DESIGNED & DIMENSIONED
IN MILLIMETERS
(INCHES FOR REFERENCE ONLY)
REVISION F
DO NOT
SCALE FROM
THIS PRINT
MEC6-1XX-XX-X-DV-XX
(No OF POS x 0.635[.0250]) + 4.77[.188] REF
C
CARD THICKNESS
-02: 1.57mm [.062]
THICK CARD
+ 1.565[.062] REF
C
2.70 .106
REF
02
(No OF POS -1 )
x 0.635[.0250]
C
L
"A"
4.40 .173
REF
"A"
C
L
7.00 .276
REF
59
0.635±0.050 .0250±.0020
(TOL NON ACCUM)
POSITION #1
INDICATOR
ROW SPECIFICATION
-DV: DUAL VERTICAL
(USE MEC6-XX-XX-DV)
PLATING SPECIFICATION
-L: LIGHT SELECTIVE GOLD/MATTE TIN (USE C-182-02-L)
-S: SELECTIVE GOLD/MATTE TIN (USE C-182-02-S)
60
1.78 .070 REF
01
OPTION
-A: ALIGNMENT PINS (SEE FIG. 3)
(USE MEC6-XX-XX-DV-A)
-LC: LOCKING CLIP
(USE LC-05-TM)
-K: POLYIMIDE FILM PAD
(USE K-DOT-.217-.313-.005)(SEE FIG. 4)
-TR: TAPE & REEL
No OF POSITIONS
-10, -20, -30, -40,
-50, -60, -70
C
C
MEC6-XX-02-DV
+0.10
+.004
1.00 - 0.20 .039 - .008
0.90±0.15 .035±.006
(TYP)
1.13 x 60 REF
8.50 .335
REF
C
3.60 .142
REF
LC-05-TM
C
8.65±0.15 .341±.006
(TYP)
SEE TABLE 1
C-182-02-X
0.25 .010 REF
C
C
L
1.40 .055
1.05 .041
REF (TYP)
+ 2.370[.0933]
8.80 .346 REF
SECTION "A"-"A"
1.50 .059
CL
FIG 1
-LC OPTION SHOWN
MEC6-130-02-X-DV-LC SHOWN
(FOR POSITIONS -10, -20, -30 & -40)
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. MAXIMUM BURR ALLOWANCE: 0.038[.0015].
3. MINIMUM PUSHOUT FORCE: 2.22 N [.5 LB].
4. PARTS TO BE PACKAGED IN TRAYS, UNLESS
-TR OPTION IS SPECIFIED.
ANGLES
.X: 0.3 [.01]
2
.XX: 0.13 [.005]
.XXX: 0.051 [.0020]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, COLOR: BLACK
CONTACT: PHOS BRONZE
F:\DWG\MISC\MKTG\MEC6-1XX-XX-X-DV-XX-MKT.SLDDRW
SHEET SCALE: 1:0.4
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
.635mm VERTICAL MOUNT MINI-EDGE CARD ASSEMBLY
DWG. NO.
MEC6-1XX-XX-X-DV-XX
BY: DEAN P
05/17/2005
SHEET 1 OF 2
REVISION F
FIG 3
-A OPTION
(No OF POS x 0.635[.0250]) + 7.94[.313] REF
"D" REF
2.70 .106 REF
MEC6-140-02-X-DV-A SHOWN
"A" REF
CL
100
02
MEC6-XX-02-DV-A
1.00 .039
01
(TOL NON-ACCUM)
C
C
99
(No OF POS) x 0.635[.0250]) + 2.37[.093] REF
3.81 .150
"B" SPACES @
0.635[.0250] = "C"
53°
REF
(No OF POS + 4) x 0.635[.0250]
C
1.400 .055
REF
0.90 .035
1.400 .055
0.10 X U
1.50 .059
REF
FIG 4
((No OF POS + 4) x 0.635[.0250]) + 3.00[.118] REF
-K OPTION
"R"
8.80 .346
"S"
1.50 .059
REF
CL
FIG 2
MEC6-150-02-X-DV-A SHOWN
FOR POSITIONS -50 THRU 70
(SAME AS FIG 1, UNLESS OTHERWISE STATED)
0.55 .022
5.50 .217
PROPRIETARY NOTE
SHEET SCALE: 1:0.444444
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
MEC6-1XX-XX-X-DV-XX
BY: DEAN P
05/17/2005
SHEET 2 OF 2
很抱歉,暂时无法提供与“MEC6-160-02-L-DV-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+83.346391+10.79628
- 10+77.0466210+9.98024
- 25+72.8410225+9.43546
- 50+70.2023050+9.09366
- 100+69.57435100+9.01232
