GBE82DHHN-T931
GBE82DHHN-T931
    SULLINS
    CONN EDGECARD 164POS 1MM
GBE82DHHN-T931 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY E 2536 UPDATE PROCESSING TEMPERATURE 03/02/2012 LH F 2740 REPLACE NYLON 46 WITH NYLON 9T, UPDATED NOTES, CARD SLOT WIDE 1.80mm(WAS 1.77mm) & 04/30/2013 DIMENSION TABLE TOLERANCES LH F F 1.73±0.08 .068±.003 11.65 .459 PIN A1 IDENTIFIER E B A 1.50 .059 1.80±0.15 .071±.006 1.00 .039 TYP. 7.45 .293 PIN A1 CL PIN B1 E 8.85 .348 1.50 .059 10.00±0.15 .394±.006 14.50 .571 D 5.10 .201 C 0.90 .035 3.75 .148 MAX. A 1.50 .059 MAX. D 3.75 .148 7.85 .309 11.25 .443 MAX. 0.80 .031 15.60 .614 4.40 .173 3.40 .134 C A 0.34 .013 2.00 .079 1.25 .049 1.65 .065 C 2X 1.20 .047 1.00 .039 TYP. 1.35 .053 2X TAIL LENGTH (SEE PART NUMBER CODING) +0.25 +.010 Tol. .XX - 0.13 .XXX - .005 3.25 .128 SECTION A-A B NOTES: 1. INSULATOR MATERIAL: NYLON 9T, UL 94V-0. 14.65 .577 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 1.1 AMP PER CONTACT. 5. VOLTAGAE RATING 50 VAC. 6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 30 MILLI OHMS MAX. 8. DIELECTRIC WITHSTANDING: 500 VAC. 9. INSERTION FORCE: 117.3gf (1.15 N) MAX PER CONTACT PAIR USING A 1.70 mm (.067") STEEL CARD. 10. WITHDRAWAL FORCE: 15.31gf (0.15 N) MIN PER CONTACT PAIR USING A 1.44 mm (.057") STEEL CARD. 11. OPERATING TEMPERATURE: -10° C TO +85° C. 12. PROCESSING TEMP: 260° C FOR 10 SEC. MAX. A B D DRAWN Pb RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] NAME 03/09/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TOLERANCES: ANGULAR: DATE 3 DECIMALS .X= 0.35 [.014] .XX= 0.25 [.010] .XXX= 0.08 [.0031] TITLE PCI EXPRESS, 1mm CC, DIP SOLDER(GEN 1) PART NUMBER SIZE C 7 6 5 4 3 2 _ _E_ _DHHN-T9_1 CAGE CODE 54453 SCALE: 3.5:1 8 2.15±0.05 .085±.002 DWG. NO. 11045 REV F SHEET 1 OF 2 1 FILE NAME: Z:\ECO PENDING\2740, PCI E -- REMOVE NYLON 46, DWG 11205, 11045, 11042, 11043, 11044\11045-F\11045, N(G)_E_ _DHHN-T9_ _ PRINT: 10/31/2013 A 8 7 4 5 6 1.90±0.06 .075±.002 1 2 3 -X- 1.50 .059 0.70 .028 TYP. F F 1.50 .059 0.10[.004] W X B PIN #1 1.00 .039 TYP. E 8.40 .331 MIN 3.20 .126 REF. 5.60 .220 E 2.40 .094 PIN "G" SEE TABLE -W- 10.00 .394 A 12.15 .478 0.50[.020] X 45 TYP F I/O PANEL DIRECTION PRIMARY (COMPONENT) SIDE D 1.57±0.13 .062±.005 D A PIN #1 D 10.00 .394 2X A 2.35±0.05 .093±.002 0.10[.004] 1.65 .065 1.35 .053 C A PIN #1 4.20 .165 C 1.25 .049 3.25 .128 B PIN #1 1.57 .062 B I/O PANEL DIRECTION SECONDARY (SOLDER) SIDE 1.40 .055 0.70±0.08 .028±.003 1.00 .039 TYP . 0.10[.004] B ADD-IN CARD EDGE-FINGER DIMENSIONS RECOMMENDED PCB LAYOUT (TOLERANCE: 0.05[.002]) 20.0°±2° DETAIL A SCALE 10 : 1 DRAWN Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] NAME 03/09/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TOLERANCES: ANGULAR: DATE 3 DECIMALS .X= 0.35 [.014] .XX= 0.25 [.010] .XXX= 0.08 [.0031] TITLE PCI EXPRESS, 1mm CC, DIP SOLDER(GEN 1) PART NUMBER SIZE C 3 _ _E_ _DHHN-T9_1 CAGE CODE 54453 DWG. NO. 11045 SCALE: 2:1 SHEET 2 OF 2 2 1 REV F FILE NAME: Z:\ECO PENDING\2740, PCI E -- REMOVE NYLON 46, DWG 11205, 11045, 11042, 11043, 11044\11045-F\11045, N(G)_E_ _DHHN-T9_ _ PRINT: 10/31/2013 A
GBE82DHHN-T931 价格&库存
很抱歉,暂时无法提供与“GBE82DHHN-T931”相匹配的价格&库存,您可以联系我们找货
