SPN02SXCN-RC
SPN02SXCN-RC
    SULLINS
    2 (1 x 2) Position Shunt Connector Open Top 0.079" (2.00mm) Gold
SPN02SXCN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2145 07/16/2010 LH B 2456 INITIAL RELEASE CORRECTED OPEN TOP VIEW TO MATCH PART, UPDATED DWG FORMAT 9/27/2011 JH F F .157 4.00 E .079 2.00 E A .039 1.00 .079 2.00 D D .177 4.50 2X .096 2.45 POINT OF CONTACT (REF.) .079 2.00 C A C SECTION A-A SCALE 20 : 1 B A B NOTES: 1. INSULATOR MATERIAL: PBT. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. PLATING: GOLD FLASH OVERALL. 4. UL FLAMMABILITY RATING: 94V-0. 5. DIELECTRIC WITHSTANDING VOLTAGE: 650V AC. 6. CURRENT RATING: 1 AMP PER CONTACT. 7. CONTACT RESISTANCE: 30 MILLI OHMS MAX. 8. INSULATION RESISTANCE: 1000 MEGA OHMS. 9. OPERATING TEMPERATURE: -40 C TO +85 C. 10. DOUBLE TUNING FORK TYPE CONTACT, ACCOMMODATES .020"[0.50mm] SQ PINS, .079"[2.00mm] PITCH LOW-PROFILE MINI TYPE. DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: ANGULAR: .XX= .012 [.30] .XXX= .008 [.20] .XXXX= .004 [.10] RoHS COMPLIANT 8 7 6 5 30' 4 INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 7/16/2010 LH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A MINI SHUNT, .079" CC, OPEN TOP PART NUMBER SIZE C CAGE CODE 54453 SCALE: 16:1 2 SPN02SXCN-RC DWG. NO. 11504 SHEET 1 OF 1 1 REV B FILE NAME: 11504, SPN02SXCN-RC
SPN02SXCN-RC 价格&库存
很抱歉,暂时无法提供与“SPN02SXCN-RC”相匹配的价格&库存,您可以联系我们找货
