DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
REVISION E
DCA-17-XX
STYLE
-01: PANEL MOUNT DUST CAP
-02: CABLE DUST CAP
-03: USB FLASH DRIVE COVER
16.35 .644
REF
1.20 .047 REF
(SEE NOTE 3)
39.51 1.556 REF
DO NOT
SCALE FROM
THIS PRINT
DCFS-17-01
7.50 .295 REF
DC-17-01
125.00 4.921 REF
FIG 1
DCA-17-01 SHOWN
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. VENDOR TO ASSEMBLE PARTS.
3. COMPONENTS MUST BE PRESSED DOWN BELOW SNAPS.
4. DCA-17-03 WILL ACCOMODATE USB DEVICE WITH DIMENSIONS 80.00mm X
13.30mm X 20.25mm.
5. TORQUE SPECIFICATION FOR SCN-17-04 IS 12 IN-LB.
6. MIN BEND RADIUS: 6.00 [.24]
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
ANGLES
.X: 0.3 [.01]
2
.XX: 0.13 [.005]
.XXX: 0.051 [.0020]
MATERIAL:
STRAP: LDPE
CAP: PA66
O-RING: SILICONE
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
F:\DWG\MISC\MKTG\DCA-17-XX-MKT.SLDDRW
SHEET SCALE: 1:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
DWG. NO.
DUST CAP ASSEMBLY
DCA-17-XX
BY: CHAD F
11/22/2004
SHEET 1 OF 3
REVISION E
16.80 .661
REF
(SEE NOTE 3)
39.50 1.555 REF
DCFS-17-01
DC-17-02
FIG 2
DCA-17-02 SHOWN
(SAME AS FIG 1, UNLESS OTHERWISE STATED)
OR-17-01
PROPRIETARY NOTE
SHEET SCALE: 1:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
DUST CAP ASSEMBLY
DCA-17-XX
BY: CHAD F
11/22/2004
SHEET 2 OF 3
REVISION E
(SEE NOTE 5)
(SEE NOTE 3)
98.70 3.886 REF
DC-17-03
SCN-17-04
DCFS-17-01
FIG 3
DCA-17-03 SHOWN
PROPRIETARY NOTE
SHEET SCALE: 1:2
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
DUST CAP ASSEMBLY
DCA-17-XX
BY: CHAD F
11/22/2004
SHEET 3 OF 3
很抱歉,暂时无法提供与“DCA-17-03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+38.675101+5.02593
- 50+32.6681050+4.24531
- 100+26.53530100+3.44833
- 500+18.89716500+2.45574
