1.30259.0210700
1.30259.0210700
    RAFI
    RND USB FEED THRO PLAST CHROMIN
1.30259.0210700 数据手册
Data Sheet 1.30.259 USB Feedthrough RAFIX 22 FS Sealing cap closed: Degree of protection IP 65 USB Type A port on front USB Type B port on rear Rugged USB feedthroughs for 22.3 mm mounting A sealing cap protects the slot and ensures a hole diameter matching the RAFIX 22 FS and degree of protection to IP 65. For assembly, simply RAFIX 22 QR actuator series. insert the feedthrough from the front side into the The USB feedthrough provides sturdy installation of mounting hole and fasten it by means of a ring nut an easily accessible USB slot in front panels of from the rear. The depth behind panel is 27.7 mm. controllers and IPCs and can be used, for example, The colour of the front ring can be freely selected so to connect a keyboard for maintenance purposes or that the USB feedthrough can be matched in a USB stick for a software update. The port on the appearance to the customer-specific design. rear accommodates commercially available USB cables of varying lengths with B-type connector. Mounting dimensions Cut-out Cut-out Data Sheet 1.30.259 USB Feedthrough RAFIX 22 FS Preliminary specifications Max. operating temperature: Min. operating temperature: Max. storage temperature: Min. storage temperature: +70 °C -25 °C +80 °C -40 °C Relative humidity: IP protection (front): 5 to 95% (non-condensing) IP 65 (with sealing cap closed) Shock resistance to IEC 60068-2-27 (EN 61131-2): Vibration resistance to IEC 600 68-2-6 (EN61131-2): Environmental resistance: 50 g at 11 ms amplitude, half sinusoidal 5 g at 10...500 Hz acc. to IEC 60068-2-14 and -30 Operating life: 1.500 plugging cycles Approvals: UL 508 Order numbers Collar shape Round Round Front ring Plastic slate grey Chromium-plated Order no. 1.30.259.001/0707 1.30.259.021/0700 Square Square Plastic slate grey Chromium-plated 1.30.259.051/0707 1.30.259.071/0700 Rev.: 08/06/2011 Preliminary technical data, subject to modification. 3D data in step or igs format available on request. RAFI GmbH & Co. KG Ravensburger Str. 128-134, D-88276 Berg/Ravensburg, Germany Tel.: +49 751 89-0, Fax: +49 751 89-1300 www.rafi.de, info@rafi.de
1.30259.0210700 价格&库存
很抱歉,暂时无法提供与“1.30259.0210700”相匹配的价格&库存,您可以联系我们找货
