GWE140DHHN-T921
GWE140DHHN-T921
    SULLINS
    CONNPCIEXPFEMALE280POS0.039
GWE140DHHN-T921 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO E 2704 F 2740 F 11.65 .459 E 10.00 .394 (11 POSITION) PIN A1 IDENTIFIER PIN PIN PIN PIN D 1.73±0.08 .068±.003 38.27 1.507 91.65 3.608 37.00 1.457 (38 POSTION) 90.00 3.543 (91 POSITIONS) 1.50 .059 DATE ADD TAIL LENGTH OPTION 1(2.30mm) 12/10/2012 REPLACE NYLON 46 WITH NYLON 9T, REMOVE INSULATOR WHITE COLOR & UPDATED NOTES, TAIL 05/20/2013 LENGTH 3.10mm(WAS 3.00), ADD TAIL LENGTH & BOTTOM VIEW DIMENSION TOLERANCES BY LH LH F E 1.80±0.15 .071±.006 1.00 .039 TYP. 7.50 .295 MAX. 8.85 .348 A1 A2 B1 B2 CL 14.50 .571 1.73±0.08 .068±.003 D 131.65 5.183 0.90 .035 5.10 .201 11.25 .443 MAX. A 1.50 .059 MAX 3.75 .148 DESCRIPTION 3.75 .148 MAX. 7.85 .309 15.60 .614 0.80 .031 4.40 .173 C 1.35 .053 1.65 .065 0.34 .013 0.25 .010 3.25 .128 A 1.25 .049 2.00 .079 1.00 .039 TYP. C TAIL LENGTH (SEE PART NUMBER CODING) +0.25 +.010 X.XX - 0.13 .XXX - .005 2X 1.20 .047 149.00±0.30 5.866±.012 SECTION A-A 2.15±0.05 .085±.002 B 1.80 .071 B B 14.65 .577 40.00±0.15 1.575±.006 133.15±0.15 5.242±.006 A NOTES: 1. INSULATOR MATERIAL: NYLON 9T, UL 94V-0. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 1.1 AMP PER CONTACT. 5. VOLTAGE RATING: 50 VAC 6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 30 MILLI OHMS MAX. 8. DIELECTRIC WITHSTANDING: 500 VAC. 9. OPERATING TEMPERATURE: -10° C TO +85° C. 10. PROCESSING TEMP: 260° C FOR 10 SEC. MAX. 11. INSERTION FORCE: 117.3gf (1.15 N) MAX PER CONTACT PAIR USING A 1.70 mm (.067") STEEL CARD. 12. WITHDRAWAL FORCE: 15.31gf (0.15 N) MIN PER CONTACT PAIR USING A 1.44 mm (.057") STEEL CARD. 8 7 6 5 DETAIL B SCALE 4 : 1 DRAWN Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] NAME 06/24/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TOLERANCES: ANGULAR: DATE 3 DECIMALS .X= 0.35 [.014] .XX= 0.25 [.010] .XXX= 0.080 [.0031] 2.15 0.05[.085 .002] TITLE PCI EXPRESS, 1mm CC, 140P, DIP SOLDER(GEN 1) PART NUMBER SIZE C 3 2X _ _E140DHHN-T9_1 CAGE CODE 54453 DWG. NO. 11040 SCALE: 2:1 SHEET 1 OF 2 2 1 REV F FILE NAME: Z:\ECO PENDING\2740, PCI E -- REMOVE NYLON 46, DWG 11205, 11045, 11042, 11043, 11044\11040-F\11040, N(G)_E140DHHN-T9_ _ PRINT: 11/1/2013 A 8 7 4 5 6 1 2 3 1.90±0.06 .075±.002 -X1.90±0.06 .075±.002 -X- F F 1.50 .059 0.70±0.05 .028±.002 1.50 .059 0.10[.004] W X PIN B1 8.40 .331 5.60 .220 4.20 .165 -W- 1.00 .039 TYP E E 10.00 .394 12.15 .478 37.00 1.457 90.00 3.543 40.00 1.575 92.15 3.628 0.5[.020] X 45 TYP I/O PANEL DIRECTION PRIMARY (COMPONENT) SIDE D D PIN A1 C 144.30 5.681 I/O PANEL DIRECTION SECONDARY (SOLDER) SIDE C . 20.0°±5° 1.40 .055 C ADD-IN CARD EDGE-FINGER DIMENSIONS 1.57±0.13 .062±.005 133.15 5.242 130.00 5.118 10.00 .394 PIN A2 B 2.50 .098 2.00 .079 TYP 40.00 1.575 0.70±0.05 .028±.002 2.00 .079 2.00 .079 PIN A1 PIN B1 PIN B2 1.35 .053 1.65 .065 1.00 .039 TYP 1.35 .053 3X 1.65 .065 RoHS COMPLIANT 6 5 2.35±0.05 .093±.002 DRAWN Pb A 7 B 1.80 .071 RECOMMENDED PCB LAYOUT 8 DETAIL C SCALE 4 : 1 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] NAME 06/24/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TOLERANCES: ANGULAR: DATE 3 DECIMALS .X= 0.35 [.014] .XX= 0.25 [.010] .XXX= 0.080 [.0031] TITLE PCI EXPRESS, 1mm CC, 140P, DIP SOLDER(GEN 1) PART NUMBER SIZE C 3 _ _E140DHHN-T9_1 CAGE CODE 54453 DWG. NO. 11040 SCALE: 2:1 SHEET 2 OF 2 2 1 REV F FILE NAME: Z:\ECO PENDING\2740, PCI E -- REMOVE NYLON 46, DWG 11205, 11045, 11042, 11043, 11044\11040-F\11040, N(G)_E140DHHN-T9_ _ PRINT: 11/1/2013 A
GWE140DHHN-T921 价格&库存
很抱歉,暂时无法提供与“GWE140DHHN-T921”相匹配的价格&库存,您可以联系我们找货
