GBC28DRTI-S93
GBC28DRTI-S93
    SULLINS
    CONN EDGECARD 56POS DIP .100 SLD
GBC28DRTI-S93 数据手册
Female Card Edge .100” [2.54 mm] Contact Centers, .431” [10.95 mm] Insulator Height, Dip Solder/Eyelet/Right Angle for .093” [2.36 mm] Mating PCB Sullins Female Card Edge SPECIFICATIONS • • • • • • Accommodates .093” ± .008” [2.36 mm ± 0.20 mm] PC board PBT, PPS, PA9T, or PEEK insulator Molded-in key available 3 Amps current rating for one contact energized 30 milli Ohms maximum at rated current UL Flammability Rating: 94V-0 READOUT .265"[6.73]INSERTION DEPTH FULL BELLOWS BACK-UP SPRING LETTER 'A' SIDE HALF LOADED (H) DUAL (D) TERMINATION TYPE .125” [3.18] .185” [4.70] EYELET ACCEPTS 3-#26 AWG .050” [1.27] .225” [5.72] .200” [5.08] (RT) .440” [11.19] (RY) LETTER B SIDE FITS Ø.043” [1.09] .007” [0.18] THICK .156” [3.96] NARROW DIP SOLDER (RT,RY) RIGHT ANGLE (RA) EYELET (RE) FITS Ø.043” [1.09] .200” [5.08] MOUNTING STYLE Ø.125” [3.18] #4-40 Ø.116” [2.95] CLEARANCE FOR #4 SCREW Ø.125” [3.18] .135” [3.43] CLEARANCE HOLE (H) 48 THREADED INSERT ( I ) FLOATING BOBBIN (F) NO MOUNTING EARS (N) SIDE MOUNTING (S) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .100” [2.54 mm] Contact Centers, .431” [10.95 mm] Insulator Height, Dip Solder/Eyelet/Right Angle for .093” [2.36 mm] Mating PCB PART NUMBER OPTIONS E B C 43 D RE H - S93 MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze (Standard) R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper *F = PPS/Spinodal (Overall Gold Plating Only) Consult Factory for Special Soldering Guidelines *C = PPS/Beryllium Nickel (Overall Gold Plating Only) *W = PEEK/Beryllium Nickel (Overall Gold Plating Only) *Consult factory for availability. Refer to Page 7 for Operating/Processing Temperatures MOUNTING STYLE (Opposite Page) H = .125” [3.18 mm] Clearance Holes N = No Mounting S = Side Mounting I = Threaded Insert F = Floating Bobbin TERMINATION TYPE (Opposite Page) RA = Right Angle RE = Eyelet RT = .200” [5.08 mm] X .200” [5.08 mm] Dip Solder RY = .200” [5.08 mm] X .440” [11.19 mm] Dip Solder CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface .000010” Gold .000030” Gold .000010” Gold .000030” Gold Contact Surface S = .000010” Gold M = .000030” Gold E = .000100” Pure Tin, Matte B C G Y = = = = Sullins Female Card Edge MODIFICATION (Consult Factory) -S93 = .093” ± .008” [2.36 mm ± 0.20 mm] PCB, .200” [5.08 mm] Row Spacing (RT, RY) Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold .000005” Gold Overall Plating .000010” Gold .000010” Gold .000100” Pure Tin, Matte READOUT (Opposite Page) D = Dual H = Half Loaded NUMBER OF CONTACT POSITIONS See Chart Below CONTACT CENTERS C = .100” [2.54 mm] DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. .265 [6.73]INSERTION DEPTH B A C REFER TO MOUNTING STYLE F .025 [0.64] .100 [2.54] D E CONTACT MARKINGS B 1 2 3 ... 58 59 60 B A 1 2 3 ... 58 59 60 A .431 [10.95] B 1 2 59 60 B A 1 2 59 60 A .245 [6.22] REFER TO TERMINATION TYPE Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. POSITIONS/ CONTACTS 04/08* 05/10 06/12 07/14 08/16 10/20 12/24 13/26 15/30 17/34 18/36 19/38 20/40 22/44 23/46* 25/50 26/52 28/56 30/60 31/62 35/70 36/72 40/80 43/86 44/88 49/98 50/100 52/104* 60/120 65/125 INCHES MILLIMETERS A±.008 B±.008 C±.015 D±.010 E±.020 0.300 0.400 0.500 0.600 0.700 0.900 1.100 1.200 1.400 1.600 1.700 1.800 1.900 2.100 2.200 2.400 2.500 2.700 2.900 3.000 3.400 3.500 3.900 4.200 4.300 4.800 4.900 5.100 5.900 6.400 0.500 0.600 0.700 0.800 0.900 1.100 1.300 1.400 1.600 1.800 1.900 2.000 2.100 2.300 2.400 2.600 2.700 2.900 3.100 3.200 3.600 3.700 4.100 4.400 4.500 5.000 5.100 5.300 6.100 6.600 0.675 0.775 0.875 0.975 1.075 1.275 1.475 1.575 1.775 1.975 2.075 2.175 2.275 2.475 2.575 2.775 2.875 3.075 3.275 3.375 3.775 3.875 4.275 4.575 4.675 5.175 5.275 5.475 6.275 6.775 0.975 1.075 1.175 1.275 1.375 1.575 1.775 1.875 2.075 2.275 2.375 2.475 2.575 2.775 2.875 3.075 3.175 3.375 3.575 3.675 4.075 4.175 4.575 4.875 4.975 5.475 5.575 5.775 6.575 7.075 1.275 1.375 1.475 1.575 1.675 1.875 2.075 2.175 2.375 2.575 2.675 2.775 2.875 3.075 3.175 3.375 3.475 3.675 3.875 3.975 4.375 4.475 4.875 5.175 5.275 5.775 5.875 6.075 6.875 7.375 F+.005/-.015 0.330 0.400 A±0.20 B±0.20 C±0.38 D±0.25 E±0.51 7.62 10.16 12.70 15.24 17.78 22.86 27.94 30.48 35.56 40.64 43.18 45.72 48.26 53.34 55.88 60.96 63.50 68.58 73.66 76.20 86.36 88.90 99.06 106.68 109.22 121.92 124.46 129.54 149.86 162.56 12.70 15.24 17.78 20.32 22.86 27.94 33.02 35.56 40.64 45.72 48.26 50.80 53.34 58.42 60.96 66.04 68.58 73.66 78.74 81.28 91.44 93.98 104.14 111.76 114.30 127.00 129.54 134.62 154.94 167.64 17.15 19.69 22.23 24.77 27.31 32.39 37.47 40.01 45.09 50.17 52.71 55.25 57.79 62.87 65.41 70.49 73.03 78.11 83.19 85.73 95.89 98.43 108.59 116.21 118.75 131.45 133.99 139.07 159.39 172.09 24.77 27.31 29.85 32.39 34.93 40.01 45.09 47.63 52.71 57.79 60.33 62.87 65.41 70.49 73.03 78.11 80.65 85.73 90.81 93.35 103.51 106.05 116.21 123.83 126.37 139.07 141.61 146.69 167.01 179.71 32.39 34.93 37.47 40.01 42.55 47.63 52.71 55.25 60.33 65.41 67.95 70.49 73.03 78.11 80.65 85.73 88.27 93.35 98.43 100.97 111.13 113.67 123.83 131.45 133.99 146.69 149.23 154.31 174.63 187.33 F+0.13/-0.38 8.38 10.16 * Consult factory for availability. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 49
GBC28DRTI-S93
1. 物料型号:文档中没有明确指出具体的物料型号,但提供了一种Female Card Edge连接器的详细信息。
2. 器件简介:文档描述了Sullins品牌的Female Card Edge连接器,具有.100” [2.54 mm]接触中心间距和.431” [10.95 mm]的绝缘体高度。该连接器适用于.093” [2.36 mm]的PCB板,有多种材料选项,包括PBT、PPS、PA9T或PEEK绝缘体,并可提供成型键。
3. 引脚分配:文档提供了详细的引脚分配信息,包括不同配置下的引脚位置和尺寸,如“DUAL (D)”、“HALF LOADED (H)”等。
4. 参数特性:连接器的参数特性包括3安培的电流额定值,最大30毫欧姆的电阻,以及UL 94V-0的阻燃等级。
5. 功能详解:文档中没有提供具体的功能详解,但根据规格和配置选项,可以推断该连接器适用于需要高密度和高性能电气连接的应用。
6. 应用信息:文档没有明确列出具体的应用领域,但根据其特性,Female Card Edge连接器可能适用于多种电子设备和系统中的PCB连接。
7. 封装信息:文档提供了连接器的封装信息,包括插入深度、背部弹簧、全钟形等结构细节,以及不同安装风格和终止类型(如Eyelet、Right Angle、Dip Solder)的选项。
GBC28DRTI-S93 价格&库存
很抱歉,暂时无法提供与“GBC28DRTI-S93”相匹配的价格&库存,您可以联系我们找货
