8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
E
2536
UPDATE PROCESSING TEMPERATURE
03/02/2012
LH
F
2740
REPLACE NYLON 46 WITH NYLON 9T, UPDATED
NOTES, CARD SLOT WIDE 1.80mm(WAS 1.77mm) & 04/30/2013
DIMENSION TABLE TOLERANCES
LH
F
F
1.73±0.08 .068±.003
11.65 .459
PIN A1
IDENTIFIER
E
B
A
1.50 .059
1.80±0.15 .071±.006
1.00 .039 TYP.
7.45 .293
PIN A1
CL
PIN B1
E
8.85 .348
1.50 .059
10.00±0.15 .394±.006
14.50 .571
D
5.10 .201
C
0.90 .035
3.75 .148 MAX.
A
1.50 .059 MAX.
D
3.75 .148
7.85 .309
11.25 .443 MAX.
0.80 .031
15.60 .614
4.40 .173
3.40 .134
C
A
0.34 .013
2.00 .079
1.25 .049
1.65 .065
C
2X 1.20 .047
1.00 .039 TYP.
1.35 .053
2X
TAIL LENGTH
(SEE PART NUMBER CODING)
+0.25
+.010
Tol. .XX - 0.13 .XXX - .005
3.25 .128
SECTION A-A
B
NOTES:
1. INSULATOR MATERIAL: NYLON 9T, UL 94V-0.
14.65 .577
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 1.1 AMP PER CONTACT.
5. VOLTAGAE RATING 50 VAC.
6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 30 MILLI OHMS MAX.
8. DIELECTRIC WITHSTANDING: 500 VAC.
9. INSERTION FORCE: 117.3gf (1.15 N) MAX PER CONTACT PAIR USING A 1.70 mm (.067") STEEL CARD.
10. WITHDRAWAL FORCE: 15.31gf (0.15 N) MIN PER CONTACT PAIR USING A 1.44 mm (.057") STEEL CARD.
11. OPERATING TEMPERATURE: -10° C TO +85° C.
12. PROCESSING TEMP: 260° C FOR 10 SEC. MAX.
A
B
D
DRAWN
Pb
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN MM[INCHES]
NAME
03/09/2009
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TOLERANCES:
ANGULAR:
DATE
3
DECIMALS
.X= 0.35 [.014]
.XX= 0.25 [.010]
.XXX= 0.08 [.0031]
TITLE
PCI EXPRESS, 1mm CC, DIP SOLDER(GEN 1)
PART NUMBER
SIZE
C
7
6
5
4
3
2
_ _E_ _DHHN-T9_1
CAGE CODE
54453
SCALE: 3.5:1
8
2.15±0.05 .085±.002
DWG. NO.
11045
REV
F
SHEET 1 OF 2
1
FILE NAME: Z:\ECO PENDING\2740, PCI E -- REMOVE NYLON 46, DWG 11205, 11045, 11042, 11043, 11044\11045-F\11045, N(G)_E_ _DHHN-T9_ _ PRINT: 10/31/2013
A
8
7
4
5
6
1.90±0.06 .075±.002
1
2
3
-X-
1.50 .059
0.70 .028 TYP.
F
F
1.50 .059
0.10[.004] W X
B PIN #1
1.00 .039 TYP.
E
8.40 .331 MIN
3.20 .126 REF.
5.60 .220
E
2.40 .094 PIN "G" SEE TABLE
-W-
10.00 .394
A
12.15 .478
0.50[.020] X 45 TYP
F
I/O PANEL DIRECTION
PRIMARY (COMPONENT) SIDE
D
1.57±0.13 .062±.005
D
A PIN #1
D
10.00 .394
2X
A
2.35±0.05 .093±.002
0.10[.004]
1.65 .065
1.35 .053
C
A PIN #1
4.20 .165
C
1.25 .049
3.25 .128
B PIN #1
1.57 .062
B
I/O PANEL DIRECTION
SECONDARY (SOLDER) SIDE
1.40 .055
0.70±0.08 .028±.003
1.00 .039 TYP
0.10[.004]
B
ADD-IN CARD EDGE-FINGER DIMENSIONS
RECOMMENDED PCB LAYOUT
(TOLERANCE: 0.05[.002])
20.0°±2°
DETAIL A
SCALE 10 : 1
DRAWN
Pb
A
RoHS COMPLIANT
8
7
6
5
4
NAME
03/09/2009
JH
TOLERANCES:
ANGULAR:
DATE
3
DECIMALS
.X= 0.35 [.014]
.XX= 0.25 [.010]
.XXX= 0.08 [.0031]
TITLE
PART NUMBER
SIZE
C
3
_ _E_ _DHHN-T9_1
CAGE CODE
54453
DWG. NO.
11045
SCALE: 2:1
SHEET 2 OF 2
2
1
REV
F
A
很抱歉,暂时无法提供与“GWE18DHHN-T931”相匹配的价格&库存,您可以联系我们找货
