8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2663
INITIAL RELEASE
8/24/2012
JH
B
4415
UPDATE TITLE BLOCK
8/17/2021
PL
F
F
E
D
B
A
.075 1.91
SEE NOTE 13
E
E
2X .125 3.18
THRU
A
F
C
.030 0.75
.431 10.95
.245 6.22
D
A
.156 3.96
.041 1.04 X .007[0.18]
.025 0.64
D
.200 5.08
SECTION A-A
_ _M_ _DRX (RF, RU, RP)H-S37
D
TAIL LENGTH±.025[0.64]
RX= .137[3.48]
RF= .200[5.08]
RU= .225[5.71]
RP= .408[10.40]
A
C
2X .125 3.18
(NOT REQ'D FOR 'N' MOUNTING)
.200 5.08
.156 3.96
B
A
.051 1.30 MIN
PCB LAYOUT RECOMMENDED
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: SEE PART NUMBER CODING.
3. PLATING: .SEE PART NUMBER CODING.
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING.
5. PROCESSING TEMP: SEE PART NUMBER CODING.
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 950 VAC
8. CURRENT RATING: 3 AMPS
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI-8.6-03
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE
16. MODIFICATION: REVERSE CONTACT ID, SHORTER CARDSLOT LENGTH (SEE DIMENSION TABLE)
CONTACT MARKINGS
(LETTERS G, I, O & Q NOT USED)
SIZES 36 & 43
A B C .... R.....Y
1 2 3 .... 36...43
B
CUSTOMER COPY
Pb
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
8/24/2012 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
7
6
5
4
3
A
EDGECARD, .156 CC, LP
PART NUMBER
_ _M_ _DRX (RF, RU, RP)_- S37
SIZE
C
CAGE CODE
54453
SCALE: 2:1
8
C
2
DWG. NO.
C12077
REV
B
SHEET 1 OF 3
1
FILE NAME: C12077, _ _M_ _DRX (RF, RU, RP)_-S37
8
7
4
5
6
2X #4-40
THREADED INSERTS
F
1
2
3
F
D
C
E
E
_ _M_ _DRX (RF, RU, RP)N-S37
_ _M_ _DRX (RF, RU, RP)I-S37
D
D
2X
FLOATING BOBBIN
.116[2.95] CLEARANCE
FOR #4 SCREW
C
2X
D
D
C
.125 3.18
.280 7.11
.135 3.43
_ _M_ _DRX (RF, RU, RP)F-S37
_ _M_ _DRX (RF, RU, RP)S-S37
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8/24/2012 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 1:1
8
7
6
5
4
3
A
2
DWG. NO.
C12077
REV
B
SHEET 2 OF 3
1
8
7
4
5
6
1
2
3
FOR 'I' AND 'F'
MOUNTING STYLES
NO. OF
POSITIONS
PART NUMBER
F
_ _M36DRX(RF, RU, RP)_-S37
_ _M43DRX(RF, RU, RP)_-S37
36
43
A±.008[0.20]
B±008[0.20]
C±.015[0.38]
D±.010[0.25]
E±.020[0.51]
E±.020[0.51]
F+.005/-.015 [+0.13/0.38]
INCH
MM
INCH
MM
INCH
MM
INCH
MM
INCH
MM
INCH
MM
INCH
MM
5.460
6.552
138.68
166.42
5.766
6.810
146.46
172.97
5.900
6.992
149.86
177.60
6.213
7.305
157.81
185.55
6.462
7.554
164.13
191.87
6.562
7.654
166.67
194.41
0.438
0.500
11.13
12.70
F
PART NUMBER CODING
_ _ M _ _ D_ _ _ - S37
E
MATERIAL (INSULATOR/CONTACT)
E=
D
E
MOUNTING STYLE
BLUE PBT/PHOSPHOR BRONZE
OPERATING TEMP: -65°C TO +125°C
PROCESSING TEMP: WAVE/MANUAL SOLDERING ONLY
R = GREEN PPS/PHOSPHOR BRONZE
PROCESSING TEMP: 260°C MAX FOR 20 SEC
H = BLUE PBT/BERYLLIUM COPPER
A = GREEN PPS/BERYLLIUM COPPER
OPERATING TEMP: -65°C TO +150°C
(CONSULT FACTORY FOR OTHER MATERIALS)
H=
N=
S=
I=
F=
.125" DIA. CLEARANCE HOLES (PAGE 1)
NO MOUNTING EARS (PAGE 2)
.125" DIA. SIDE MOUNTING (PAGE 2)
#4-40 THREADED INSERT (PAGE 2)
FLOATING BOBBIN (PAGE 2)
TAIL LENGTH
RX= .137[3.48]
RF= .200[5.08]
RU= .225[5.71]
RP= .408[10.40]
(SEE SECTION A-A ON PAGE 1)
D
NUMBER OF POSITIONS
(CONTACTS PER ROW)
PLATING
ALL PLATINGS ARE LEAD FREE AND HAVE .000050" NICKEL UNDERPLATE
CONTACT SURFACE
TERMINATION
B = .000010" GOLD
.000100" PURE TIN, MATTE
C = .000030" GOLD
G = .000010" GOLD
.000005" GOLD
Y = .000030" GOLD
.000005" GOLD
CONTACT SURFACE
OVERALL PLATING
S = .000010" GOLD
.000010" GOLD
M = .000030" GOLD
.000010" GOLD
**E = .000100" PURE TIN, MATTE
** OVERALL TIN ONLY AVAILABLE ON MATERIAL CODES 'E' OR 'R'
C
B
C
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8/24/2012 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 1.5:1
8
7
6
5
4
3
A
2
DWG. NO.
C12077
REV
B
SHEET 3 OF 3
1
很抱歉,暂时无法提供与“EBM43DRXH-S37”相匹配的价格&库存,您可以联系我们找货
