Male Card Edge
.100” [2.54 mm] Contact Centers, .540” [13.72 mm] Insulator Height,
Male Card Edge, Dip Solder/Right Angle/Card Extender
SPECIFICATIONS
Sullins Male Card Edge
Compatible with .431” [10.95 mm] or .610” [15.49 mm] Insulator Height Card Edges
Mates in place of .062” [1.57 mm] PC board
PBT, PA9T or PPS insulator
3 Amps current rating for one contact energized
30 milli Ohms maximum at rated current
Consult Factory for other Contact Centers
UL Flammability Rating: 94V-0
Operating/Processing Temperature
E = PBT & Phosphor Bronze
Operating Temperature: -65°C to + 125°C
Processing Temperature: Wave only
R = PPS & Phosphor Bronze
Operating Temperature: -65°C to + 150°C
Processing Temperature: 260°C Max. for 20 sec.
G = PA9T & Phosphor Bronze
A = PPS & Beryllium Copper
Operating Temperature: -65°C to + 200°C
Overall Gold Plating Only (Plating code 'S' or 'M')
TERMINATION TYPE
MA = .100” [2.54]
MV = .130” [3.30]
MB = .180” [4.57]
MD = .250” [6.35]
MJ = .500” [12.70]
MK = .560” [14.22]
MW = .125” [3.18]
MS = .190” [4.83]
MM = .560” [14.22]
FITS Ø
.043” [1.09]
.200”
[5.08]
DIP SOLDER (MW, MS)
WIRE WRAP (MM)
FITS Ø
.043” [1.09]
MR = .175” [4.45]
MN = .545” [13.84]
.150” [3.81]
.200” [5.08] (-S189 Modification)
ACCOMMODATES .062” [1.57] PCB
CARD EXTENDER
(MR, MN)
RIGHT ANGLE
(MA, MV, MB, MD, MJ, MK)
MOUNTING STYLE
2X Ø.125” [3.18]
4X Ø.125” [3.18]
.125” [3.18]
NO
MOUNTING
(N)
42
FLUSH with
CLEARANCE HOLES
(D)
FLUSH, SIDE MOUNTING
with CLEARANCE HOLES
(Z)
2X #4-40
2X #4-40
.125” [3.18]
FLUSH with
THREADED INSERT
(T)
FLUSH, with SIDE MOUNTED
THREADED INSERT
(V)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Male Card Edge
PART NUMBER OPTIONS
E B C 25 M MW D - Sxxx
MODIFICATIONS (Consult Factory)
OMIT FOR STANDARD
-S189 = .200” [5.08] Row Spacing (Right Angle Only)
MOUNTING STYLE
N = No Mounting
D = .250” Ears, Flush Mounting, .125” [3.18] Diameter
Z = .250” Ears, Flush, Side Mounting
T = .250” Ears, Flush Mounting, #4-40 Threaded Insert
V = Flush, Side Mounting, #4-40 Threaded Insert
TERMINATION TYPE
MW, MS = Dip Solder
MM = Wire Wrap
MA, MV, MB = Right Angle
MD, MJ, MK = Right Angle
MR, MN = Card Extender
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
B = .000010” Gold
C = .000030” Gold
Y = .000030” Gold
Contact Surface
S = .000010” Gold
M = .000030” Gold
Termination
.000100” Pure Tin, Matte
.000005” Gold
Overall Plating
.000010” Gold
.000010” Gold
M = Male Card Edge
NUMBER OF CONTACT POSITIONS
04 thru 60 Positions
(Contact factory for positions not shown.)
CONTACT CENTERS
C = .100” [2.54 mm]
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze
G = PA9T/Phosphor Bronze
R = PPS/ Phosphor Bronze
A = PPS/Beryllium Copper (Only 'S' or 'M' plating code)
Operating & Processing Temperature: See Opposite Page
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
(Dimension 'E'
for Mounting Style 'N' Only)
E
(Dimensions 'D' & 'C'
for Mounting Style 'D, Z, T, V' Only)
D
C
B
A
.540 [13.72]
.250 [6.35]
.370
[9.40]
REFER TO MOUNTING STYLE
POSITIONS/
CONTACTS
04/08
05/10
06/12
07/14
08/16
10/20
12/24
13/26
15/30
16/32
17/34
18/36
19/38
20/40
22/44
23/46*
24/48
25/50
26/52
28/56
30/60
31/62
32/64
34/68
35/70
36/72
40/80
43/86*
44/88*
49/98*
50/100
52/104*
55/110*
56/112*
57/114*
58/116*
59/118*
60/120
.030[ 0.76]
.025 [0.64] SQ.
.100 [2.54]
REFER TO TERMINATION TYPE
INCHES
MILLIMETERS
A±.008
B±.008
C±.010
D±.020
0.300
0.400
0.500
0.600
0.700
0.900
1.100
1.200
1.400
1.500
1.600
1.700
1.800
1.900
2.100
2.200
2.300
2.400
2.500
2.700
2.900
3.000
3.100
3.300
3.400
3.500
3.900
4.200
4.300
4.800
4.900
5.100
5.400
5.500
5.600
5.700
5.800
5.900
0.486
0.586
0.686
0.786
0.886
1.086
1.286
1.386
1.586
1.686
1.786
1.886
1.986
2.086
2.286
2.386
2.486
2.586
2.686
2.886
3.086
3.186
3.286
3.486
3.586
3.686
4.086
4.386
4.486
4.986
5.086
5.286
5.586
5.686
5.786
5.886
5.986
6.086
0.975
1.075
1.175
1.275
1.375
1.575
1.775
1.875
2.075
2.175
2.275
2.375
2.475
2.575
2.775
2.875
2.975
3.075
3.175
3.375
3.575
3.675
3.775
3.975
4.075
4.175
4.575
4.875
4.975
5.475
5.575
5.775
6.075
1.236
1.336
1.436
1.536
1.636
1.836
2.036
2.136
2.336
2.436
2.536
2.636
2.736
2.836
3.036
3.136
3.236
3.336
3.436
3.636
3.836
3.936
4.036
4.236
4.336
4.436
4.836
5.136
5.236
5.736
5.836
6.036
6.336
* Consult factory for availability.
‘N’ Mounting Only
E±.020 ‘N’
Mtg. Only
A±0.20
B±0.20
C±0.25
D±0.51
0.656
0.756
0.856
0.956
1.056
1.256
1.456
1.556
1.756
1.856
1.956
2.056
2.156
2.256
2.456
2.556
2.656
2.756
2.856
3.056
3.256
3.356
3.456
3.656
3.756
3.856
4.256
4.556
4.656
5.156
5.256
5.456
5.756
5.856
5.956
6.056
6.156
6.256
7.62
10.16
12.70
15.24
17.78
22.86
27.94
30.48
35.56
38.10
40.64
43.18
45.72
48.26
53.34
55.88
58.42
60.96
63.50
68.58
73.66
76.20
78.74
83.82
86.36
88.90
99.06
106.68
109.22
121.92
124.46
129.54
137.16
139.70
142.24
144.78
147.32
149.86
12.34
14.88
17.42
19.96
22.50
27.58
32.66
35.20
40.28
42.82
45.36
47.90
50.44
52.98
58.06
60.60
63.14
65.68
68.22
73.30
78.38
80.92
83.46
88.54
91.08
93.62
103.78
111.40
113.94
126.64
129.18
134.26
141.88
144.42
146.96
149.50
152.04
154.58
24.77
27.31
29.85
32.39
34.93
40.01
45.09
47.63
52.71
55.25
57.79
60.33
62.87
65.41
70.49
73.03
75.57
78.11
80.65
85.73
90.81
93.35
95.89
100.97
103.51
106.05
116.21
123.83
126.37
139.07
141.61
146.69
154.31
31.39
33.93
36.47
39.01
41.55
46.63
51.71
54.25
59.33
61.87
64.41
66.95
69.49
72.03
77.11
79.65
82.19
84.73
87.27
92.35
97.43
99.97
102.51
107.59
110.13
112.67
122.83
130.45
132.99
145.69
148.23
153.31
160.93
‘N’ Mounting Only
E±0.51 ‘N’
Mtg. Only
16.66
19.20
21.74
24.28
26.82
31.90
36.98
39.52
44.60
47.14
49.68
52.22
54.76
57.30
62.38
64.92
67.46
70.00
72.54
77.62
82.70
85.24
87.78
92.86
95.40
97.94
108.10
115.72
118.26
130.96
133.50
138.58
146.20
148.74
151.28
153.82
156.36
158.90
43
很抱歉,暂时无法提供与“EBC04MMVD-S189”相匹配的价格&库存,您可以联系我们找货
