EBM43DSUS
EBM43DSUS
    SULLINS
    CONN EDGECARD 86POS DIP .156 SLD
EBM43DSUS 数据手册
Female Card Edge .156” [3.96 mm] Contact Centers, .431” [10.95 mm] Insulator Height, Dip Solder/Eyelet/Right Angle Sullins Female Card Edge SPECIFICATIONS • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board • Molded-in key available • 3 Amps current rating for one contact energized (for 5 Amps application, consult factory) • 30 milli Ohms maximum at rated current • UL Flammability Rating: 94V-0 READOUT POLARIZING KEY PLA-K1 KEY IN BETWEEN CONTACTS (ORDER SEPARATELY) BACK-UP SPRINGS FULL BELLOWS .230” [5.84] .235” [5.97] .030” [0.76] NUMBER SIDE HALF LOADED (H) DUAL (D) PLM-K2 KEY IN CONTACT (ORDER SEPARATELY) .093” [2.36] .200” [5.08] .260” [6.60] CONSULT FACTORY FOR MOLDED-IN KEY TERMINATION TYPE .137” [3.48] (RX) .200” [5.08] (RF) .225” [5.71] (RU) .408” [10.40] (RP) .137” [3.48] (RT) .225” [5.71] (RK) .425” [10.80] (RY) (RA) .125” [3.18] FOR ALL POSITIONS (SA) .270” [6.85] 02 THRU 25 POSITIONS (SA) .230” [5.84] 28 THRU 36 POSITIONS (SA) .190” [4.82] 43 POSITIONS TOLERANCE: (RA) ± .025” [0.64] (SA) ± .040” [1.00] EYELET ACCEPTS 3-#22 AWG FITS Ø .051” [1.30] .200” [5.08] .140” [3.56] ALTERNATE EYELET SHAPE * (RE) .014” [0.36] THICK .185” [4.70] WIDE DIP SOLDER (RF, RX, RU, RP) NARROW DIP SOLDER (RT, RK, RY) .050” [1.27] .156” [3.96] .110” ± .025” [2.79±0.64] (SX) .210” ± .025” [5.33±0.64] (SU) .225” [5.72] LETTER SIDE FITS Ø.051” [1.30] (SE) .007” [0.18] THICK (RE) .014” [0.36] THICK .122” [3.10] (RT) .210” [5.33] (RK) EYELET .410” [10.41] (RY) (SE OR RE) .210” [5.33] (SE) ACCEPTS .062” [1.57] PCB CARD EXTENDER (RT,RK,RY,SE TERMINATIONS ONLY) REQUIRES -S13 MODIFICATION CODE FITS Ø .051” [1.30] MINIMUM RIGHT ANGLE, DIP SOLDER (RA, SA) CENTERED DIP SOLDER (SX, SU) AVAILABLE WITH DUAL OR HALF LOADED READOUT TYPE MOUNTING STYLE Ø.125” [3.18] CLEARANCE HOLE (H) #4-40 THREADED INSERT (I) Ø.116” [2.95], Ø.125” [3.18] CLEARANCE FOR #4 SCREW FLOATING BOBBIN (F) .135” [3.43] NO MOUNTING EARS (N) SIDE MOUNTING (S) * Beryllium Copper & Beryllium Nickel (H, A, J, F, C & W Material Codes) Only. 70 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .156” [3.96 mm] Contact Centers, .431” [10.95 mm] Insulator Height, Dip Solder/Eyelet/Right Angle PART NUMBER OPTIONS E B M 43 D RK H - Sxxx MOUNTING STYLE (Opposite Page) H = .125” [3.18 mm] Clearance Holes N = No Mounting S = Side Mounting I = Threaded Insert F = Floating Bobbin TERMINATION TYPE (Opposite Page) RA = .125” [3.18 mm] Right Angle Dip Solder SA = Long Right Angle Dip Solder RT = .140” X .137” [3.56 mm X 3.48 mm] Dip Solder RK = .140” X .225” [3.56 mm X 5.72 mm] Dip Solder RY = .140” X .425” [3.56 mm X 10.80 mm] Dip Solder RX = .200” X .137” [5.08 mm X 3.48 mm] Dip Solder RF = .200” X .200” [5.08 mm X 5.08 mm] Dip Solder RU = .200” X .225” [5.08 mm X 5.72 mm] Dip Solder RP = .200” X .408” [5.08 mm X 10.36 mm] Dip Solder SX = .110” [2.79 mm] Centered Dip Solder SU = .210” [5.33 mm] Centered Dip Solder SE = .007” [0.18 mm] Thick Eyelet RE = .014” [0.36 mm] Thick Eyelet CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface .000010” Gold .000030” Gold .000010” Gold .000030” Gold Contact Surface S = .000010” Gold M = .000030” Gold E = .000100” Pure Tin, Matte B C G Y Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold .000005” Gold Overall Plating .000010” Gold .000010” Gold .000100” Pure Tin, Matte = = = = Sullins Female Card Edge MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD -S13 = Card Extender Accepts .062” [1.57 mm] PCB (RT, RK, RY, SE Terminations Only) MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze (Standard) R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper *F = PPS/Spinodal (Overall Gold Plating Only) Consult Factory for Special Soldering Guidelines *C = PPS/Beryllium Nickel (Overall Gold Plating Only) *W = PEEK/Beryllium Nickel (Overall Gold Plating Only) *Consult factory for availability. Refer to Page 7 for Operating/Processing Temperatures READOUT (Opposite Page) D = Dual D = Dual Row/ Crimp to Center for Single Readout (SX, SU Termination Only) H = Half Loaded CONTACT CENTERS M = .156” [3.96 mm] NUMBER OF CONTACT POSITIONS See Chart Below DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. REFER TO MOUNTING STYLE .265 [6.73] INSERTION DEPTH B A .245 [6.22] .431 [10.95] C 1 .025 [0.64] F D E A B 3 C 41 42 43 _ _ _ W X F Y CONTACT MARKINGS (LETTERS G, I, O & Q NOT USED) SIZE 02 THRU 25 1 2 3 . . . 23 24 . . . A B C . . . AA BB . . . SIZES 28 THRU 44 1 2 3 . . . 23 24 . . . A B C... A B ... REFER TO MOUNTING STYLE .156 [3.96] TYP. 2 Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. POSITIONS/ CONTACTS INCHES A±.008 B±.008 02/04 0.156 0.476 03/06 0.312 0.632 04/08* 0.468 0.788 06/12 0.780 1.100 07/14 0.936 1.256 08/16 1.092 1.412 10/20 1.404 1.724 11/22 1.560 1.880 12/24 1.716 2.036 15/30 2.184 2.504 18/36 2.652 2.972 22/44 3.276 3.596 24/48 3.588 3.908 25/50 3.744 4.064 28/56 4.212 4.532 36/72 5.460 5.780 43/86 6.552 6.872 44/88 6.708 7.028 * Consult factory for availability. C±.015 0.596 0.752 0.908 1.220 1.376 1.532 1.844 2.000 2.156 2.624 3.092 3.716 4.028 4.184 4.652 5.900 6.992 7.148 D±.010 MILLIMETERS E MAX F+.005/-.015 ‘N’ MOUNTING 1.533 1.689 1.845 2.157 2.313 2.469 2.937 3.405 4.029 4.341 4.497 4.965 6.213 7.305 7.461 1.902 2.058 2.214 2.526 2.682 2.838 3.306 3.774 4.398 4.710 4.866 5.334 6.582 7.674 7.830 0.325 0.438 0.500 A±0.20 B±0.20 C±0.38 3.96 7.92 11.89 19.81 23.77 27.74 35.66 39.62 43.59 55.47 67.36 83.21 91.14 95.10 106.98 138.68 166.42 170.38 12.09 16.05 20.02 27.94 31.90 35.86 43.79 47.75 51.71 63.60 75.49 91.34 99.26 103.23 115.11 146.81 174.55 178.51 15.14 19.10 23.06 30.99 34.95 38.91 46.84 50.80 54.76 66.65 78.54 94.39 102.31 106.27 118.16 149.86 177.60 181.56 D±0.25 E MAX F+0.13/-0.38 ‘N’ MOUNTING 38.94 42.90 46.86 54.79 58.75 62.71 74.60 86.49 102.34 110.26 114.22 126.11 157.81 185.55 189.51 48.31 52.27 56.24 64.16 68.12 72.09 83.97 95.86 111.71 119.63 123.60 135.48 167.18 194.92 198.88 8.26 11.13 12.70 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 71
EBM43DSUS
1. 物料型号:文档中提到了多种型号选项,例如E、B、M、43、D、RK、H等,以及不同的修改代码,例如-S13,用于卡扩展器接受0.062” [1.57 mm] PCB。
2. 器件简介:Sullins Female Card Edge连接器,具有.156” [3.96 mm]接触中心和.431” [10.95 mm]绝缘体高度,支持Dip Solder/Eyelet/Right Angle。
3. 引脚分配:文档提供了详细的引脚分配信息,包括不同的终止类型如RA、SA、RT、RK、RY、RX等,以及对应的尺寸和公差。
4. 参数特性:文档中列出了关键的参数特性,如适应.062” ± .008” [1.57 mm ± 0.20 mm]的PCB板,内置键可用,单个接触激活时的3安培电流等级,最大30毫欧姆在额定电流下,以及UL阻燃等级94V-0。
5. 功能详解:文档详细描述了连接器的多种功能,包括极化键、备份弹簧、全波纹、双(D)/半加载(H)选项,以及不同终止类型的详细规格。
6. 应用信息:虽然文档中没有直接提到“应用信息”,但从规格和选项可以推断,这些连接器适用于需要高电流承载能力和精确引脚分配的电子应用。
7. 封装信息:文档提供了封装的详细尺寸和安装风格选项,包括清除孔、螺纹浮动、无安装耳、侧安装等。
EBM43DSUS 价格&库存
很抱歉,暂时无法提供与“EBM43DSUS”相匹配的价格&库存,您可以联系我们找货
