1825
1825
    ADAFRUIT
    HEX STANDOFF 6-32 ALUM 2-1/2"
1825 数据手册
USB DIY Slim Connector Shell - Mini-B Plug PRODUCT ID: 1825 DESCRIPTION - Make your own USB connections without slicing apart a USB cable and soldering those thin wires inside. This is the 'slim' version of the DIY Mini-B Male Plug connector. It's a little more elegant because instead of snapping two pieces together the connector press-fits into the overmolding for a modern look. We also carry the slim size in USB-A male, microB male, and USB-microB female. Normal DIY "USB shells" are available in USB A plug, micro B, mini B and USB A socket. Each shell comes with a plastic shell and a proper connector with easy-to-solder tabs. http://www.adafruit.com/products/1825 10/5/2015 Technical Details Assembled Dimensions: 26mm x 10mm x 7mm / 1" x 0.4" x 0.3" Assembled Weight: 1.24g Micro USB Connector Dimensions: 14mm x 7mm x 3mm / 0.6" x 0.3" x 0.1" Micro USB Connector Weight: 0.6g
很抱歉,暂时无法提供与“1825”相匹配的价格&库存,您可以联系我们找货
  • 1+8.377201+1.08585
