) : 0.5 A/Line AC/DC • Voltage rating: 30 V AC/DC • Temperature range: -30℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 30 mΩ max. After environmental tests/ 50 mΩ max. (variation from initial value) • Insulation resistance: 1,000 M Ω min. • Withstanding voltage: 100 VAC/minute * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Receptacle Model No. Standard B Type TID No.: 60002098 Material and Finish Contact: Copper alloy, nickel-undercoated, gold-plated Housing: Heat resisting resin, UL94V-0, black 9.2 UB-MC5BR3-SDWP604-4S 8.54 6.9 5.5 Shell: SUS, nickel-undercoated, tin-plated Shell cover: Copper alloy, nickel-undercoated, tin-plated Cap: Heat resisting resin, UL94V-0, black Outer seal: Silicone rubber, black 1.85 3.4 Sealant: Cured resin Circuit No.1 9.94 6.7 4.3 ±0.05 2.6 ±0.05 0.65 ±0.03 1.2 ±0.05 0.9±0.05 Shell cover 1.3 ±0.05 Shell ±0.05 Shell (0.45) 0.35 ±0.05 1.05 ±0.05 (1.65) (2.15) 0.9±0.05 1.85±0.05 φ0.85 0.9±0.05 2 ±0.05 2±0.05 3.95 0.4 ±0.05 6.8±0.05 7.9±0.05 10.5±0.05 1 Q'ty/reel: 1,500 RoHS2 compliance
UB-MC5BR3-SDWP604-4S-TF 价格&库存
很抱歉,暂时无法提供与“UB-MC5BR3-SDWP604-4S-TF”相匹配的价格&库存,您可以联系我们找货
  • 1+17.04746
  • 375+16.70380
  • 750+16.37056
库存:25
  • 1+23.138481+2.99090
  • 10+19.6287410+2.53723
  • 25+18.3980325+2.37814
  • 50+17.5186250+2.26447
  • 100+16.68160100+2.15628
  • 250+15.63683250+2.02123
  • 500+14.89036500+1.92474
库存:6233
  • 1+21.243131+2.74590
  • 3+17.658903+2.28260
  • 10+15.5608210+2.01140
  • 25+14.3369325+1.85320
  • 35+13.9872535+1.80800
  • 50+13.7249950+1.77410
  • 100+13.11305100+1.69500
  • 250+12.58853250+1.62720
  • 1500+11.801741500+1.52550
库存:53304
    • 1+18.821591+2.43289
    • 10+14.4768010+1.87128
    • 50+10.0620850+1.30063
    • 100+9.51133100+1.22944
    • 500+9.14417500+1.18198
    • 1000+9.074231000+1.17294
    • 2000+9.013042000+1.16503
    库存:1183
