FHA.MH.03C.XLZT66N
FHA.MH.03C.XLZT66N
    LEMO(雷莫)
    CONN PLUG HSG FHA.MH. - 4 F2 F/O
FHA.MH.03C.XLZT66N 数据手册
® ® HERMAPHRODITIC PUSH-PULL CONNECTORS DISCLAIMER​The information contained within this catalog and the functions offered are intended to provide information about products. All reasonable efforts have been made to ensure the accuracy of the information. However, LEMO cannot be held responsible for any errors. LEMO does not warrant the accuracy and reserves the right to make changes to the catalog and its functions at any time without notice. www.lemo.com 1 ® ® Precision modular connectors to suit your application Since its creation in Switzerland in 1946 the LEMO Group has been recognized as a global leader of circular Push-Pull connectors and connector solutions. Today LEMO and its affiliated companies, REDEL and COELVER, are active in more than 80 countries with the help of over 40 subsidiaries and distributors. Over 75000 connectors The modular design of the LEMO range provides over 75000 connectors from miniature ø 3 mm to ø 50 mm, capable of handling cable diameters up to 30 mm and for up to 114 contacts. This vast portfolio enables you to select the ideal connector configuration to suit almost any specific requirement in most markets, including medical devices, test and measurement instruments, machinery, audio video broadcast, telecommunications and military. LEMO’s Push-Pull Self-Latching Connection System This self-latching system is renowned worldwide for its easy and quick mating and unmating features. It provides absolute security against vibration, shock or pull on the cable, and facilitates operation in a very limited space. The LEMO self-latching system allows the connector to be mated by simply pushing the plug axially into the socket. Once firmly latched, connection cannot be broken by pulling on the cable or any other component part other than the outer release sleeve. When required, the connector is disengaged by a single axial pull on the outer release sleeve. This first disengages the latches and then withdraws the plug from the socket. UL Recognition LEMO connectors are recognized by the Underwriters Laboratories (UL). The approval of the complete system (LEMO connector, cable and your equipment) will be easier because LEMO connectors are recognized. CE marking CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. RoHS LEMO connector specifications conforms the requirements of the RoHS directive (2011/65/EU) of the European Parliament and the latest amendments. This directive specifies the restrictions of the use of hazardous substances in electrical and electronic equipment marketed in Europe. Product safety notice & disclaimers Please read and follow all instructions specified on the last page or on our website carefully and consult all relevent national and international safety regulations for your application. Improper handling, cable assembly, or wrong use of connectors can result in hazardous situations. LEMO products and services are provided “as is.” LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. In no event shall LEMO be liable for any direct, indirect, punitive, incidental, special consequential damages, to property or life, whatsoever arising out of or connected with the use or misuse of LEMO’s products. www.lemo.com ® ® SH-MH Series The LEMO Hermaphroditic series provide a rugged high performance patented push-pull hermaphroditic interconnection system. These «genderless» connectors combine LEMO’s well proven push-pull latching technology and the use of our standard high quality optical and electrical contacts. The main features of these series are as follow: – security of a new patented push-pull hermaphroditic self-latching system – 2 shell sizes, SH and MH series – compact unsealed version for general purpose applications – rugged waterproof (IP 68) version for all outdoor applications – a choice of multifibre or electrical contacts configurations – lightweight design with shell in anthracite nickel-plated aluminium alloy – low loss ceramic PC technology in multimode and singlemode – gold plated electrical contacts. Each series consists of plug and socket which will accept cable diameter ranging from 3.6 mm to 10 mm. Initial program is giving solutions with 2, 4 or 6 fibre optic channel and 6 or 12 electrical contacts. Standard version (IP 50 when mated) Straight plug FHA Sealed version Straight plug (IP 68 when mated) FHE Straight plug Fixed plug Fixed socket FHA FWA EHA Straight plug Fixed plug Fixed socket FHE FWE EHE Part Section Showing Internal Components 10 9 6 1 5 2 1 2 3 4 5 www.lemo.com 4 7 shell latch sleeve inner shell spring circlip 3 8 8 2 1 7 3 4 5 6 9 10 collet nut insulator 8 optical contact 9 cable adapter 10 bend relief 6 7 1 ® ® Technical Characteristics Optical Mechanical and Environmental Characteristics Value 2000 cycles Mating durability Standard IEC 60512-5 test 9a Temperature range -55°C to +125°C1) Vibration resistance 10-2000 Hz, 15 g IEC 60512-4 test 6d Shock resistance 100 g, 6 ms IEC 60512-4 test 6c Protection index FHE/FHE IP 68 IEC 60529 up to 2 meters depth Water immersion FHE/FHE Protection index FHA/FHA plug/plug IP 50 IEC 60529 600 N IEC 60512-8 test 15f SH Average series plug/socket 300 N latching 800 N retention MH plug/plug series plug/socket 400 N Value Characteristics IEC 60512-8 test 15f IEC 60512-8 test 15f Standard Average insertion loss fibre 9/125 µm 0.18 dB IEC 61300-03-34 Method 2 Average insertion loss fibre 50/125 µm 0.25 dB IEC 61300-03-34 Method 2 Return loss fibre 9/125 µm (UPC) ≥45 dB IEC 61300-03-06 Coupler Method Return loss fibre 9/125 µm (Hand polish) >25 dB IEC 61300-03-06 Coupler Method Materials and Treatments IEC 60512-8 test 15f Material (Standard) Component Electrical Outer shell, collet nut1) Alum. (AA 6262A or AA 6023) Characteristics Value Standard Insulation resistance > 1012 Ω IEC 60512-2 test 3a Contact resistance < 3.6 mΩ IEC 60512-2 test 11f Shell resistance < 10 mΩ IEC 60512-2 test 2f Method Notes: 1) with f.o. contacts temperature range -40°C/+80°C Surface treat (µm) Cu nickel Ni Au – 5 – 0.5 3 – – 5 – Latch sleeve Special brass Other metallic parts Alum. (AA 6262A or AA 6023) Spring Stainless steel without treatment Insulator PEEK without treatment Electrical contacts Brass (male)/Bronze (female) O-ring and gaskets Silicone MQ / MVQ 0.5 3 1 without treatment Notes: 1) anthracite colour Part Number Example A different part number structure is applicable for each of the following product types: – Plugs and fixed sockets; fibre optic contacts. Note: The fibre optic contacts must be ordered separately. An equal number of contacts must be ordered (eg. for MH.03C; 2 x FFS.F2 and 2 x PSS.F2). Straight plug with bend relief F H E Model: (page 4) Series: (page 4) Type: (page 5) Housing: X = Anthracite nickel plated aluminium M H 0 3 C X L Z T 7 6 N Bend relief colour (for plug): N = black, G = grey, R = red Cable fixing and ø (for plug): (page 5) LV Contact Type: (page 5) Insulator: L = PEEK FHE.MH.03C.XLZT76N = Straight plug (IP 68 when mated), MH series, multifibre to accept 4 F2 type fibre optic contacts, anthracite nickel plated aluminium shell, PEEK insulator, with cable fixing type T for 7.5 to 6.6 mm cable and black bend relief. 2 www.lemo.com ® ® Fiber optic contact F F S F 2 B A 2 L C E 3 0 FFS = Male contact Model: PSS = Female contact Cable ø for F2: T10 = 0.25 to 1.1 mm E30 = 1.7 to 3.0 mm FO Contact type: F2 for SH.03A & MH.03C F7 for SH.03C & MH.03E Cable ø for F7: E23 = 0.25 to 2.0 mm Fibre type: (page 5) Ferrule material: C = Zirconia ceramic Body: L = PEEK FFS.F2.BA2.LCE30 = Male F2 type fibre optic contact, ferrule bore diameter of 125 µm, PEEK body, Zirconia ceramic ferrule, crimp cable fixing, for tight jacket cable with a diameter between 1.7 to 3.0 mm. Models - Series FHA Straight plug with cable adapter or collet and nut with bend relief ~M ~N Reference øA S2 Dimensions (mm) Model Series A ~L L M N S2 FHA SH 21.8 98.4 82.2 46.2 13 FHA MH 25.4 109.3 89.1 47.1 15 FWA Fixed plug, nut fixing Reference Model Series B + 0.1 0 S3 øA S1 e øB ø A+ 0.1 0 S2 A B e E L M S1 S2 S3 FWA SH 28.5 28.5 M22x1 14 55.0 26.5 20.5 14 25 FWA MH 34.0 34.0 M25x1 17 64.5 31.5 23.5 17 30 Panel cut-outs Dim. (mm) Series ø A B E maxi M ~L www.lemo.com Dimensions (mm) SH 22.2 20.6 MH 25.2 23.6 3 ® ® EHA Fixed socket, nut fixing S1 S3 Reference øA e øB Model Series P ø A+ 0.1 0 7 maxi Dimensions (mm) A B L e optic elect. M N P S1 S3 EHA SH 27 28.5 M22x1 38.8 30.5 19.5 30.5 3.3 20.5 25 EHA MH 32 34.0 M25x1 40.8 37.0 24.5 37.0 4.3 23.5 30 Panel cut-outs M N Dim. (mm) Series ø A B ~L B + 0.1 0 SH 22.2 20.6 MH 25.2 23.6 FHE Straight plug with cable adapter or collet and nut with bend relief (IP 68 when mated) ~M S2 ~N øA Reference Dimensions (mm) Model Series A ~L L M N S2 FHE SH 28.5 98.4 90.0 54.0 13 FHE MH 34.0 109.3 98.9 56.9 15 FWE Fixed plug, nut fixing (IP 68 when mated) Reference Model Series B + 0.1 0 S3 øA S1 e øB ø A+ 0.1 0 S2 E maxi M ~L 4 Dimensions (mm) A B e E L M S1 S2 S3 FWE SH 28.5 28.5 M22x1 14 55.0 26.5 20.5 14 25 FWE MH 34.0 34.0 M25x1 17 64.5 31.5 23.5 17 30 Panel cut-outs Dim. (mm) Series ø A B SH 22.2 20.6 MH 25.2 23.6 www.lemo.com ® ® EHE Fixed socket, nut fixing (IP 68 when mated) S1 S3 Reference øA e øB Model Series ø A+ 0.1 0 7 maxi P M N Dimensions (mm) A B L e optic elect. M N P S1 S3 EHE SH 28.5 28.5 M22x1 38.8 30.5 19.5 30.5 11.1 20.5 25 EHE MH 34.0 34.0 M25x1 40.8 37.0 24.5 37.0 14.1 23.5 30 Panel cut-outs Dim. (mm) Series ø A B ~L B + 0.1 0 SH 22.2 20.6 MH 25.2 23.6 Insert configuration FO contact Low Voltage contact MH Test voltage (kV dc) Rated current (A) – Test voltage (kV rms) ø A (mm) – AWG Crimp Contact Nb – AWG max. Solder F7 Nb SH Socket F2 Nb Plug Reference øA øA Contact type – – – – – 03A 2 03C – 4 – – – – – – – 306 – 03C 4 – – – – – – – – 03E – 6 – – – – – – – 312 – – – 6 12 1.3 1.3 20 20 18-20 18-20 1.5 1.0 2.1 1.5 12 8 Note: Other arrangement, optical, electrical or mixed optical-electrical can be made available upon request. WARNING: There is no contact number on the insulator. When wiring one hermaphroditic connector, one should terminate each contact to its mirror image number of the other connector. www.lemo.com 5 ® ® Electrical contact Reference Cable diameter Contact type Reference Contact type A solder for plug M crimp for socket C crimp for plug Z no contact L Adapter «T» for fibre optic connectors SH solder for socket Fibre type Collet «C» for electrical connectors Ref. Cable ø max. min. Ref. Cable ø max. min. T46 4.5 3.6 C52 5.0 4.1 T56 5.5 4.6 C62 6.0 5.1 T66 6.5 5.6 C72 7.0 6.1 T76 7.5 6.6 C82 8.0 7.1 T56 5.5 4.6 C62 6.0 5.1 T66 6.5 5.6 C72 7.0 6.1 Ref. for F2 contact Ref. for F7 contact BA2 125 9/125, 50/125, 62.5/125 125 l BB2 126 9/125, 50/125, 62.5/125 126 l BD2 128 9/125, 50/125, 62.5/125 128 T76 7.5 6.6 C82 8.0 7.1 l T86 8.5 7.6 C92 9.0 8.1 T91 9.0 8.6 C10 10.0 9.1 Ferrule Note hole ø (µm) ø Core/Cladding (µm) l First choice alternative   MH Special order alternative Accessories BFA Cap (for FHA and FWA plugs) 6 N øA L sliding loop Part number Dimensions (mm) A L N1) BFA.SH.100.XAZ 21.8 23.5 120 BFA.MH.100.XAZ 25.4 30.0 120 l l l l l Note: 1) the tolerance on this dimension is ± 5 mm. Body material: Anthracite nickel plated aluminium alloy Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin Maximum operating temperature: 125°C Watertightness: IP50 according to IEC 60529 BHA Cap (for FHA and FWA plugs) 6 N øA L ø 3.5 Part number l l l l l Body material: Anthracite nickel plated aluminium alloy Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin Maximum operating temperature: 125°C Watertightness: IP50 according to IEC 60529 Dimensions (mm) A L N1) BHA.SH.100.XAZ 21.8 23.5 120 BHA.MH.100.XAZ 25.4 30.0 120 Note: 1) the tolerance on this dimension is ± 5 mm. 6 www.lemo.com ® ® BFE Cap (for FHE and FWE plugs) 6 N øA L sliding loop Part number Dimensions (mm) A L N1) BFE.SH.100.XAS 28.5 23.5 120 BFE.MH.100.XAS 34.0 30.0 120 l l l l l l Note: 1) the tolerance on this dimension is ± 5 mm. Body material: Anthracite nickel plated aluminium alloy Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin O-ring material: Silicone rubber Maximum operating temperature: 125°C Watertightness: IP68 according to IEC 60529 BHE Cap (for FHE and FWE plugs) 6 N øA L ø 3.5 Part number l l l l l l Body material: Anthracite nickel plated aluminium alloy Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin O-ring material: Silicone rubber Maximum operating temperature: 125°C Watertightness: IP68 according to IEC 60529 Dimensions (mm) A L N1) BHE.SH.100.XAS 28.5 23.5 120 BHE.MH.100.XAS 34.0 30.0 120 Note: 1) the tolerance on this dimension is ± 5 mm. www.lemo.com 7 ® ® Tooling WST.KI.125.34 Cleaning kit for F2 fibre optic contact Description Fibre optic cleaning kit of 2 cotton buds, 1 dry and 1 being soaked in IPA (Isopropyl Alcohol) used for cleaning the fibre optic contacts. DCC.91.F12.LAG Manual extractor for F2 fibre optic contact DCS Contact alignment device tool for F2 or F7 fibre optic contact Description Simple tool with two threaded end for installation/extraction of the F7 contact alignment device. Contact type Part number DCS.F2.035.PN DCS.F7.035.PN Note: 1) F2 1) F7 Included in the LEMO F7 workstation. DCC Extractor for F7 fibre optic contact Description Manual tool for the extraction of the F7 contact. Part number DCC.91.307.5LA 1) Note: 1) Included in the LEMO F7 workstation. 8 www.lemo.com ® ® Product safety notice PLEASE READ AND FOLLOW ALL INSTUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION. IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS SITUATIONS. 1. SHOCK AND FIRE HAZARD Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue (such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock. Mated components should never be disconnected while live as this may result in an exposed electric arc and local overheating, resulting in possible damage to components. 2. HANDLING Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect components should be rejected or returned to the factory for verification. Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used during installation and / or assembly in order to obtain safe and reliable performance. 3. USE Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to eliminate all risk of transmission of such voltages to any exposed metal part of the connector. 4. TEST AND OPERATING VOLTAGES The maximum admissible operating voltage depends upon the national or international standards in force for the application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the catalog however these may be influenced by PC board design and / or wiring harnesses. The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the test duration is 1 minute. 5. CE MARKING CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. 6. PRODUCT IMPROVEMENTS The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior notification. 7. WARNING (Prop 65 State of California) Proposition 65 requires businesses to provide warnings to Californians about significant exposures to chemicals that cause cancer, birth defects or other reproductive harm. LEMO products are exempt from proposition 65 warnings because they are manufactured, marketed, and sold solely for commercial and industrial use. For further information, please visit https://www.lemo.com/quality/LEMO-Prop-65-compliance-declaration.pdf. Disclaimers LEMO works constantly to improve the quality of its products; the information and illustrations figuring in this document may therefore vary and are not binding. In any case, LEMO makes no specific warranty of merchantability, fitness for a particular purpose, third party components as such or included in assembly, non-infringement, title, accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO component. In no event shall LEMO, its affiliates, officers, agents or employees be liable for any incidental, indirect, special or consequential damages in connection with the products or services provided by LEMO, including (without limitation) loss of profits or revenues, interruption of business, loss of use of the products or any associated equipment, materials, components or products, damages to associated equipment or in combination with other components, materials. Reproduction of significant portions of LEMO information in LEMO data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. LEMO is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO SA reserves the right to modify and improve specifications, at all times, without any notification. www.lemo.com LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. +41 21 695 16 00 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: +43 1 914 23 20 0 Fax:+43 1 914 23 20 11 salesAT@lemo.com BRAZIL LEMO Latin America Ltda Av. Dr. Adhemar de Barros, 566 – Sala 1407, Vila Adyana CEP: 12245-011 São José dos Campos - SP - Brazil Tel: +55 11 94242 4293 info-la@lemo.com CANADA LEMO Canada Inc 44 East Beaver Creek Road, unit 20 Richmond Hill, Ontario L4B 1G8 Tel: +1 905 889 56 78 Fax: +1 905 889 49 70 info-canada@lemo.com CHINA / HONG KONG LEMO Electronics (Shanghai) Co., Ltd First Floor, Block E, 18 Jindian Road, Pudong Shanghai, China, 201206 Tel: +86 21 5899 7721 Fax: +86 21 5899 7727 cn.sales@lemo.com DENMARK LEMO Denmark A/S Mandal Allé 16A 5500 Middelfart Tel: +45 45 20 44 00 Fax: +45 45 20 44 01 info-dk@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: +33 1 60 94 60 94 Fax: +33 1 60 94 60 90 info-fr@lemo.com GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: +49 89 42 77 03 Fax: +49 89 420 21 92 info@lemo.de HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: +36 1 421 47 10 Fax: +36 1 421 47 57 info-hu@lemo.com ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: +39 02 66 71 10 46 Fax: +39 02 37 90 80 46 sales.it@lemo.com JAPAN LEMO Japan Ltd 2-7-22, Mita, Minato-ku, Tokyo, 108-0073 Tel: +81 3 54 46 55 10 Fax: +81 3 54 46 55 11 info-jp@lemo.com LEMO NETHERLANDS / BELGIUM LEMO Connectors Nederland B.V. Jacques Meuwissenweg 6 2031 AD Haarlem Tel. +31 23 206 07 01 info-nl@lemo.com NORWAY / ICELAND LEMO Norway A/S Soerumsandvegen 69, 1920 Soerumsand Tel: +47 22 91 70 40 Fax: +47 22 91 70 41 info-no@lemo.com SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: +65 6476 0672 Fax: +65 6474 0672 sg.sales@lemo.com SPAIN / PORTUGAL IBERLEMO SAU Brasil, 45, 08402 Granollers Barcelona Tel: +34 93 860 44 20 Fax: +34 93 879 10 77 info-es@lemo.com SWEDEN / FINLAND LEMO Nordic AB Gunnebogatan 30 163 53 Spånga Tel: +46 8 635 60 60 Fax: +46 8 635 60 61 info-se@lemo.com SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B, 6343 Rotkreuz Tel: +41 41 790 49 40 ch.sales@lemo.com TAIWAN TAOYUAN TAIWAN Tel: +886 967 132 824 speng@lemo.com UNITED ARAB EMIRATES LEMO Middle East Connectors LLC Concorde Tower 11th Floor, Office 1102, Dubai Media City, P.O. Box 449849 Dubai, United Arab Emirates Tel: +971 4 568 1904 info-me@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street, Worthing, West Sussex, BN11 1DU Tel: +44 1903 23 45 43 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: +1 707 578 88 11 +1 800 444 53 66 Fax: +1 707 578 08 69 info-US@lemo.com DISTRIBUTORS ARGENTINA, AUSTRALIA, BRAZIL, CHILE, COLOMBIA, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, PERU, POLAND, SOUTH AFRICA, SOUTH KOREA, TURKEY, UKRAINE www.lemo.com CAT.MH.LEN.P0908, © LEMO / Data subject to change, printed in Switzerland, updated April 2022 LEMO
FHA.MH.03C.XLZT66N 价格&库存
很抱歉,暂时无法提供与“FHA.MH.03C.XLZT66N”相匹配的价格&库存,您可以联系我们找货
