UTS6JC183G1S
UTS6JC183G1S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN HSG PLUG 4POS INLINE SKT
UTS6JC183G1S 数据手册
1 2 DWG. NO. NOTES: S99696 1. THIS DRAWING IS A CONTROLLED DOCUMENT FOR SOURIAU USA, INC. IT IS SUBJECT TO CHANGE WITHOUT NOTIFICATION. CONTACT THE DOCUMENT CONTROL CENTER FOR THE LATEST REVISION. 3.15 [80.0] MATES WITH UTS7183G1P___ 2. USES 1-TO-4 EA. SIZE-8, 3.6mm SOCKETS (CONTACTS ORDERED SEPARATELY) CONTACT TYPE: REFER TO SOURIAU BSD202333001 1.56 [39.5] 3. MATERIALS 3.1 PLUG: COUPLING& INSULATOR: POLYAMIDE UL94V0, COLOR-BLACK 3.2 ALL MATERIALS ARE RoHS COMPLIANT. 4. 4.1 4.2 4.3 4.4 CABLE RANGE 7-16mm WITH REDUCING SEAL MECHANICAL PERFORMANCE. OPERATING TEMPERTURE: -40 TO 105$C CORROSION: SALT SPRAY, 500 HOUR DURABILTY: 250 MATE-UNMATE CYCLES SEALING IN MATED CONDITION: IEC 60529-IP68: 10M WATER, 1-WEEK; -IP69K: HIGH-PRESSURE WATER, DIN 40050 B 5. ELECTRICAL PERFORMANCE 5.1 DIELECTRIC WITHSTANDING VOLTAGE / INSULATION RESISTANCE 2200 VRMS MAX. BETWEEN CIRCUITS / 5000 MOhm MIN. @ 500 VDC 5.2 OPERATING VOLTAGE: 600 VAC MAX. 5.3 CIRCUIT USE: B,C,D: 44 AMP AC MAX; A: GROUND: FIRST MATE LAST BREAK 6 7. SCALE 2:1 PACKAGING: LABEL INCLUDES SOURIAU P/N & QTY. UL 1977 RECOGNIZED. KEY ORIENTATION MARKING, COLOR WHITE. BACKSHELL ASSEMBLY 9. UNITED STATED PATENT 7,955,125 C REVISED PER ECN 11550 B REVISED PER ECN 11503 A RELEASED PER ECN 11468 REV DESCRIPTION NPP NPP 11-03-11 11-03-11 RSK NPP 09-08-11 09-08-11 SCP NPP 07-18-11 07-18-11 BY DATE CHKD DATE DRAWING TITLE UTS CABLE PLUG, SIZE-18, 4X SIZE-8 SOCKET CAT NO. UTS6JC183G1S Client Drawing Approval X Option LINEAR Authorized SignatureMEASURE: THIRD ANGLE PROJECTION & Date CAGE NO: 09922 SIZE: B APPROVAL THE INFORMATION CONTAINED IN THIS DRAWING IS CONFIDENTIAL AND MAY NOT BE DISCLOSED WITHOUT WRITTEN CONSENT FROM SOURIAU USA, INC. PLUG Approved with no Exceptions Approved with Exceptions Noted TOLERANCES UNLESS OTHERWISE SPECIFIED No. OF PLACES INCH [mm] Rejected ONE PLACE #.1 [ #3] The signature above indicates the client's authorized representative has TWO PLACES #0.02 [ #.5] reviewed, understands, and concurrs with the requirements defined herein If no signature is provided, placement of a purchase order by theTHREE PLACES #0.010 [ #.25] client is considered drawing acceptance. ANGLES #1 $ Revision/Resubmission Required 2 Company Name CUSTOMER INTERPRET THIS DRAWING IN ACCORDANCE WITH ASME Y14.5M - 1994. DRAWN: CHKD : DSGN : MFG : QC : DRAWING DRAWING 07-06-11 SCP 07-06-11 NPP 07-06-11 NPP 07-06-11 DH 07-06-11 BB SCALE: 3:2 NO. REV C S99696 www.souriau.com 1 1 OF 1 PRO-E A
UTS6JC183G1S 价格&库存
很抱歉,暂时无法提供与“UTS6JC183G1S”相匹配的价格&库存,您可以联系我们找货
