HDMR-19-01-F-SM-PF
HDMR-19-01-F-SM-PF
    SAMTEC(申泰)
    SMD,P=0.5mm,卧贴
    HDMI连接器 19Pin SMD,P=0.5mm,卧贴
HDMR-19-01-F-SM-PF 数据手册
REVISION AI DO NOT SCALE FROM THIS PRINT NOTES: (SEE NOTE 4) DESIGNED & DIMENSIONED 1. C REPRESENTS A CRITICAL DIMENSION. IN MILLIMETERS[INCHES] HDMR-XX-XX-X-XX-XX-XX 2. PARTS SHALL BE ROHS COMPLIANT. 3. PARTS TO BE PACKAGED IN TRAYS, TAIL SIDE DOWN. PACKAGING (LESS THAN FULL TRAY QUANTITIES ARE TO BE PACKAGED IN BLANK: TRAY (SEE NOTES 3 & 6) No OF POSITIONS COVERED TRAYS TRIMMED TO MATCH QUANTITY ORDERED) -TR: TAPE & REEL (SEE NOTES 6 & 7) 4. HDMR FORMERLY NAMED HDMI. -19: (SEE SHT 1, FIG. 1) (ONLY AVAILABLE WITHOUT -PF OPTION) 5. DIMENSION APPLIES TO CONTACT & SHIELD. -29: (SEE SHT 4) -FR: FULL REEL QTY TAPE & REEL 6. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING (SEE NOTES 6 & 7) EFFICIENCY STANDARDS (SPES ) FOUND ON WWW.SAMTEC.COM. SHIELD TAIL STYLE 7. ATTACH LABEL TO EACH REEL. (ONLY AVAILABLE WITHOUT -PF OPTION) -01: THROUGH HOLE -02: SURFACE MOUNT C1 OPTION (SEE SHT 3, FIG 2)(-19 POS ONLY) 13.90 .547 -PF: PANEL FLANGE (SEE SHT 3, FIG. 4) -L: LOCKING OPTION(ONLY AVAILABLE 9.00 .354 C28 C2 C8 PLATING ON HDMR-19-01-X-TH-PF-L, SEE SHT 3, FIG 5 0.50±0.05 .020±.002 0.25±0.10 .010±.004 & HDMR-29-01-X-TH-PF-L, SEE SHT 4 FIG 8) (-19 POSITION) -S: CONTACT AREA: .000030" GOLD 0.10 A TAILS: .BRIGHT ACID TIN SHELL: NICKEL LEAD TERMINATION -F: CONTACT AREA: .000001" GOLD -SM: SURFACE MOUNT TAILS: BRIGHT ACID TIN 0.15 .006 -TH: THROUGH HOLE (ONLY AVAILABLE SHELL: NICKEL ON HDMR-19-01-X-TH-PF-L)(SEE SHT 3, FIG 3) (-29 POSITION) -S: CONTACT AREA: .000030" GOLD TAILS: BRIGHT ACID TIN "A" SHELL: NICKEL -F: CONTACT AREA: .000001" GOLD TAILS: BRIGHT ACID TIN SHELL: NICKEL 15.00 .591 C3 0.50 .020 9.00 .354 10.80±0.10 .425±.004 +.002 14.00+-0.05 0.04 .551 - .002 19 'C' "B" "D" "A" -A- 01 "A" "B" C7 +.002 4.55+-0.05 0.04 .179 - .002 6.18 .243 2.2 .09 C6 18 02 "D" 8.00 .315 0.50 .020 0.10 A 14.50±0.08 .571±.003 C5 +.004 12.05+0.10 0.00 .475 - .000 9.85+0.10 0.00 1.20 .047 .388+-.004 .000 FIG 1 HDMR-19-01-X-SM SHOWN F:\dwg\misc\mktg\HDMR-XX-XX-X-XX-XX-XX-MKT.SLDDRW .X: 0.25[.010] .XX: 0.20[.008] .XXX: ±0.10[.004] MATERIAL: ANGLES 1 "B" 4.60 .181 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM. TOLERANCES ARE: DECIMALS +.002 9.40+-0.05 0.10 .370 - .004 2.00 .079 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:0.333333 INSULATOR: HIGH TEMP THERMOPLASTIC (UL94V-0) CONTACT: COPPER ALLOY SHELL: NICKEL PLATED BRASS 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: HDMI RECEPTACLE DWG. NO. HDMR-XX-XX-X-XX-XX-XX BY: B. PERRY 9/14/07 SHEET 1 OF 4 REVISION AI 0.50 .020 +.004 0.50+-0.10 0.05 .020 - .002 4.16±0.15 .164±.006 'F' 4.16±0.15 .164±.006 0.06±0.03 .002±.001 DETAIL 'C' SCALE 6 : 1 0.50 .020 REF SECTION "B"-"B" SCALE 3 : 1 SECTION "A"-"A" SCALE 3 : 1 4.80±0.10 .189±.004 6.80±0.20 .268±.008 1.00±0.10 .039±.004 3.4 .13 'E' 0.90±0.05 .035±.002 C27 +.004 0.35+-0.10 0.05 .014 - .002 DETAIL 'E' SCALE 6 : 1 DETAIL 'F' SCALE 6 : 1 3.10 .122 SECTION "D"-"D" SCALE 3 : 1 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:0.333333 F:\dwg\misc\mktg\HDMR-XX-XX-X-XX-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: HDMI RECEPTACLE DWG. NO. HDMR-XX-XX-X-XX-XX-XX BY: B. PERRY 9/14/07 SHEET 2 OF 4 REVISION AI FIG 3 -TH LEAD TERMINATION STYLE (ONLY AVAILABLE ON HDMR-19-01-X-TH-PF-L) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)) FIG 2 -02 SHIELD TAIL STYLE (HDMR-19-02-X-SM SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)) 0.35 .014 1.60 .063 C9 C15 1.20 .047 C10 2.80±0.15 .110±.006 9.00 .354 17.20 .677 9.00 .354 0.76 .030 C14 0.80±0.13 .031±.005 0.50±0.08 .020±.003 C16 C13 FIG 5 -L: LOCKING LEADS (ONLY AVAILABLE ON HDMR-19-01-X-TH-PF-L) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1)) 7.50 .295 CL C11 M3 X 0.5 THREAD 1.50 .059 REF C12 9.975 .393 7.20 .283 REF 2.50 .098 REF 16.01 .630 0.90 .035 REF 13.10 .516 REF CL OF OUTSIDE OF SHELL * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\dwg\misc\mktg\HDMR-XX-XX-X-XX-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: HDMI RECEPTACLE DWG. NO. HDMR-XX-XX-X-XX-XX-XX BY: B. PERRY 9/14/07 SHEET 3 OF 4 REVISION AI C18 14.00±0.25 .551±.010 C17 C29 0.500 .0197 0.20 .008 FIG 6 HDMR-29-01-X-SM SHOWN 12.160 .4787 22.300 .8780 21.300 .8386 14.00±0.25 .551±.010 29 01 C23 4.550 .1791 28 6.200 .2441 2.100 .0827 02 13.00±0.25 .512±.010 0.50 .020 21.800±0.10 .8583±.004 C20 C19 C22 4.700 .1850 2.000 .0787 1.000 .0394 5.900 .2323 CL C21 7.50 .295 * =NOT RELEASED FIG 7 HDMR-29-01-X-SM-PF SHOWN (DIFFERENT AS SHOWN, OTHERWISES SAME AS FIG 6) 7.20 .283 REF 16.050 .632 15.00 .590 C25 CL M3 X 0.5 THREAD C26 2.60±0.15 .102±.006 FIG 8 HDMR-29-01-X-TH-PF-L SHOWN * (DIFFERENT AS SHOWN, OTHERWISES SAME AS FIG 3) 14.00 .551 C24 16.650 .6555 9.976 .393 CL OF OUTSIDE OF SHELL 7.20 .284 REF C27 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\dwg\misc\mktg\HDMR-XX-XX-X-XX-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: HDMI RECEPTACLE DWG. NO. HDMR-XX-XX-X-XX-XX-XX BY: B. PERRY 9/14/07 SHEET 4 OF 4
HDMR-19-01-F-SM-PF 价格&库存
很抱歉,暂时无法提供与“HDMR-19-01-F-SM-PF”相匹配的价格&库存,您可以联系我们找货
