MPSL-1100-18-DSE-9GK 数据手册
8
7
4
5
6
1
2
3
REVISIONS
1.900±.010 48.26±0.25
F
NO EAR ON
HIGHER POSITION SIDE
1.700±.010 43.18±0.25
.125 3.18
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
559
INITIAL RELEASE
3/3/2005
AN
B
744
SHOW BAR STANDOFFS ON EARS, UPDATE
INSULATOR P/N TO C18X-P330
09/29/05
MNH
C
944
CHANGED CARDSLOT CHAMFERS TO
PROTECT THE PINS FROM DAMAGE, AND
INSULATOR FROM P330 TO P340
2/28/2006
TT
D
984
CHANGE CONTACT PIN TO V115, CHANGE
BODY FROM P340 TO P40
04/24/06
MNH
F
.075 1.91
WIDTH CARDSLOT
.100 2.54 CC.
E
E
2.375±.020 60.33±0.51
2.075±.015 52.71±0.38
1
A
.330 8.38
BODY WIDTH
.265 6.73
INSERTION DEPTH
.431 10.95
D
D
.220 5.59
.225±.025 5.71±0.64
TAIL LENGTH
A
2
.110 2.79
CONTACT POINT
SECTION A-A
FORMED TO FIT
.062" PCB
C
B
A
C
NOTES:
1. THIS SPECIFICATION COVERS THE REQUIREMENTS FOR A DUAL ROW 18 POSITION
EDGECARD CONNECTOR
2. INSULATOR MATERIAL: PPS
3. CONTACT MATERIAL: PHOSPHOR BRONZE.
4. PLATING: .000030” GOLD ON CONTACT SURFACE.
.000100” PURE TIN, MATTE ON TERMINAL.
.000050” NICKEL UNDERPLATE.
5. OPERATING TEMPERATURE: -65°C TO +125°C.
6. PROCESSING TEMPERATURE: 260°C MAX FOR 120 SECS MAX.
7. UL FLAMABILITY RATING: 94V-0
8. DIELECTRIC WITHSTANDING VOLTAGE: 600 VDC MIN. AT SEA LEVEL
9. CURRENT RATING: 3 AMP
10. VOLTAGE DROP: 30 MILLIVOLT AT RATED CURRENT.
11. INSULATION RESISTANCE: 5000 MEGOHMS @ 500 VDC.
12. CONNECTOR IDENTIFICATION: PART SHALL BE MARKED WITH PART NUMBER AND
DATE CODE.
13. ACCOMMODATES BOARD THICKNESS .054 TO .070 INCH THICK.
14. BOARD INSERTION FORCE: 16 Oz MAX. PER CONTACT PAIR USING .062 PCB
15. BOARD WITHDRAWL FORCE: 1 Oz MIN. PER CONTACT PAIR USING .062 PCB.
16. MODIFICATION: CARD EXTENDER BEND FOR LOW PROFILE CONNECTOR, .055"
INSIDE DIMENSION FOR .062" PCB, MOUNTING EAR ON POSITION 1 SIDE, NO
MOUNTING EAR ON HIGH NUMBER SIDE.
B
REFERENCE: RCC18DRVH-P64
7
6
E_C-V115
CONTACT PIN
10702
1
C18X-P40
INSULATOR, .100 CC, L.P., MP
10423
1
ITEM
PART NO
DESCRIPTION
DWG NO
QTY.
36
BILL OF MATERIALS
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES[MM]
TOLERANCES:
ANGULAR: 1
.XX= .02 [.508]
.XXX= .005 [.1270]
.XXXX= .0005 [.0127]
PARENTHETICAL INFORMATION IS FOR
REFERENCE ONLY
RoHS COMPLIANT
8
2
5
4
DATE
DRAWN
SULLINS
ELECTRONICS
NAME
Aria. N
DESCRIPTION
EDGECARD CONNECTOR
PART NO. :MPSL-1100-18-DSE-9GK
SIZE DWG. NO.
C
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5-1984
3
6/28/2006
THE INFORMATION HERIN CONTAINS
PROPIETARY RIGHTS OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY
SULLINS ELECTRONICS.
REV
10428
SCALE: 3:1
2
D
SHEET 1 OF 1
1
FILE NAME: Z:\Components\Part Assemblies\MICROPLASTIC_ASSEMBLIES\10428, MPSL-1100-18-DSE-9GK_(RCC18DRVH-P64)
A
MPSL-1100-18-DSE-9GK 价格&库存
很抱歉,暂时无法提供与“MPSL-1100-18-DSE-9GK”相匹配的价格&库存,您可以联系我们找货
