SPN02SYBN-RC
SPN02SYBN-RC
    SULLINS
    CONN SHUNT 2MM OPEN TOP 2PS GOLD
SPN02SYBN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY B 946 UPDATE OPERATING TEMPERATURE 03/01/06 YH C 1340 04/19/07 YH D 1764 07/23/08 ASK E 1903 UPDATE OVERALL DIM HEIGHT UPDATE FORMAT, TOLERANCE, DEFINE CONTACT AREA UPDATE TOLERANCE BLOCK, SPECIFICATION 20 MILLI OHMS WAS 20 MEGA OHMS 1/23/09 JH .157 4.00 E E .024 0.60 A F A D D .079 2.00 .079 2.00 2X .079 2.00 POINT OF CONTACT C C .138 3.50 .059 1.50 AREAS OF CONTACT B B SECTION A-A A NOTES: 1. INSULATOR MATERIAL: PBT, BLACK 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. PLATING: SEE PART NUMBER CODING. 4. OPERATING TEMPERATURE: -55 C TO +105 C. 5. OPERATING VOLTAGE: 250 VAC MAX. 6. UL FLAMMABILITY RATING: 94V-0. 7. DIELECTRIC WITHSTANDING VOLTAGE: 1000 VAC FOR 1 MINUTE. 8. CURRENT RATING: 1 AMP PER CONTACT. 9. CONTACT RESISTANCE: 20 MILLI OHMS MAX. 10. INSULATION RESISTANCE: 5000 MEGA OHMS. 8 7 6 Pb RoHS COMPLIANT 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 30' .XX= .012 [.30] .XXX= .008 [.20] .XXXX= .004 [.10] INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 DRAWN DATE NAME 10/21/05 YH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. S_N02SYBN-RC SIZE DWG. NO. C REV 10631 SCALE: 32:1 3 A MINI SHUNT, OPEN TOP 2 E SHEET 1 OF 1 1 FILE NAME: Z:\COMPONENTS\Taiwan\10631, S_N02SYBN PRINT: 2/9/2009
SPN02SYBN-RC 价格&库存
很抱歉,暂时无法提供与“SPN02SYBN-RC”相匹配的价格&库存,您可以联系我们找货
