DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
REVISION B
MCPK-8-X
PLUG KIT
SIZE
CN-30-8
END
(SEE NOTE 7)
-T: TERMINAL
-S: SOCKET
CC-30-8
CG-30-8
SPC-30-8
SUB-MCR-8-12
12 POSITION
-S: SOCKET
FIG 1
MCPK-8-S SHOWN
ALIGNMENT ARROW
37.30 1.469 REF
01
DO NOT
SCALE FROM
THIS PRINT
03
CN-30-8
07
04
CC-30-8
10
08
CG-30-8
15.00 .591 REF
12
11
SPR-30-8
12 POSITION
-T: TERMINAL
ALIGNMENT ARROW
CR-30-8
39.50 1.555 REF
03
01
SUB-MCP-8-12
FIG 2
MCPK-8-T SHOWN
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. COMPONENTS TO BE PACKAGED PER PACKAGING STANDARDS, REFERENCE PACKAGING MANUAL.
3. TORQUE SPECIFICATION FOR CN-30-8 (CABLE NUT): 0.5 Nm [4.4 IN-LBS]
4. CABLE DIAMETER RANGE SPECIFICATION: 6.20[.244] - 7.00[.276]
5. -T (TERMINAL): REFERENCE DCA-MCP-8 PRINT FOR TERMINAL DUSTCAP
-S (SOCKET): REFERENCE DCA-MCR-8 PRINT FOR SOCKET DUSTCAP
6. PLACE HDRL-07 (LABEL) ON BAG. LABEL TO HAVE THE FOLLOWING
PRINTED IN ARIAL FONT SIZE 9:
LINE 1 - "FOR ASSEMBLY INSTRUCTIONS SEE"
LINE 2 - "WWW.SAMTEC.COM/MCPKFTK"
LINE 3 - PART NUMBER "XXXXXX"
LINE 4 - SHOP ORDER NUMBER "XXXXXXX"
7. -T (TERMINAL): REFERENCE TC114-XXXX-X-X PRINT FOR TERMINALS.
-S (SOCKET): REFERENCE CC393-XXXX-X-X PRINT FOR CONTACTS.
04
07
08
10
12
11
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
ANGLES
X.X: 0.3 [.01]
2
X.XX: 0.13 [.005]
X.XXX: 0.051 [.0020]
MATERIAL:
15.50 .610 REF
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATORS, CABLE NUT, C-RING: PPS
GASKET, O-RING: SILICONE
SPRING: STAINLESS STEEL
COUPLING RING, SPACER: PBT
CABLE CLAMP: POM
c:\enterprisevault\DWG\MISC\MKTG\MCPK-8-X-MKT.SLDDRW
SHEET SCALE: 1:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
MINI CIRC. CABLE KIT
DWG. NO.
MCPK-8-X
BY: J. BORGELT
4/15/13
SHEET 1 OF 1
很抱歉,暂时无法提供与“MCPK-8-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+59.815191+7.77578
- 25+54.0401925+7.02505
- 50+52.1412050+6.77819
