EBC07DCWB
EBC07DCWB
    SULLINS
    CONNEDGEDUALFMALE14POS0.100
EBC07DCWB 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. A ECO. NO 2077 DESCRIPTION INITIAL RELEASE DATE 11/11/09 BY TT F F DETAIL CONTACT E E E D B 2X .125 3.18 THRU A D D .075 1.91 ACCEPT .062" PCB .100 2.54 TYP A .180 4.57 .370 9.40 .250 6.35 .297 7.54 INSERTION DEPTH .610 15.49 C C .060 1.52 A .025 0.64 X .015[0.38] FITS .035 MIN HOLE F _ _ C _ _ DCWH _ _ C _ _ DCTH B A .200 5.08 SECTION A-A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. VOLTAGE RATING: 600 VDC MINIMUM AT SEA LEVEL. 8. CURRENT RATING: 3 AMP PER CONTACT 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHM 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND BARCODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008" 14. BOARD INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062" TEST BLADE. INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION W17.3-01. 15. BOARD WITHDRAWAL FORCE: 1 OUNCE MINIMUM PER CONTACT PAIR USING .062" PCB 8 7 6 5 CW = .125±.025 3.18±0.64 CT = .170 .025 [4.32 0.64] B CUSTOMER COPY UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 30' .XX= .02 [.508] .XXX= .005 [.1270] .XXXX= .0005 [.0127] SURFACE FINISH: 63 Ra DRAWN 4 11/11/2009 TT THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. _ _C_ _DCW(DCT)_ SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 NAME EDGECARD CONNECTOR .100 CC HP REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT DATE REV C11424 SCALE: 1:1 2 A SHEET 1 OF 3 1 FILE NAME: Z:\ECO PENDING\2077, _ _C_ _DCW(T)_\C11424, _ _C_ _DCW(DCT)_ PRINT: 11/20/2009 A 8 7 4 5 6 D 1 2 3 D 2X #4-40 THREADED INSERT F F E E D = .250 6.35 W = .430[10.92] _ _ C _ _ DCWI _ _ C _ _ DCTI 2X _ _ C _ _ DCWD _ _ C _ _ DCWW _ _ C _ _ DCTD _ _ C _ _ DCTW .125 3.18 THRU 2X #4-40 THREADED INSERT D D D 2X D .125 3.18 THRU .305 7.75 C C _ _ C _ _ DCWS _ _ C _ _ DCTS T = .250 6.35 X = .430[10.92] B _ _ C _ _ DCWT _ _ C _ _ DCWX _ _ C _ _ DCTT _ _ C _ _ DCTX B C CUSTOMER COPY UNLESS OTHERWISE SPECIFIED: _ _ C _ _ DCWN _ _ C _ _ DCTN A Pb DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 30' .XX= .02 [.508] .XXX= .005 [.1270] .XXXX= .0005 [.0127] SURFACE FINISH: 63 Ra DRAWN 8 7 6 5 4 11/11/2009 TT THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. _ _C_ _DCW(DCT)_ SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 NAME EDGECARD CONNECTOR .100 CC HP REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT DATE REV C11424 SCALE: 2:1 2 A SHEET 2 OF 3 1 FILE NAME: Z:\ECO PENDING\2077, _ _C_ _DCW(T)_\C11424, _ _C_ _DCW(DCT)_ PRINT: 11/20/2009 A 8 7 4 5 6 1 2 3 F F E E D D C C .035[0.76] MIN .100 2.54 .200 5.08 A B 2X .125 3.18 OPTIONAL FOR H, I, D, W, T, & X MOUNTING D B RECOMMENDED PC BOARD LAYOUT CUSTOMER COPY UNLESS OTHERWISE SPECIFIED: Pb A DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 30' .XX= .02 [.508] .XXX= .005 [.1270] .XXXX= .0005 [.0127] SURFACE FINISH: 63 Ra DRAWN 8 7 6 5 4 11/11/2009 TT THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. _ _C_ _DCW(DCT)_ SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 NAME EDGECARD CONNECTOR .100 CC HP REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT DATE REV C11424 SCALE: 1:1 2 A SHEET 3 OF 3 1 FILE NAME: Z:\ECO PENDING\2077, _ _C_ _DCW(T)_\C11424, _ _C_ _DCW(DCT)_ PRINT: 11/20/2009 A
EBC07DCWB 价格&库存
很抱歉,暂时无法提供与“EBC07DCWB”相匹配的价格&库存,您可以联系我们找货
