8
7
4
5
6
1
2
3
REVISIONS
E
REV.
ECO. NO
DESCRIPTION
DATE
BY
B
2072
11/05/09
JH
C
2644
ADD B MOUNTING STYLE
ADDED TOLERANCE TO BODY WIDTH &
UPDATED DWG FORMAT
8/9/2012
KV
F
D
F
B
CONTACT IDs:
B 1 2 3 . . . 60 B
A 1 2 3 . . . 60 A
A
E
E
2X
.075[1.90]
SEE NOTE 13
.125 3.18
CONTACT ID
SCALE 4:1
C
F
.030 0.76
A
D
.265 6.73
INSERTION
DEPTH
D
.431 10.95
.200±.025 5.08±0.64
.245 6.22
FITS
.025 0.64
.043 MIN. HOLE
.140 3.56
ROW SPACING
.100 2.54 TYP
C
_ _ C _ _ DRTH
C
A
SECTION A - A
B
A
B
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 700 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB
8
7
6
5
CUSTOMER COPY
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
01/25/07 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
2
A
EDGECARD, .100 CC LP
_ _C_ _DRT_
DWG. NO.
C10878
SHEET 1 OF 3
1
REV
C
FILE NAME: C10878, _ _C_ _DRT_
8
7
4
5
6
1
2
3
F
F
C
2X
D
.125 3.18
E
E
.135 3.43
_ _ C _ _ DRTN
_ _ C _ _ DRTS
D
2X #4-40
THREADED
INSERTS
D
2X FLOATING BOBBIN
.116 2.95 CLEARANCE
FOR # 4 SCREW
D
D
.280 7.11
C
C
_ _ C _ _ DRTI
A
_ _ C _ _ DRTF
2X .065 1.65
B
B
L .015[0.38]
(L= DIM 'A' + .130[3.30]
CUSTOMER COPY
Pb
A
_ _ C _ _ DRTB
8
7
RoHS COMPLIANT
6
5
4
01/25/07 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
2
A
_ _C_ _DRT_
DWG. NO.
C10878
SHEET 2 OF 3
1
REV
C
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
01/25/07 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
2
A
_ _C_ _DRT_
DWG. NO.
C10878
SHEET 3 OF 3
1
REV
C
很抱歉,暂时无法提供与“ECC03DRTB”相匹配的价格&库存,您可以联系我们找货
