ECA30DSSN-S288
ECA30DSSN-S288
    SULLINS
    CONNEDGEDUALFMALE60POS0.125
ECA30DSSN-S288 数据手册
8 7 4 5 6 2 3 1 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2899 INITIAL RELEASE 1/17/2014 JHSU E F F D FIRST POSITION INDICATOR B PRELIMINARY A 2X .125 3.18 THRU .075 1.91 SEE NOTE 13 E E .370 C A +.005 +0.13 9.40 - .015 - 0.38 .030 0.77 D D .180 4.57 .550 13.97 .250 6.35 .020 0.51 .300 7.62 INSERTION DEPTH .235±.025 5.97±0.64 .025 0.63 ACCEPTS .062" PCB .125 3.18 TYP A C SECTION A-A C F _ _A_ _DSSH-S288 CONTACT MARKINGS 1 3 5 ... 45 47... 99 2 4 6 ... 46 48... 100 B B CONTACT ID NOTES: SCALE 4:1 1. INSULATOR MATERIAL: SEE PART NUMBER CODING CONTACTS NOT 2. CONTACT MATERIAL: SEE PART NUMBER CODING SHOWN FOR CLARITY 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 750 VAC MINIMUM AT SEA LEVEL. 8. CONTACT RATING: 3 AMP DRAWN DATE NAME 9. CONTACT RESISTANCE: 30 MILLI OHM MAX UNLESS OTHERWISE SPECIFIED: 6/24/2011 JH 10. INSULATION RESISTANCE: 5000 MEGA OHM MIN DIMENSIONS ARE IN INCHES [MM] 11. DURABILITY: 500 CYCLES MIN TITLE TOLERANCES: ANGULAR: 30' 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE EDGECARD .125" PITCH, HP .XX= .02 [.5] .XXX= .005 [.13] 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] PART NUMBER .XXXX= .0005 [.013] _ _A_ _DSS_-S288 14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062" TEST BLADE. CAGE CODE DWG. NO. SIZE INTERPRET DIMENSIONS AND 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062" PCB TOLERANCING C 54453 C12338 16. MODIFICATION: CARD EXTENDER BEND FOR .062" PCB PER: ASME Y14.5M-2009 RoHS COMPLIANT CUSTOMER COPY A Pb THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. SCALE: 2:1 8 7 6 5 4 3 2 A REV A SHEET 1 OF 3 1 FILE NAME: C12338, _ _A_ _DSS_-S288 8 7 4 5 6 2 3 1 F F E E D 2X C .125 3.18 THRU 2X .245 6.22 _ _A_ _DSSS-S288 _ _A_ _DSSN-S288 D D A 2X .095 2.41 D 2X #4-40 THREADED INSERTS C C L±.015 (L= DIM 'A' + .190[4.83]) B B _ _A_ _DSSB-S288 _ _A_ _DSSI-S288 CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 DATE NAME 6/24/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER _ _A_ _DSS_-S288 SIZE CAGE CODE C 54453 SCALE: 1.5:1 3 2 A EDGECARD .125" PITCH, HP DWG. NO. REV C12338 A SHEET 2 OF 3 1 FILE NAME: C12338, _ _A_ _DSS_-S288 8 PART NUMBER F E D _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _A06DSS_-S288 _A10DSS_-S288 _A14DSS_-S288 _A15DSS_-S288 _A18DSS_-S288 _A22DSS_-S288 _A24DSS_-S288 _A25DSS_-S288 _A28DSS_-S288 _A30DSS_-S288 _A31DSS_-S288 _A32DSS_-S288 _A35DSS_-S288 _A36DSS_-S288 _A40DSS_-S288 _A43DSS_-S288 _A44DSS_-S288 _A49DSS_-S288 _A50DSS_-S288 7 4 5 6 2 3 A±.008[0.20] B±.008[0.20] C±.015[0.38] D±.010[0.25] E±.020[0.51] F±.015[0.38] INCH 0.625 1.125 1.625 1.750 2.125 2.625 2.875 3.000 3.375 3.625 3.750 3.875 4.250 4.375 4.875 5.250 5.375 6.000 6.125 INCH 0.875 1.375 1.875 2.000 2.375 2.875 3.125 3.250 3.625 3.875 4.000 4.125 4.500 4.625 5.125 5.500 5.625 6.250 6.375 INCH 1.035 1.535 2.035 2.160 2.535 3.035 3.285 3.410 3.785 4.035 4.160 4.285 4.660 4.785 5.285 5.660 5.785 6.410 6.535 INCH 1.295 1.795 2.295 2.420 2.795 3.295 3.545 3.670 4.045 4.295 4.420 4.545 4.920 5.045 5.545 5.920 6.045 6.670 6.795 INCH 1.555 2.055 2.555 2.680 3.055 3.555 3.805 3.930 4.305 4.555 4.680 4.805 5.180 5.305 5.805 6.180 6.305 6.930 7.055 INCH 0.875 1.375 1.875 2.000 2.375 2.875 3.125 3.250 3.625 3.875 4.000 4.125 4.500 4.625 5.125 5.500 5.625 6.250 6.375 MM 15.88 28.58 41.28 44.45 53.98 66.68 73.03 76.20 85.73 92.08 95.25 98.43 107.95 111.13 123.83 133.35 136.53 152.40 155.58 MM 22.23 34.93 47.63 50.80 60.33 73.03 79.38 82.55 92.08 98.43 101.60 104.78 114.30 117.48 130.18 139.70 142.88 158.75 161.93 MM 26.29 38.99 51.69 54.86 64.39 77.09 83.44 86.61 96.14 102.49 105.66 108.84 118.36 121.54 134.24 143.76 146.94 162.81 165.99 MM 32.89 45.59 58.29 61.47 70.99 83.69 90.04 93.22 102.74 109.09 112.27 115.44 124.97 128.14 140.84 150.37 153.54 169.42 172.59 MM 39.50 52.20 64.90 68.07 77.60 90.30 96.65 99.82 109.35 115.70 118.87 122.05 131.57 134.75 147.45 156.97 160.15 176.02 179.20 1 MM 22.23 34.93 47.63 50.80 60.33 73.03 79.38 82.55 92.08 98.43 101.60 104.78 114.30 117.48 130.18 139.70 142.88 158.75 161.93 F E D PART NUMBER CODING _ _ A_ _DSS _ - S288 C MATERIALS (INSULATOR / CONTACT) MOUNTING STYLE E = PBT/PHOSPHOR BRONZE H= .125" DIA. CLEARANCE HOLES (PAGE 1) OPERATING TEMP: -65°C TO +125°C I= #4-40 THREADED INSERT (PAGE 2) PROCESSING TEMP: WAVE/MANUAL SOLDER S= .125" DIA. SIDE MOUNTING (PAGE 2) N= NO MOUNTING EARS (PAGE 2) B= OPEN CARDSLOT(PAGE 2) R = PPS/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C C PROCESSING TEMP: 260°C FOR 120 SECS MAX G = PA9T/PHOSPHOR BRONZE NUMBER OF POSITIONS OPERATING TEMP: -65°C TO +125°C (CONTACTS PER ROW) PROCESSING TEMP: 260°C FOR 20 SECS MAX H = PBT/BERYLLIUM COPPER PLATING OPERATING TEMP: -65°C TO +125°C ALL PLATINGS ARE LEAD FREE AND HAVE .000050" NICKEL UNDERPLATE PROCESSING TEMP: WAVE/MANUAL SOLDER A = PPS/BERYLLIUM COPPER B CONTACT SURFACE TERMINATION B= .000010" GOLD OPERATING TEMP: -65°C TO +150°C C= .000030" GOLD .000100" PURE TIN, MATTE PROCESSING TEMP: 260°C FOR 120 SECS MAX S= .000010" GOLD .000010" GOLD OVERALL .000030" GOLD .000010" GOLD OVERALL J = PA9T/BERYLLIUM COPPER M= ** E = OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C FOR 20 SECS MAX (CONSULT FACTORY FOR OTHER MATERIALS) .000100" PURE TIN, MATTE B .000100" PURE TIN, MATTE, OVERALL G= .000010 GOLD .000005" GOLD Y= .000030" GOLD .000005" GOLD ** OVERALL PURE TIN ONLY AVAILABLE ON MATERIAL CODES E, R AND G CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 DATE NAME 6/24/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER _ _A_ _DSS_-S288 SIZE CAGE CODE C 54453 SCALE: 2:1 3 2 A EDGECARD .125" PITCH, HP DWG. NO. REV C12338 A SHEET 3 OF 3 1 FILE NAME: C12338, _ _A_ _DSS_-S288
ECA30DSSN-S288 价格&库存
很抱歉,暂时无法提供与“ECA30DSSN-S288”相匹配的价格&库存,您可以联系我们找货
