RCA24DTBN
RCA24DTBN
    SULLINS
    CONN EDGECARD 48POS R/A .125 SLD
RCA24DTBN 数据手册
Female Card Edge .125” [3.18 mm] Contact Centers, .610” [15.49 mm] Insulator Height, Dip Solder/Wire Wrap/Right Angle Sullins Female Card Edge SPECIFICATIONS • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board (See following pages for .093” ± .008” [2.36 mm ± 0.20 mm] and .125” ± .008” [3.18 mm ± 0.20 mm] mating PCB) • PBT, PPS or PA9T insulator • Molded-in key available • 3 Amps current rating for one contact energized • 30 milli Ohms maximum at rated current • UL Flammability Rating: 94V-0 READOUT POLARIZING KEY PLC-K1 .038” [0.97] .285” [7.24] EVEN NUMBER SIDE DUAL (D) .100” [2.54] KEY IN BETWEEN CONTACTS (ORDER SEPARATELY) HALF LOADED (H) TERMINATION TYPE LOOP BELLOWS HAIRPIN BELLOWS L .275” [6.98] L L K K .250” [6.35] .250” [6.35] ODD NUMBER SIDE K K .150” [3.81] L - .015” [0.38] ACCEPTS .062” [1.57] PCB LOOP BELLOWS (TK,RS,RM,CK) HAIRPIN BELLOWS (CS,CM,CW,CT) HAIRPIN BELLOWS CM CA CB CC CW CT CS LOOP BELLOWS TK, CK RS RM TA TB TM TERMINATION TYPE DIP SOLDER DIP SOLDER WIRE WRAP RIGHT ANGLE RIGHT ANGLE RIGHT ANGLE DIP SOLDER DIP SOLDER DIP SOLDER RIGHT ANGLE, DIP SOLDER (CA,CB,CC,TA,TB,TM) CARD EXTENDER REQUIRES -S288 MODIFICATION CODE (CS,CM,CT,RS,CK,TK,RM) POST CROSS SECTION K POST LENGTH L ± .025”ʺ [0.64] FITS MIN. HOLE SIZE .025ʺ [0.64] ROUND .190ʺ [4.83] .033ʺ [0.84] .025ʺ [0.64] SQUARE .190ʺ [4.83] .040ʺ [1.02] .025ʺ [0.64] SQUARE .560ʺ [14.20] .040ʺ [1.02] .025ʺ [0.64] SQUARE .100ʺ [2.54] .043ʺ [1.09] .025ʺ [0.64] SQUARE .180ʺ [4.57] .043ʺ [1.09] .025ʺ [0.64] SQUARE .250ʺ [6.35] .043ʺ [1.09] .015ʺ X .025ʺ [0.38 X 0.64] .125ʺ [3.18] .035ʺ [0.89] .015ʺ X .025ʺ [0.38 X 0.64] .170ʺ [4.32] .035ʺ [0.89] .025ʺ [0.64] SQUARE .160ʺ [4.06] .040ʺ [1.02] MOUNTING STYLE Ø.125” [3.18] #4-40 Ø.125” [3.18] Ø.125” [3.18] D = .250” [6.35] W = .430” [10.92] .250” [6.35] CLEARANCE HOLE (H) 64 #4-40 T = .250” [6.35] X = .430” [10.92] .245” [6.22] THREADED INSERT (I) SIDE MOUNTING (S) NO MOUNTING EARS (N) FLUSH MOUNTING (D, W) FLUSH MOUNTING WITH THREADED INSERT (T, X) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .125” [3.18 mm] Contact Centers, .610” [15.49 mm] Insulator Height, Dip Solder/Wire Wrap/Right Angle PART NUMBER OPTIONS E B A 50 D CM H - Sxxx MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze (Standard) R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/ Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures H I S N W D X T CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface .000010” Gold .000030” Gold .000010” Gold .000030” Gold Contact Surface S = .000010” Gold M = .000030” Gold E = .000100” Pure Tin, Matte B C G Y = = = = Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold .000005” Gold Overall Plating .000010” Gold .000010” Gold .000100” Pure Tin, Matte Sullins Female Card Edge MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD -S288 = Card Extender Accepts .062” [1.57 mm] PCB MOUNTING STYLE (Opposite Page) = Clearance Holes = Threaded Inserts = Side Mounting = No Mounting = Flush Mounting = Flush Mounting = Flush Mounting with Threaded Inserts = Flush Mounting with Threaded Inserts TERMINATION TYPE (Opposite Page) Hairpin Bellows ** **Available with B or C plating and Phosphor Bronze Only CS = .025” [0.64 mm] Square Dip Solder CM = .025” [0.64 mm] Square Wire Wrap CA, CB, CC = .025” [0.64 mm] Square Right Angle CW, CT = .015” X .025” [0.38 mm X 0.64 mm] Dip Solder CONTACT CENTERS A = .125” [3.18 mm] Loop Bellows RS CK, TK RM TA, TB, TM NUMBER OF CONTACT POSITIONS See Chart Below READOUT (Opposite Page) D = Dual H = Half Loaded = = = = .025” [0.64 mm] Square Dip Solder .025” [0.64 mm] Round Dip Solder .025” [0.64 mm] Square Wire Wrap .025” [0.64 mm] Square Right Angle DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. .297 [7.54] INSERTION DEPTH REFER TO MOUNTING STYLE .250 [6.35] C .180 [4.57] .370 [9.40] CONTACT MARKINGS 1 3 5 . . . 95 97 99 2 4 6 . . . 96 98 100 1 2 A B D E 3 4 5 95 97 99 6 96 98 100 .610 [15.49] .060 [1.52] REFER TO TERMINATION TYPE .125 [3.18] TYP. F Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. POSITIONS/ CONTACTS INCHES A±.008 06/12 10/20 14/28 15/30 18/36 22/44 24/48 25/50* 28/56 30/60 31/62 32/64 35/70 36/72 40/80 43/86 44/88 49/98 50/100 * Consult factory B±.008 0.625 0.875 1.125 1.375 1.625 1.875 1.750 2.000 2.125 2.375 2.625 2.875 2.875 3.125 3.000 3.250 3.375 3.625 3.625 3.875 3.750 4.000 3.875 4.125 4.250 4.500 4.375 4.625 4.875 5.125 5.250 5.500 5.375 5.625 6.000 6.250 6.125 6.375 for availability. MILLIMETERS C±.015 D±.010 E±.020 F±.015 A±0.20 B±0.20 C±0.38 D±0.25 E±0.51 F±0.38 1.035 1.535 2.035 2.160 2.535 3.035 3.285 3.410 3.785 4.035 4.160 4.285 4.660 4.785 5.285 5.660 5.785 6.410 6.535 1.295 1.795 2.295 2.420 2.795 3.295 3.545 3.670 4.045 4.295 4.420 4.545 4.920 5.045 5.545 5.920 6.045 6.670 6.795 1.555 2.055 2.555 2.680 3.055 3.555 3.805 3.930 4.305 4.555 4.680 4.805 5.180 5.305 5.805 6.180 6.305 6.930 7.055 0.875 1.375 1.875 2.000 2.375 2.875 3.125 3.250 3.625 3.875 4.000 4.125 4.500 4.625 5.125 5.500 5.625 6.250 6.375 15.88 28.58 41.28 44.45 53.98 66.68 73.03 76.20 85.73 92.08 95.25 98.43 107.95 111.13 123.83 133.35 136.53 152.40 155.58 22.23 34.93 47.63 50.80 60.33 73.03 79.38 82.55 92.08 98.43 101.60 104.78 114.30 117.48 130.18 139.70 142.88 158.75 161.93 26.29 38.99 51.69 54.86 64.39 77.09 83.44 86.61 96.14 102.49 105.66 108.84 118.36 121.54 134.24 143.76 146.94 162.81 165.99 32.89 45.59 58.29 61.47 70.99 83.69 90.04 93.22 102.74 109.09 112.27 115.44 124.97 128.14 140.84 150.37 153.54 169.42 172.59 39.50 52.20 64.90 68.07 77.60 90.30 96.65 99.82 109.35 115.70 118.87 122.05 131.57 134.75 147.45 156.97 160.15 176.02 179.20 22.23 34.93 47.63 50.80 60.33 73.03 79.38 82.55 92.08 98.43 101.60 104.78 114.30 117.48 130.18 139.70 142.88 158.75 161.93 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 65
RCA24DTBN
1. 物料型号:文档中描述了Sullins Female Card Edge连接器的多种型号和规格,包括不同的接触中心距离、绝缘体材料、以及多种安装风格和接触表面镀层选项。
2. 器件简介:介绍了Sullins Female Card Edge连接器的一般特性,如适用于不同厚度的PCB板、具有PBT、PPS或PA9T绝缘体、内置键槽选项、电流额定值为3安培、最大30毫欧姆的电阻以及UL 94V-0的阻燃等级。
3. 引脚分配:提供了连接器的引脚分配图,包括不同配置下的引脚布局,如双数(D)、半载(H)等。
4. 参数特性:列出了连接器的关键参数,例如接触中心的距离、绝缘体高度、电流额定值、电阻、UL阻燃等级等。
5. 功能详解:文档中详细描述了连接器的多种功能,包括不同的终止类型(如Hairpin Bellows、Loop Bellows)、接触表面镀层(如金、锡)、以及不同的安装方式(如侧向安装、齐平安装、带螺纹嵌件的齐平安装等)。
6. 应用信息:虽然文档中没有直接提到“应用信息”,但从提供的规格和选项可以推断,这些连接器适用于需要高电流和多种安装选项的电子设备。
7. 封装信息:提供了连接器的物理尺寸和安装尺寸,包括插入深度、接触标记、不同安装风格的尺寸等。
RCA24DTBN 价格&库存
很抱歉,暂时无法提供与“RCA24DTBN”相匹配的价格&库存,您可以联系我们找货
