8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
B
2069
C
BY
LH
F
LH
+0.20 +.008
B - 0.15 , - .006
1.73±0.08 .068±.003
A 0.15[.006]
11.65±0.25 .459±.010
E
2740
DESCRIPTION
DATE
ADD I/O PANEL SECONDARY SIDE VIEW AND
TABLE"G", UPDATE DRAWING AND TABLE OF
05/17/2010
TOLERANCE
ADD CAP ON PARTS AND UPDATE SHAPE, 3 - VIEWS
& NOTES, CARD SLOT WIDE 1.80mm(WAS 1.77mm)
& 1.73mm(WAS 1.78mm, BETWEEN BOTH CARD
04/18/2013
SLOT THICKNESS), CANCEL DIMENSION TABLE
TOLERANCES, SHOW ON THE TOP VIEW.
E
1.00 .039 TYP.
10.00±0.15 .394±.006
CL
PIN A1
15.00 .591
7.45 .293 8.95 .352
PIN B1
1.50 .059
1.80±0.15 .071±.006
D
11.00 .433
5.93 .233
7.00 .276
1.50 .059
A
14.50 .571
0.90 .035
D
6.80 .268
7.62 .300
11.90 .469
10.90 .429
0.10[.004]
4.10 .161
C
1.35 .053
0.34 .013
1.65 .065
SECTION A-A
1.00 .039
A
2X
1.00±0.10 .039±.004
8.65 .341
C
C
3.50 .138
B
NOTES:
1. INSULATOR MATERIAL: NYLON 9T, UL 94V-0, COLOR: BLACK.
D
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: SEE PART NUMBER CODING.
E
4. CURRENT RATING: 1.1 AMP PER CONTACT.
5. VOLTAGE RATING: 50 VAC.
6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 30 MILLI OHMS MAX.
8. DIELECTRIC WITHSTANDING: 500V AC.
9. OPERATING TEMPERATURE:-10 C TO +85 C.
10. PROCESSING TEMP.: 260° C FOR 10 SECS MAX.
11. INSERTION FORCE: 117gf (1.15 N) MAX PER CONTACT PAIR USING A 1.70 mm (.067") STEEL CARD.
12. WITHDRAWAL FORCE: 15gf (0.15 N) MIN PER CONTACT PAIR USING A 1.44 mm (.057") STEEL CARD.
B
DRAWN
Pb
A
RoHS COMPLIANT
8
7
6
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN MM[INCHES]
NAME
02/05/09
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TOLERANCES:
ANGULAR:
DATE
3'
DECIMALS
.X= 0.35 [.014]
.XX= 0.25 [.010]
.XXX= 0.08 [.0031]
TITLE
PART NUMBER
SIZE
C
3
A
PCI EXPRESS, 1mm CC, SMT
G_E_ _DHFN-T951
CAGE CODE
54453
DWG. NO.
11205
SCALE: 3:1
SHEET 1 OF 2
2
1
REV
C
FILE NAME: Z:\ECO PENDING\2740, PCI E -- REMOVE NYLON 46, DWG 11205, 11045, 11042, 11043, 11044\11205-C\11205, G_E_ _DHFN-T951 PRINT: 10/31/2013
8
7
4
5
6
1
2
3
1.80 .071
A
2X 4.50 .177
F
9.20 .362
PIN A1
1.20±0.05 .047±.002
F
1.00 .039 TYP.
4.60 .181
CL
5.20 .205
1.65 .065
2.00 .079
E
2X
10.00 .394
5.00 .197
0.70±0.05 .028±.002
E
1.35 .053
3.00 .118
D
H
RECOMMENDED PCB LAYOUT
D
D
1.90±0.05 .075±.002
1.50 .059
1.50 .059
PIN A1
1.00 .039
3.20 .126
0.70±0.05 .028±.002 TYP
PIN B1
3.20 .126
C
8.40 .331
5.60 .220
C
2.40 .094
10.00 .394
PIN "G" SEE TABLE
A
12.15±0.10 .478±.004
2.40 .094
F
B
20.0°±5°
I/O PANEL DIRECTION .
SECONDARY (SOLDER) SIDE
B
I/O PANEL DIRECTION
PRIMARY (COMPONENT) SIDE
1.40 .055
1.57±0.13 .062±.005
DETAIL A
SCALE 10 : 1
Pb
A
RoHS COMPLIANT
8
7
6
5
4
TOLERANCES:
ANGULAR:
3'
DECIMALS
.X= 0.35 [.014]
.XX= 0.25 [.010]
.XXX= 0.08 [.0031]
DRAWN
DATE
NAME
02/05/09
JH
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 1:5
3
2
A
G_E_ _DHFN-T951
DWG. NO.
11205
SHEET 2 OF 2
1
REV
C
FILE NAME: 11205, G_E_ _DHFN-T951
很抱歉,暂时无法提供与“GBE18DHFN-T951”相匹配的价格&库存,您可以联系我们找货
