T020-001-ST9
T020-001-ST9
    TRIPPLITE
    T020-001-ST9
T020-001-ST9 数据手册
FC to ST 9/125 Adapter for Multi-Function Optical Fiber Cable Tester (M/F) MODEL NUMBER: T020-001-ST9 Highlights ● Converts native FC jack to an ST female connector ● FC male plug connects to fiber cable tester’s FC female jack ● Perfect for 9/125 singlemode cable testing ● Included dust caps keep connectors clean ● For use with T020-001-PSF Optical Fiber Cable Tester System Requirements ● Tripp Lite T020-001-PSF MultiFunction Optical Fiber Cable Tester Package Includes ● Converts FC connector on Tripp Lite Multi-Function Optical Fiber Cable Tester to an ST connector. Ideal for cable installers or anyone else working in telecom or LAN environments. Description The T020-001-ST9 FC to ST 9/125 Adapter converts a native FC fiber female port on the Tripp Lite T020001-PSF Multi-Function Optical Fiber Cable Tester to an ST female port for 9/125 singlemode cable testing. “9/125” is clearly labeled on the unit to differentiate the T020-001-ST9 from other adapters. Included dust caps keep the connectors clean when not in use. Features Converts Cable Tester’s FC Connector to an ST Connector ● Ideal for cable installers or anyone else working in telecom or LAN environments ● Perfect for 9/125 singlemode cable testing ● FC male plug connects to cable tester’s FC female jack ● Included dust caps keep connectors clean ● For use with T020-001-PSF Multi-Function Optical Fiber Cable Tester Specifications OVERVIEW UPC Code 037332197672 Technology Singlemode PHYSICAL Color Silver Clad Diameter (microns) 125 1/2 T020-001-ST9 FC to ST 9/125 Adapter Core Diameter (microns) 9 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Weight (kg) 0.02 Shipping Weight (lbs.) 0.04 WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
T020-001-ST9 价格&库存
很抱歉,暂时无法提供与“T020-001-ST9”相匹配的价格&库存,您可以联系我们找货
