1.30279.0010707
1.30279.0010707
    RAFI
    RND USB FEED THRO PLASTIC GREY
1.30279.0010707 数据手册
21.01.2015 RAFIX 22 FS+ - USB feedthrough, round collar 1.30.279.001/0707 General information Form of lens Color of lens Color of front ring Form of collar flat lens opaque slate-grey slate-grey round Dimensions Dimensions of collar Overall height Mounting depth Mounting hole Key grid Diameter of collar ø 29.8 mm 11.3 mm 27,7 mm 22.3 mm 30 x 30 mm 29.8 mm Mechanical design Mounting Front connection Rear connection Torque for nut ring ring nut USB Type A USB Type B 1.2 Nm Other specifications Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Operating life Degree of protection from front side -25 °C +70 °C -40 °C +80 °C 1500 operations cycle IP65 (DIN EN 60529) with closed sealing cap Relative humidity Shock resistance to IEC 60068-2-27 (EN 61131-2) Vibration resistance according to IEC 600 68-2-6 (EN 61131-2) ROHS compliant REACH compliant 5 bis 95% (non condensed) 50 g at 11 ms half sine amplitude 5 g at 10...500 Hz yes yes Technical data are approximate and intended solely for general orientation in the selection of a product. Subject to modifications and errors. Images and other graphics may only be similar. For more information, refer to www.rafi.de chapter Imprint / Data Protection. 21.01.2015 Panel cut-out to IEC 60947-5-1 Technical data are approximate and intended solely for general orientation in the selection of a product. Subject to modifications and errors. Images and other graphics may only be similar. For more information, refer to www.rafi.de chapter Imprint / Data Protection.
1.30279.0010707 价格&库存
很抱歉,暂时无法提供与“1.30279.0010707”相匹配的价格&库存,您可以联系我们找货
