Female Card Edge
.125” [3.18 mm] Contact Centers, .610” [15.49 mm] Insulator Height,
Dip Solder/Wire Wrap/Right Angle
Sullins Female Card Edge
SPECIFICATIONS
• Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board
(See following pages for .093” ± .008” [2.36 mm ± 0.20 mm]
and .125” ± .008” [3.18 mm ± 0.20 mm] mating PCB)
• PBT, PPS or PA9T insulator
• Molded-in key available
• 3 Amps current rating for one contact energized
• 30 milli Ohms maximum at rated current
• UL Flammability Rating: 94V-0
READOUT
POLARIZING KEY
PLC-K1
.038”
[0.97]
.285”
[7.24]
EVEN
NUMBER
SIDE
DUAL (D)
.100” [2.54]
KEY IN BETWEEN CONTACTS
(ORDER SEPARATELY)
HALF LOADED (H)
TERMINATION TYPE
LOOP BELLOWS
HAIRPIN BELLOWS
L
.275” [6.98]
L
L
K
K
.250” [6.35]
.250” [6.35]
ODD
NUMBER
SIDE
K
K
.150” [3.81]
L - .015” [0.38]
ACCEPTS .062” [1.57] PCB
LOOP BELLOWS
(TK,RS,RM,CK)
HAIRPIN BELLOWS
(CS,CM,CW,CT)
HAIRPIN
BELLOWS
CM
CA
CB
CC
CW
CT
CS
LOOP
BELLOWS
TK, CK
RS
RM
TA
TB
TM
TERMINATION
TYPE
DIP SOLDER
DIP SOLDER
WIRE WRAP
RIGHT ANGLE
RIGHT ANGLE
RIGHT ANGLE
DIP SOLDER
DIP SOLDER
DIP SOLDER
RIGHT ANGLE, DIP SOLDER
(CA,CB,CC,TA,TB,TM)
CARD EXTENDER
REQUIRES -S288 MODIFICATION CODE
(CS,CM,CT,RS,CK,TK,RM)
POST CROSS SECTION
K
POST LENGTH
L ± .025”ʺ [0.64]
FITS MIN.
HOLE SIZE
.025ʺ [0.64] ROUND
.190ʺ [4.83]
.033ʺ [0.84]
.025ʺ [0.64] SQUARE
.190ʺ [4.83]
.040ʺ [1.02]
.025ʺ [0.64] SQUARE
.560ʺ [14.20]
.040ʺ [1.02]
.025ʺ [0.64] SQUARE
.100ʺ [2.54]
.043ʺ [1.09]
.025ʺ [0.64] SQUARE
.180ʺ [4.57]
.043ʺ [1.09]
.025ʺ [0.64] SQUARE
.250ʺ [6.35]
.043ʺ [1.09]
.015ʺ X .025ʺ [0.38 X 0.64]
.125ʺ [3.18]
.035ʺ [0.89]
.170ʺ [4.32]
.035ʺ [0.89]
.025ʺ [0.64] SQUARE
.160ʺ [4.06]
.040ʺ [1.02]
MOUNTING STYLE
Ø.125”
[3.18]
#4-40
Ø.125” [3.18]
Ø.125”
[3.18]
D = .250” [6.35]
W = .430” [10.92]
.250”
[6.35]
CLEARANCE
HOLE (H)
64
#4-40
T = .250” [6.35]
X = .430” [10.92]
.245”
[6.22]
THREADED
INSERT (I)
SIDE MOUNTING
(S)
NO MOUNTING
EARS (N)
FLUSH MOUNTING
(D, W)
FLUSH MOUNTING WITH
THREADED INSERT
(T, X)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
PART NUMBER OPTIONS
E B A 50 D CM H - Sxxx
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze (Standard)
R = PPS/Phosphor Bronze
G = PA9T/Phosphor Bronze
H = PBT/ Beryllium Copper
A = PPS/Beryllium Copper
J = PA9T/Beryllium Copper
(Consult factory for other materials.)
Refer to Page 7 for Operating/Processing Temperatures
H
I
S
N
W
D
X
T
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
.000010” Gold
.000030” Gold
.000010” Gold
.000030” Gold
Contact Surface
S = .000010” Gold
M = .000030” Gold
E = .000100” Pure Tin, Matte
B
C
G
Y
Termination
.000005” Gold
.000005” Gold
Overall Plating
.000010” Gold
.000010” Gold
MODIFICATION CODE (Consult Factory)
OMIT FOR STANDARD
-S288 = Card Extender Accepts .062” [1.57 mm] PCB
MOUNTING STYLE (Opposite Page)
= Clearance Holes
= Threaded Inserts
= Side Mounting
= No Mounting
= Flush Mounting
= Flush Mounting
= Flush Mounting with Threaded Inserts
TERMINATION TYPE (Opposite Page)
Hairpin Bellows **
**Available with B or C plating and Phosphor Bronze Only
CS = .025” [0.64 mm] Square Dip Solder
CM = .025” [0.64 mm] Square Wire Wrap
CA, CB, CC = .025” [0.64 mm] Square Right Angle
CW, CT = .015” X .025” [0.38 mm X 0.64 mm] Dip Solder
CONTACT CENTERS
A = .125” [3.18 mm]
Loop Bellows
RS
CK, TK
RM
TA, TB, TM
NUMBER OF CONTACT POSITIONS
See Chart Below
READOUT (Opposite Page)
D = Dual
H = Half Loaded
.025” [0.64 mm] Round Dip Solder
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
.297 [7.54] INSERTION DEPTH
REFER TO MOUNTING STYLE
.250
[6.35]
C
.180 [4.57]
.370 [9.40]
CONTACT MARKINGS
1 3 5 . . . 95 97 99
2 4 6 . . . 96 98 100
1
2
A
B
D
E
3
4
5 95 97 99
6 96 98 100
.610
[15.49]
.060
[1.52]
REFER TO TERMINATION TYPE
.125 [3.18] TYP.
F
Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory.
POSITIONS/
CONTACTS
INCHES
A±.008
06/12
10/20
14/28
15/30
18/36
22/44
24/48
25/50*
28/56
30/60
31/62
32/64
35/70
36/72
40/80
43/86
44/88
49/98
50/100
* Consult factory
B±.008
0.625
0.875
1.125
1.375
1.625
1.875
1.750
2.000
2.125
2.375
2.625
2.875
2.875
3.125
3.000
3.250
3.375
3.625
3.625
3.875
3.750
4.000
3.875
4.125
4.250
4.500
4.375
4.625
4.875
5.125
5.250
5.500
5.375
5.625
6.000
6.250
6.125
6.375
for availability.
MILLIMETERS
C±.015
D±.010
E±.020
F±.015
A±0.20
B±0.20
C±0.38
D±0.25
E±0.51
F±0.38
1.035
1.535
2.035
2.160
2.535
3.035
3.285
3.410
3.785
4.035
4.160
4.285
4.660
4.785
5.285
5.660
5.785
6.410
6.535
1.295
1.795
2.295
2.420
2.795
3.295
3.545
3.670
4.045
4.295
4.420
4.545
4.920
5.045
5.545
5.920
6.045
6.670
6.795
1.555
2.055
2.555
2.680
3.055
3.555
3.805
3.930
4.305
4.555
4.680
4.805
5.180
5.305
5.805
6.180
6.305
6.930
7.055
0.875
1.375
1.875
2.000
2.375
2.875
3.125
3.250
3.625
3.875
4.000
4.125
4.500
4.625
5.125
5.500
5.625
6.250
6.375
15.88
28.58
41.28
44.45
53.98
66.68
73.03
76.20
85.73
92.08
95.25
98.43
107.95
111.13
123.83
133.35
136.53
152.40
155.58
22.23
34.93
47.63
50.80
60.33
73.03
79.38
82.55
92.08
98.43
101.60
104.78
114.30
117.48
130.18
139.70
142.88
158.75
161.93
26.29
38.99
51.69
54.86
64.39
77.09
83.44
86.61
96.14
102.49
105.66
108.84
118.36
121.54
134.24
143.76
146.94
162.81
165.99
32.89
45.59
58.29
61.47
70.99
83.69
90.04
93.22
102.74
109.09
112.27
115.44
124.97
128.14
140.84
150.37
153.54
169.42
172.59
39.50
52.20
64.90
68.07
77.60
90.30
96.65
99.82
109.35
115.70
118.87
122.05
131.57
134.75
147.45
156.97
160.15
176.02
179.20
22.23
34.93
47.63
50.80
60.33
73.03
79.38
82.55
92.08
98.43
101.60
104.78
114.30
117.48
130.18
139.70
142.88
158.75
161.93
65
很抱歉,暂时无法提供与“EBA30DTBT”相匹配的价格&库存,您可以联系我们找货
