2. 5
TOLERANCE UNLESS OTHERWISE
SPECIFIED IN MM:
0.0
± 0.38
ANGLE ±3°
0.00
± 0.25
0.000
± 0.13
5
4.50
4.30
A1
2
SEPT.15/2015
DIMS UPDATE
C.B OCT.11/2016
3
PLATING OPTIONS UPDATE
C.B APR.12/2017
4
3.80
0.90
16.33
6.00
1
11.53
5.00 OD
4
3
8.28
7.44
6.4
5.4
6.65
R2.2
R2.2
1.20
44°
44°
4.50 OD
2
8.25
B1
A1
24.08
NOTES:
1. SPECIFICATIONS
1.1 Voltage:
1.2 Current Rating:
1.30
B12
8.55
2.40
6.83
A12
4.40
8.08
4.68
0.80
8.25
1.57
1.30
2.64
9.52
1
B1
8.60
13.50
ORIGINAL
REDRAWN
R.STA.MONICA
A12
B12
11.71
16.00
ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
30 V AC (RMS)
3.0A for Vbus and corresponding GND
0.25A for all other contacts
1.3 Contact Resistance: 30 Milliohms Max. for Vbus and GND
50 Milliohms Max. for all other contacts
1.4 Insulation Resistance: 100 Megohms Min.
1.5 Dielectric Withstanding Voltage: 100V AC/Minute
1.6 Total Mating Force: 5N~20N at 12.5mm/sec. Max.
1.7 Total Unmating Force: 8N~20N at 12.5mm/sec. Max.
1.8 Operating Temperature: -55°C to +85°C
2. MATERIAL:
2.1 Housing:
Thermoplastic, UL 94V-0, Black Color
2.2 Shell:
Stainless Steel all over Nickel Plating
2.3 Contact:
Copper Alloy with Gold Plating
on Contact Area , all over Nickel Plating
2.4 GND Latch:
Tab with Lead Free Tin Alloy
2.5 Back Shell:
3. PART NUMBER:
690-024-260-900 for Gold flash plating
690-024-360-900 for 15µ” Gold
ACAD REFERENCE NO.: 690-024-260-900
USB 3.1 TYPE C TO 2.0 PLUG CONNECTOR
DRAWN: R.STA.MONICA
DATE: SEPT.15/2015
CHECKED:
DATE:
PART NUMBER
THIS SERIES FULLY CONFORMS TO THE
EUROPEAN UNION DIRECTIVES
COMPLIANT 2011/65/EU FOR RoHS COMPLIANCY.
EDAC INC
TORONTO, ONTARIO
CANADA
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
SEE DRAWING
DRAWING NUMBER
690-024-260-900
SHEET 1 OF 1
ISSUE
4
很抱歉,暂时无法提供与“690-024-360-900”相匹配的价格&库存,您可以联系我们找货
