8
7
4
5
6
1
2
3
REV.
ECO. NO
REVISIONS
DESCRIPTION
A
2432
INITIAL RELEASE
E
DATE
BY
08/19/11
SE
D
F
F
B
.075 1.91
CARDSLOT
SEE NOTE 13
A
+.005
+0.13
.370
9.40
- .015
- 0.38
.125 3.18
2X
C
E
E
.030±.010 0.75±0.25
A
.297 7.54
INSERTION DEPTH
.250 6.35
.610 15.49
.180 4.57
.060 1.52
D
.025 0.62
A
.100 2.54
.200 5.08
.190±.025 4.83±0.64
F
D
SECTION A-A
MP_ _-_100-_ _-DR-5H_
D
2X
.125 3.18
A
CONTACT MARKINGS
1 3 5 . . . 137 139
2 4 6 . . . 138 140
.200 5.08
C
.100 2.54
.033 0.84 MIN
C
.100 2.54
RECOMMENDED PCB LAYOUT
CONTACT ID.
SCALE 4 : 1
B
A
B
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. DIELECTRIC WITHSTANDING VOLTAGE: 750 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 3 AMPS PER CONTACT
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE
CUSTOMER COPY
DRAWN
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
Pb
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
INTERPRET DIMENSIONS AND
TOLERANCING
PER: ASME Y14.5M-2009
3
DATE
NAME
08/18/11
SE
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
A
EDGECARD, .100 CC HP
PART NUMBER
SIZE
C
MP_ _-_100-_ _-DR-_H_
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11872
SHEET 1 OF 3
1
REV
A
FILE NAME: C11872, MP -0100-_ _-DR-_H_, _ _C_ _DTK_-_ _ _-S81, S328
8
7
4
5
6
D
D
F
2X
1
2
3
.125 3.18
F
2X #4-40
THREADED INSERT
.250 6.35
E
E
.060 1.52
MP_ _-_100-_ _-DR-1H_
MP_ _-_100-_ _-DR-2H_
D
D
D
2X #4-40
THREADED INSERT
C
C
C
MP_ _-_100-_ _-DR-4H_
MP_ _-_100-_ _-DR-6H_
B
B
D
2X
.125 3.18
CUSTOMER COPY
DRAWN
A
Pb
.245 6.22
TOLERANCES:
.XX=
.XXX=
.XXXX=
MP_ _-_100-_ _-DR-8H_
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
08/18/11
SE
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11872
SHEET 2 OF 3
1
REV
A
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
08/18/11
SE
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11872
SHEET 3 OF 3
1
REV
A
很抱歉,暂时无法提供与“MPL-0100-15-DR-1HK”相匹配的价格&库存,您可以联系我们找货
