UTS7142G1SNPT
UTS7142G1SNPT
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN HSG RCPT 3POS PNL MNT SKT
UTS7142G1SNPT 数据手册
1 2 DWG. NO. NOTES: S99544 1. MATES WITH UTS6_ _142G1P. 2. USES 1-TO-3 EA. SIZE-8 SOCKET (CONTACTS ORDERED SEPARATELY) CONTACT TYPE: 829116____: REFER TO SOURIAU BSD202333002. THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. 3. MATERIALS 3.1 HOUSING: POLYAMIDE UL94V0, COLOR-BLACK. 3.2 ALL MATERIALS ARE RoHS COMPLIANT. 4. PRODUCT PERFORMANCE. 4.1 OPERATING TEMPERTURE: -40C $ TO 105 $C. 4.2 CORROSION: SALT SPRAY, 500 HOUR. 4.3 DURABILITY: 250 MATE-UNMATE CYCLES. 4.4 SEALING: WHEN MATED TO CABLE PLUG (NOTE-1): IEC 60529-IP68: 10m WATER, 1-WEEK; -IP69K: HIGH-PRESSURE WATER, DIN 40050. 4.5 TYPICAL INSTALLATION: OUTLET BOX. RECOMMENDED TOOLS: 8-POINT 1 INCH SOCKET; MAX. TORQUE 37 in.-lb. 1.39 [35.3] .91 [23.2] .87 [22.1] .66 [16.7] B 5. ELECTRICAL PERFORMANCE 5.1 DIELECTRIC WITHSTANDING VOLTAGE / INSULATION RESISTANCE. 2200 VRMS MAX. BETWEEN CIRCUITS / 5000 MOhm MIN. @ 500 VDC. 5.2 OPERATING VOLTAGE: 600 VAC MAX. 5.3 CIRCUIT USE: x x x x x CIRCUIT USE 1 2 44-AMP MAX. GROUND, NO CURRENT FIRST MATE LAST BREAK x x 4X 1.00 [25.4] PACKAGING: 1 EA. RECEPTACLE PER RESEALABLE PLASTIC BAG. RUBBER WASHER IS BULK-PACKAGED. LABEL ON SHIPPING CONTAINER INCLUDES SOURIAU P/N & QTY. 7. UL1977 RECOGNIZED. 8 MOLDING "VOID CORES" ARE INDICATED "X". 9 PANEL CUTOUT IF APPLICABLE: TAP DRILL 23/32 OR .719 INCH (18.3mm). NPT-1/2 THREAD. SCALE 1:1 SCALE 1:1 B RELEASED PER ECN 11721 A RELEASED PER ECN 11483 REV DESCRIPTION RSK 05-16-12 RSK 08-11-11 NPP 05-16-12 NPP 08-11-11 BY DATE CHKD DATE DRAWING TITLE UTS RECEPTACLE, SIZE-14, NPT-1/2 CAT NO. UTS7142G1SNPT Client Drawing Approval X Option LINEAR Authorized SignatureMEASURE: THIRD ANGLE PROJECTION & Date CAGE NO: 09922 SIZE: B APPROVAL THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. 1/2-NPT 6 Approved with no Exceptions Approved with Exceptions Noted TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES INCH [mm] Rejected ONE PLACE #.1 [ #3] The signature above indicates the client's authorized representative has TWO PLACES #0.02 [ #.5] reviewed, understands, and concurrs with the requirements defined herein If no signature is provided, placement of a purchase order by the THREE PLACES #0.010 [ #.25] client is considered drawing acceptance. ANGLES #1 $ Revision/Resubmission Required SCALE 2:1 2 Company Name CUSTOMER INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. DRAWN: CHKD : DSGN : MFG : QC : DRAWING DRAWING NP NP DH BB SCALE: NO. 1 4/19/10 4/19/10 4/19/10 5:2 REV B S99544 www.souriau.com 4/19/10 - 1 OF 1 PRO-E A
UTS7142G1SNPT 价格&库存
很抱歉,暂时无法提供与“UTS7142G1SNPT”相匹配的价格&库存,您可以联系我们找货
