EBA40DRYN-S13
EBA40DRYN-S13
    SULLINS
    CONNEDGEDUALFMALE80POS0.125
EBA40DRYN-S13 数据手册
Female Card Edge .125” [3.18 mm] Contact Centers, .431” [10.95 mm] Insulator Height, Dip Solder/Eyelet/Right Angle for .062” [1.57 mm] or .031” [0.79 mm] Mating PCB Sullins Female Card Edge SPECIFICATIONS • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board or .031” ± .006” [0.79 mm ± 0.15 mm] PC board • Molded-in key available • 3 Amps current rating for one contact energized • 30 milli Ohms maximum at rated current • UL Flammability Rating: 94V-0 READOUT POLARIZING KEY .265” [6.73] INSERTION DEPTH FULL BELLOWS PLA-K1 KEY IN BETWEEN CONTACTS (ORDER SEPARATELY) BACK-UP SPRINGS .230” [5.84] .030” [0.76] LETTER SIDE .200” [5.08] CONSULT FACTORY FOR MOLDED-IN KEY HALF LOADED (H) DUAL (D) TERMINATION TYPE EYELET ACCEPTS 3-#26 AWG .200” [5.08] (RT) .440” [11.19] (RY) .225” [5.72] .165” [4.19] (RJ) .185” [4.70] (RX) .140” [3.56] NARROW DIP SOLDER (RT, RY) .007” [0.18] THICK .250” [6.35] (RJ) .200” [5.08] (RX) FITS Ø .043” [1.09] WIDE DIP SOLDER (RJ, RX) EYELET (RE) .125” [3.18] .275” [6.98] .185” [4.70] .210” [5.33] (RE) .185” [4.70] (RT) .425” [10.80] (RY) .050” [1.27] NUMBER SIDE ACCEPTS .062” [1.57] PCB .014” [0.36] THICK CARD EXTENDER REQUIRES -S13 MODIFICATION CODE (RE,RT,RY TERMINATIONS ONLY) EYELET (TE) .156” [3.96] FITS Ø .043” [1.09] RIGHT ANGLE (RA) MOUNTING STYLE Ø.125” [3.18] CLEARANCE HOLE (H) 62 #4-40 THREADED INSERT(I) Ø.116” [2.95] CLEARANCE FOR #4 SCREW Ø.125” [3.18] .135” [3.43] FLOATING BOBBIN (F) NO MOUNTING EARS (N) SIDE MOUNTING (S) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .125” [3.18 mm] Contact Centers, .431” [10.95 mm] Insulator Height, Dip Solder/Eyelet/Right Angle for .062” [1.57 mm] or .031” [0.79 mm] Mating PCB PART NUMBER OPTIONS MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD -S13 = Card Extender Accepts .062” [1.57 mm] PCB (RE, RT, RY Terminations Only) -S734 = .031” ± .006” [0.79 mm ± 0.15 mm] Thick PCB MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze (Standard) R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper *F = PPS/Spinodal (Overall Gold Plating Only) Consult factory for special soldering guidelines. *C = PPS/Beryllium Nickel (Overall Gold Plating Only) *W = PEEK/Beryllium Nickel (Overall Gold Plating Only) *Consult factory for availability. Refer to Page 7 for Operating/Processing Temperatures MOUNTING STYLE (Opposite Page) H = .125” [3.18 mm] Clearance Holes N = No Mounting S = Side Mounting I = Threaded Insert F = Floating Bobbin TERMINATION TYPE (Opposite Page) RA = Right Angle RE = Eyelet (Standard) TE = Eyelet (Overall Plated Only) RT = .140” [3.56 mm] X .200” [5.08 mm] Dip Solder RY = .140” [3.56 mm] X .440” [11.19 mm] Dip Solder RX = .200” [5.08 mm] X .185” [4.70 mm] Dip Solder RJ = .250” [6.35 mm] X .165” [4.19 mm] Dip Solder CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface .000010” Gold .000030” Gold .000010” Gold .000030” Gold Contact Surface S = .000010” Gold M = .000030” Gold E = .000100” Pure Tin, Matte CONTACT CENTERS A = .125” [3.18 mm] B C G Y = = = = Sullins Female Card Edge E B A 43 D RE H - Sxxx Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold .000005” Gold Overall Plating .000010” Gold .000010” Gold .000100” Pure Tin, Matte READOUT (Opposite Page) D = Dual H = Half Loaded NUMBER OF CONTACT POSITIONS See Chart Below DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. REFER TO MOUNTING STYLE B A .265 [6.73] INSERTION DEPTH C .245 [6.22] .431 [10.95] CONTACT MARKINGS (LETTERS G,I,O & Q NOT USED) 1 2 3 ... 23 24 ... 45 46 ... A B C ... a b ... AA BB ... .025 [0.64] F D E .125 [3.18] TYP. 1 2 3 A B C DD EE FF 48 49 50 REFER TO TERMINATION TYPE Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. POSITIONS/ CONTACTS 06/12 10/20 14/28 15/30 18/36 22/44 28/56 30/60 31/62 35/70 36/72 37/74 40/80 43/86 44/88 49/98 50/100 INCHES MILLIMETERS A±.008 B±.008 C±.015 D±.010 E±.020 0.625 1.125 1.625 1.750 2.125 2.625 3.375 3.625 3.750 4.250 4.375 4.500 4.875 5.250 5.375 6.000 6.125 0.875 1.375 1.875 2.000 2.375 2.875 3.625 3.875 4.000 4.500 4.625 4.750 5.125 5.500 5.625 6.250 6.375 1.035 1.535 2.035 2.160 2.535 3.035 3.785 4.035 4.160 4.660 4.785 4.910 5.285 5.660 5.785 6.410 6.535 1.295 1.795 2.295 2.420 2.795 3.295 4.045 4.295 4.420 4.920 5.045 5.170 5.545 5.920 6.045 6.670 6.795 1.575 2.075 2.575 2.700 3.075 3.575 4.325 4.575 4.700 5.200 5.325 5.450 5.825 6.200 6.325 6.950 7.075 F+.005/-.015 0.330 0.370 A±0.20 B±0.20 C±0.38 D±0.25 E±0.51 15.88 28.58 41.28 44.45 53.98 66.68 85.73 92.08 95.25 107.95 111.13 114.30 123.83 133.35 136.53 152.40 155.58 22.23 34.93 47.63 50.80 60.33 73.03 92.08 98.43 101.60 114.30 117.48 120.65 130.18 139.70 142.88 158.75 161.93 26.29 38.99 51.69 54.86 64.39 77.09 96.14 102.49 105.66 118.36 121.54 124.71 134.24 143.76 146.94 162.81 165.99 32.89 45.59 58.29 61.47 70.99 83.69 102.74 109.09 112.27 124.97 128.14 131.32 140.84 150.37 153.54 169.42 172.59 40.01 52.71 65.41 68.58 78.11 90.81 109.86 116.21 119.38 132.08 135.26 138.43 147.96 157.48 160.66 176.53 179.71 F+0.13/-0.38 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 8.38 9.40 63
EBA40DRYN-S13
1. 物料型号:文档中没有明确指出具体的物料型号,但提到了Sullins Female Card Edge。
2. 器件简介:连接器具有.125" [3.18 mm]的接触中心间距和.431" [10.95 mm]的绝缘体高度。适用于.062" [1.57 mm]或.031" [0.79 mm]的PCB板。
3. 引脚分配:文档提供了详细的引脚分配图和标记,包括字母和数字的排列。
4. 参数特性: - 电流额定值:单个接触点3安培。 - 最大电阻:在额定电流下为30毫欧姆。 - UL阻燃等级:94V-0。
5. 功能详解:文档详细描述了连接器的多种功能,包括不同的终止类型、安装方式和极化键。
6. 应用信息:适用于需要高电流和高可靠性的场合,如工业和商业应用。
7. 封装信息:提供了连接器的详细尺寸和公差,以及不同材料选项,如PBT/Phosphor Bronze、PPS/Phosphor Bronze等。
8. 材料:提供了多种材料选项,包括绝缘体和接触材料的不同组合。
9. 接触表面处理:所有镀层均为无铅,并有0.000050“镍底层。
10. 修改代码:提供了修改代码以适应不同的应用需求。
EBA40DRYN-S13 价格&库存
很抱歉,暂时无法提供与“EBA40DRYN-S13”相匹配的价格&库存,您可以联系我们找货
