RSM1701K0W
N-Channel SiC Power MOSFET
VDS
RDS(on)
ID@25℃
1700V
1000mΩ
5A
Applications:
• Solar Inverters
• Switch Mode Power Supplies
• High Voltage DC/DC Converters
• EV Charging
• Motor Drives
Features:
• High Blocking Voltage with Low On-Resistance
• High Speed Switching with Low Capacitances
• Easy to Parallel and Simple to Drive
• Avalanche Ruggedness
Benefits:
• Higher System Efficiency
• Reduced Cooling Requirements
• Increased Power Density
• Increased System Switching Frequency
Ordering Information
Part Number
Package
Marking
Packing
Qty.
RSM1701K0W
TO-247-3
RSM1701K0W
Tube
30 PCS
Maximum Ratings(TJ= 25℃ unless otherwise specified)
Symbol
Parameter
Value
Unit
Test Conditions
VDSmax
Drain - Source Voltage
1700
V
VGS=0V,ID =100μA
VGSmax
Gate - Source Voltage
-10/+2
5
V
Absolute maximum values
VGSop
-5/+20
V
Recommended operational values
ID
Continuous Drain
Current
5
3.5
A
VGS=20V, TC =25℃
VGS=20V, TC =100℃
ID(pulse)
Pulsed Drain Current
6
A
Pulse width tp limited by TJmax
PD
Power Dissipation
69
W
TC =25℃, TJ =150℃
TL
Solder Temperature
260
TJ, Tstg
Operating Junction and
StorageTemperature
-40 to
+ 150
www.reasunos.com
1 /8
Note
Copyright Reasunos
RSM1701K0W
Electrical Characteristics (TJ= 25℃ unless otherwise specified)
Symbol
Parameter
Min.
V(BR)D
SS
Drain-Source
Breakdown Voltage
1700
VGS(th)
IDSS
IGSS
RDS(on)
Gate Threshold
Voltage
Zero Gate Voltage
Drain Current
Gate-Source Leakage
Current
Drain-Source on-state
Resistance
2.5
Typ.
3.0
1
1000
V
V
Coss
Output Capacitance
12
Note
VGS=0V,ID =100μA
VGS= VDS, IDS=1mA,TC
=25℃
=150℃
μA
VDS= 1700V, VGS=0V
250
nA
VGS=25V, VDS= 0V
1300
mΩ
VGS=20V, ID =2A, TC =25℃
VGS=20V, ID =2A, TC =150℃
VGS=0V, VDS=1000 V,
pF
f=1MHz,VAC=25 mV
1.6
48
μJ
VDS =1200V, VGS
=-5/20V,ID = 2A,
RG(ext) = 2.5Ω, L= 1500μH
ns
VDS =1200V, VGS =-5/20 V
ID = 2A, RG(ext) =2. 5 Ω ,
RL =600Ω
f=1 MHz, VAC=25mV
EOFF
Turn-Off Energy
18
td(on)
Turn-On Delay Time
5.2
tr
Rise Time
9.4
td(off)
Turn-Off Delay Time
13.2
tf
Fall Time
22
RG(int)
Internal Gate
Resistance
22
Ω
Qgs
Gate to Source Charge
5.2
nC
Qgd
Gate to Drain Charge
7.3
nC
Qg
Total Gate Charge
21.8
www.reasunos.com
Test Conditions
100
1500
186
EON
4.5
2.2
Input Capacitance
Crss
Unit
V
Ciss
Reverse Transfer
Capacitance
Turn-On Switching
Energy
Max
2 /8
VDS=1200V, VGS=-5/20V
ID =2A
Copyright Reasunos
RSM1701K0W
Reverse Diode Characteristics (TJ= 25℃ unless otherwise specified)
Symbol
Parameter
Typ.
Max
Unit
Test Conditions
4.2
V
VGS=-5V, ISD = 1 A, TJ = 25℃
3.9
V
VGS=-5V, ISD= 1 A, TJ= 150℃
A
VGS=-5V,TC= 25℃
VSD
Diode Forward Voltage
IS
Continuous Diode Forward
Current
trr
Reverse Recovery time
25
ns
Qrr
Reverse Recovery Charge
15
nC
Irrm
Peak Reverse Recovery
Current
2.8
A
4
Not
e
ISD= 2 A,
VR = 1200V
Thermal Characteristics (TJ= 25℃ unless otherwise specified)
Symbol
Parameter
Typ.
RθJC
Thermal Resistance from Junction to Case
1.8
Unit
Test Conditions
Not
e
℃/W
RθJA
Thermal Resistance From Junction to Ambient
www.reasunos.com
3 /8
40
Copyright Reasunos
RSM1701K0W
Typical Feature Curve
www.reasunos.com
4 /8
Copyright Reasunos
RSM1701K0W
www.reasunos.com
5 /8
Copyright Reasunos
RSM1701K0W
www.reasunos.com
6 /8
Copyright Reasunos
RSM1701K0W
Package outline drawing(TO-247-3 Unit: mm )
www.reasunos.com
7 /8
Copyright Reasunos
RSM1701K0W
Disclaimers:
Reasunos Semiconductor Technology Co.Ltd (Reasunos) reserves the right to make changes without
notice in order to improve reliability,function or design and to discontinue any product or service without
notice .Customers should obtain the latest relevant information before orders and should verify that such
information in current and complete.All products are sold subject to Reasunos's terms and conditions
supplied at the time of orderacknowledgement.
Reasunos Semiconductor Technology Co.Ltd warrants performance of its hardware products to the
speciffications at the time of sale.Testing,reliability and quality control are used to the extene Reasunos
deems necessary to support this warrantee. Except where agreed upon by contr- actual
agreement,testing of all parameters of each product is not necessarily performed.
Reasunos Semiconductor Technology Co.Ltd does not assume any liability arising from the use of any
product or circuit designs described herein.Customers are responsible for their products and applications
using Reasunos's components.To minimize risk,customers must provide adequate design and operating
safeguards.
Reasunos Semiconductor Technology Co.Ltd does not warrant or convey any license eith- er expressed or
implied under its patent rights,nor the rights of others.Reproduction of inform- ation in Reasunos's data
sheeets or data books is permissible only if reproduction is without modification
oralteration.Reproduction of this information with any alteration is an unfair and deceptive business
practice. Reasunos Semiconductor Technology Co.Ltd is not responsi- ble or liable for such altered
documentation.
Resale of Reasunos's products with statements different from or beyond the parameters stated by
Reasunos Semiconductor Technology Co.Ltd for that product or service voids all exp- ress or implied
warrantees for the associated Reasunos's product or service and is unfair and deceptive business practice.
Reasunos Semiconductor Technology Co.Ltd is not responsi- ble or liable for such statements.
Life Support Policy:
Reasunos Semiconductor Technology Co.Ltd's Products are not authorized for use as cri- tical
components in life support devices or systems without the expressed written approval of Reasunos
Semiconductor Technology Co.Ltd.
As used herein:
1. Life support devices or systems are devices or systems which: a.are intended for surgical implant into
the human body, b.support or sustain life,
c.whose failuer to when properly used in accordance with instructions for used provided in the laeling,can
be reasonably expected to result in significant injury to the user.
2.A critical component is any component of a life support device or system whose failure to system
whose failure to perform can be reasonably expected to cause the failure of the life support device or
system,or to affect its safety or effectiveness.
www.reasunos.com
8 /8
Copyright Reasunos
很抱歉,暂时无法提供与“RSM1701K0W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.35000
- 10+11.40000
- 30+11.21000
