Female Card Edge
.156” [3.96 mm] Contact Centers, .431” [10.95 mm] Insulator Height,
Dip Solder/Eyelet/Right Angle
Sullins Female Card Edge
SPECIFICATIONS
• Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board
• Molded-in key available
• 3 Amps current rating for one contact energized
(for 5 Amps application, consult factory)
• 30 milli Ohms maximum at rated current
• UL Flammability Rating: 94V-0
READOUT
POLARIZING KEY
PLA-K1
KEY IN BETWEEN CONTACTS
(ORDER SEPARATELY)
BACK-UP
SPRINGS
FULL BELLOWS
.230”
[5.84]
.235”
[5.97]
.030”
[0.76]
NUMBER
SIDE
HALF LOADED (H)
DUAL (D)
PLM-K2
KEY IN CONTACT
(ORDER SEPARATELY)
.093”
[2.36]
.200”
[5.08]
.260”
[6.60]
CONSULT FACTORY FOR MOLDED-IN KEY
TERMINATION TYPE
.137” [3.48] (RX)
.200” [5.08] (RF)
.225” [5.71] (RU)
.408” [10.40] (RP)
.137” [3.48] (RT)
.225” [5.71] (RK)
.425” [10.80] (RY)
(RA) .125” [3.18] FOR ALL POSITIONS
(SA) .270” [6.85] 02 THRU 25 POSITIONS
(SA) .230” [5.84] 28 THRU 36 POSITIONS
(SA) .190” [4.82]
43 POSITIONS
TOLERANCE: (RA) ± .025” [0.64]
(SA) ± .040” [1.00]
EYELET ACCEPTS
3-#22 AWG
FITS Ø .051” [1.30]
.200” [5.08]
.140” [3.56]
ALTERNATE
EYELET SHAPE
* (RE) .014” [0.36] THICK
.185” [4.70]
WIDE DIP SOLDER
(RF, RX, RU, RP)
NARROW DIP SOLDER
(RT, RK, RY)
.050” [1.27]
.156” [3.96]
.110” ± .025” [2.79±0.64] (SX)
.210” ± .025” [5.33±0.64] (SU)
.225”
[5.72]
LETTER
SIDE
FITS Ø.051” [1.30]
(SE) .007” [0.18] THICK
.122” [3.10] (RT)
.210” [5.33] (RK)
EYELET
.410” [10.41] (RY)
(SE OR RE)
.210” [5.33] (SE)
ACCEPTS .062” [1.57] PCB
CARD EXTENDER
(RT,RK,RY,SE TERMINATIONS ONLY)
REQUIRES -S13 MODIFICATION CODE
FITS Ø .051” [1.30]
MINIMUM
RIGHT ANGLE,
DIP SOLDER
(RA, SA)
CENTERED DIP SOLDER
(SX, SU)
AVAILABLE WITH DUAL OR
HALF LOADED READOUT TYPE
MOUNTING STYLE
Ø.125”
[3.18]
CLEARANCE HOLE
(H)
#4-40
THREADED
INSERT (I)
Ø.116” [2.95],
Ø.125” [3.18]
CLEARANCE FOR
#4 SCREW
FLOATING
BOBBIN (F)
.135” [3.43]
NO MOUNTING EARS
(N)
SIDE MOUNTING
(S)
* Beryllium Copper & Beryllium Nickel (H, A, J, F, C & W Material Codes) Only.
70
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
PART NUMBER OPTIONS
E B M 43 D RK H - Sxxx
MOUNTING STYLE (Opposite Page)
H = .125” [3.18 mm] Clearance Holes
N = No Mounting
S = Side Mounting
I = Threaded Insert
F = Floating Bobbin
TERMINATION TYPE (Opposite Page)
RA = .125” [3.18 mm] Right Angle Dip Solder
SA = Long Right Angle Dip Solder
RT = .140” X .137” [3.56 mm X 3.48 mm] Dip Solder
RK = .140” X .225” [3.56 mm X 5.72 mm] Dip Solder
RY = .140” X .425” [3.56 mm X 10.80 mm] Dip Solder
RX = .200” X .137” [5.08 mm X 3.48 mm] Dip Solder
RF = .200” X .200” [5.08 mm X 5.08 mm] Dip Solder
RU = .200” X .225” [5.08 mm X 5.72 mm] Dip Solder
RP = .200” X .408” [5.08 mm X 10.36 mm] Dip Solder
SX = .110” [2.79 mm] Centered Dip Solder
SU = .210” [5.33 mm] Centered Dip Solder
SE = .007” [0.18 mm] Thick Eyelet
RE = .014” [0.36 mm] Thick Eyelet
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
.000010” Gold
.000030” Gold
.000010” Gold
.000030” Gold
Contact Surface
S = .000010” Gold
M = .000030” Gold
E = .000100” Pure Tin, Matte
B
C
G
Y
Termination
.000005” Gold
.000005” Gold
Overall Plating
.000010” Gold
.000010” Gold
MODIFICATION CODE (Consult Factory)
OMIT FOR STANDARD
-S13 = Card Extender Accepts .062” [1.57 mm] PCB
(RT, RK, RY, SE Terminations Only)
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze (Standard)
R = PPS/Phosphor Bronze
G = PA9T/Phosphor Bronze
H = PBT/Beryllium Copper
A = PPS/Beryllium Copper
J = PA9T/Beryllium Copper
*F = PPS/Spinodal (Overall Gold Plating Only)
Consult Factory for Special Soldering Guidelines
*C = PPS/Beryllium Nickel (Overall Gold Plating Only)
*W = PEEK/Beryllium Nickel (Overall Gold Plating Only)
*Consult factory for availability.
Refer to Page 7 for Operating/Processing Temperatures
READOUT (Opposite Page)
D = Dual
D = Dual Row/ Crimp to Center for
Single Readout (SX, SU Termination Only)
H = Half Loaded
CONTACT CENTERS
M = .156” [3.96 mm]
NUMBER OF CONTACT POSITIONS
See Chart Below
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
REFER TO
MOUNTING
STYLE
.265 [6.73] INSERTION DEPTH
B
A
.245 [6.22]
.431 [10.95]
C
1
.025
[0.64]
F
D
E
A
B
3
C
41
42
43
_
_
_
W
X
F
Y
CONTACT MARKINGS
(LETTERS G, I, O & Q NOT USED)
SIZE 02 THRU 25
1 2 3 . . . 23 24 . . .
A B C . . . AA BB . . .
SIZES 28 THRU 44
A B C... A B ...
REFER TO
MOUNTING
STYLE
.156 [3.96] TYP.
2
Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory.
POSITIONS/
CONTACTS
INCHES
A±.008
B±.008
02/04
0.156
0.476
03/06
0.312
0.632
04/08*
0.468
0.788
06/12
0.780
1.100
07/14
0.936
1.256
08/16
1.092
1.412
10/20
1.404
1.724
11/22
1.560
1.880
12/24
1.716
2.036
15/30
2.184
2.504
18/36
2.652
2.972
22/44
3.276
3.596
24/48
3.588
3.908
25/50
3.744
4.064
28/56
4.212
4.532
36/72
5.460
5.780
43/86
6.552
6.872
44/88
6.708
7.028
* Consult factory for availability.
C±.015
0.596
0.752
0.908
1.220
1.376
1.532
1.844
2.000
2.156
2.624
3.092
3.716
4.028
4.184
4.652
5.900
6.992
7.148
D±.010
MILLIMETERS
E MAX
F+.005/-.015
‘N’ MOUNTING
1.533
1.689
1.845
2.157
2.313
2.469
2.937
3.405
4.029
4.341
4.497
4.965
6.213
7.305
7.461
1.902
2.058
2.214
2.526
2.682
2.838
3.306
3.774
4.398
4.710
4.866
5.334
6.582
7.674
7.830
0.325
0.438
0.500
A±0.20
B±0.20
C±0.38
3.96
7.92
11.89
19.81
23.77
27.74
35.66
39.62
43.59
55.47
67.36
83.21
91.14
95.10
106.98
138.68
166.42
170.38
12.09
16.05
20.02
27.94
31.90
35.86
43.79
47.75
51.71
63.60
75.49
91.34
99.26
103.23
115.11
146.81
174.55
178.51
15.14
19.10
23.06
30.99
34.95
38.91
46.84
50.80
54.76
66.65
78.54
94.39
102.31
106.27
118.16
149.86
177.60
181.56
D±0.25
E MAX
F+0.13/-0.38
‘N’ MOUNTING
38.94
42.90
46.86
54.79
58.75
62.71
74.60
86.49
102.34
110.26
114.22
126.11
157.81
185.55
189.51
48.31
52.27
56.24
64.16
68.12
72.09
83.97
95.86
111.71
119.63
123.60
135.48
167.18
194.92
198.88
8.26
11.13
12.70
71
很抱歉,暂时无法提供与“HBM22DSXN”相匹配的价格&库存,您可以联系我们找货
