GBB60DHAD-S793
GBB60DHAD-S793
    SULLINS
    CONN EDGECARD 120PS DIP .050 R/A
GBB60DHAD-S793 数据手册
Sullins Edgecards .050” [1.27 mm] Contact Centers, .915” [23.23 mm] Insulator Height Right Angle SPECIFICATIONS Sullins Edgecards • • • • • • Accommodates .062” ± .008” [1.57 ± .20] PC board PPS or PA9T insulator Molded-in key available High reliability/high cycle hairpin bellows contact 1 amp current rating per contact 150 grams normal force minimum READOUT TERMINATION TYPE .595 [15.11] .100, 3 PLS. (HA) .100 [2.54] (HB) .170 [4.82] DUAL (D) PCB LAYOUT A .100 [2.54], 3 PLS PIN 1 .040 [1.02] MINIMUM .100 [2.54] .050 [1.27] .104 [2.64] FOR R MOUNTING .410 [10.41] .050 [1.27] .125 [3.18] FOR S MOUNTING F D PCB LAYOUT, COMPONENT SIDE MOUNTING STYLE Ø.125 [3.18] Ø.125 [3.18] .250[6.35] .174[4.41] Board Lock (R) SIDE MOUNTING (S) (with no mounting ears) 14 .250[6.35] NO MOUNTING EARS (N) CLEARANCE HOLE (D) #4-40 .250 [6.35] THREADED INSERT ( www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Sullins Edgecards .050” [1.27 mm] Contact Centers, .915” [23.23 mm] Insulator Height Right Angle PART NUMBER CODING G B B 10 D HA S - Sxxx MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze H = PBT/Beryllium Copper G = PA9T/Phosphor Bronze R = PPS/Phosphor Bronze J = PA9T/Beryllium Copper A = PPS/Beryllium Copper CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface Termination B = .000010” Gold .000100” Pure Tin, Matte C = .000030” Gold .000100” Pure Tin, Matte Sullins Edgecards MOUNTING STYLE (Opposite Page) S = Side Mounting D = Flush Mounting N = No Mounting T = Flush Mounting With Threaded Insert R = Metal Board Lock TERMINATION TYPE (Opposite Page) HA = .100” Staggered Dip Solder, Right Angle HB = .170” Staggered Dip Solder, Right Angle READOUT (Opposite Page) D = Dual CONTACT CENTERS B = .050” [1.27mm] NUMBER OF CONTACT POSITIONS See Chart Below DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. A1 (S) MOUNTING SHOWN E D B A2 Ø .125 [3.18], 4 PLS .370 [9.40] .915 [23.23] B1 .018 x .012 [0.46 x 0.31] POST REFER TO TERM. TYPE B2 A .300 [7.62] INSERTION DEPTH .360 [9.14] C .250 [6.35] .610 [15.49] .050 CC [1.27] F R .030[.76] MAX. .040[1.02] MAX. .250[6.35] MIN. .050[1.27] A .300[7.62] MIN. .080[2.03] MAX. 30° .062±.008 [1.57±.20] -.006 MAX. - .15 MAX. - .28 MIN. .030 [.76] B -.011 MIN. CARD LAYOUT POSITIONS/ CONTACTS 05/10 06/12 09/18 10/20 13/26 14/28 15/30 20/40 22/44 24/48 25/50 30/60 34/68 35/70 40/80 45/90 50/100 55/110 60/120 64/128 65/130 66/132 70/140 75/150 80/160 85/170 90/180 95/190 100/200 105/210 108/216 110/220 120/240 INCHES A ±.005 0.200 0.250 0.400 0.450 0.600 0.650 0.700 0.950 1.050 1.150 1.200 1.450 1.650 1.700 1.950 2.200 2.450 2.700 2.950 3.150 3.200 3.250 3.450 3.700 3.950 4.200 4.450 4.700 4.950 5.200 5.350 5.450 5.950 B ±.005 0.300 0.350 0.500 0.550 0.700 0.750 0.800 1.050 1.150 1.250 1.300 1.550 1.750 1.800 2.050 2.300 2.550 2.800 3.050 3.250 3.300 3.350 3.550 3.800 4.050 4.300 4.550 4.800 5.050 5.300 5.450 5.550 6.050 C ±.015 0.490 0.540 0.690 0.740 0.890 0.940 0.990 1.240 1.340 1.440 1.490 1.740 1.940 1.990 2.240 2.490 2.740 2.990 3.240 3.440 3.490 3.540 3.740 3.990 4.240 4.490 4.740 4.990 5.240 5.490 5.640 5.740 6.240 D E ±.010 ±.020 0.776 1.090 0.826 1.140 0.976 1.290 1.026 1.340 1.176 1.490 1.226 1.540 1.276 1.590 1.526 1.840 1.626 1.940 1.726 2.040 1.776 2.090 2.026 2.340 2.226 2.540 2.276 2.590 2.526 2.840 2.776 3.090 3.026 3.340 3.276 3.590 3.526 3.840 3.726 4.040 3.776 4.090 3.826 4.140 4.026 4.340 4.276 4.590 4.526 4.840 4.776 5.090 5.026 5.340 5.276 5.590 5.526 5.840 5.776 6.090 5.926 6.240 6.026 6.340 ‘N’ Mounting Only F ±.010 0.350 0.400 0.550 0.600 0.750 0.800 0.850 1.100 1.200 1.300 1.350 1.600 1.800 1.850 2.100 2.350 2.600 2.850 3.100 3.300 3.350 3.400 3.600 3.850 4.100 4.350 4.600 4.850 5.100 5.350 5.500 5.600 6.100 A ±.13 5.08 6.35 10.16 11.43 15.24 16.51 17.78 24.13 26.67 29.21 30.48 36.83 41.91 43.18 49.53 55.88 62.23 68.58 74.93 80.01 81.28 82.55 87.63 93.98 100.33 106.68 113.03 119.38 125.73 132.08 135.89 138.43 151.13 B ±.13 7.62 8.89 12.70 13.97 17.78 19.05 20.32 26.67 29.21 31.75 33.02 39.37 44.45 45.72 52.07 58.42 64.77 71.12 77.47 82.55 83.82 85.09 90.17 96.52 102.87 109.22 115.57 121.92 128.27 134.62 138.43 140.97 153.67 [MILLIMETERS] C D E ±.38 ±.25 ±.51 12.45 19.71 27.69 13.72 20.98 28.96 17.53 24.79 32.77 18.80 26.06 34.04 22.61 29.87 37.85 23.88 31.14 39.12 25.15 32.41 40.39 31.50 38.76 46.74 34.04 41.30 49.28 36.58 43.84 51.82 37.85 45.11 53.09 44.20 51.46 59.44 49.28 56.54 64.52 50.55 57.81 65.79 56.90 64.16 72.14 63.25 70.51 78.49 69.60 76.86 84.84 75.95 83.21 91.19 82.30 89.56 97.54 87.38 94.64 102.62 88.65 95.91 103.89 89.92 97.18 105.16 95.00 102.26 110.24 101.35 108.61 116.59 107.70 114.96 122.94 114.05 121.31 129.29 120.40 127.66 135.64 126.75 134.01 141.99 133.10 140.36 148.34 139.45 146.71 154.69 143.26 150.52 158.50 145.80 153.06 161.04 158.50 ‘N’ Mounting Only www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com F ±.25 8.89 10.16 13.97 15.24 19.05 20.32 21.59 27.94 30.48 33.02 34.29 40.64 45.72 46.99 53.34 59.69 66.04 72.39 78.74 83.82 85.09 86.36 91.44 97.79 104.14 110.49 116.84 123.19 129.54 135.89 139.70 142.24 154.94 15
GBB60DHAD-S793 价格&库存
很抱歉,暂时无法提供与“GBB60DHAD-S793”相匹配的价格&库存,您可以联系我们找货
