GCC50DCSN-S36
GCC50DCSN-S36
    SULLINS
    CONN EDGECARD 100PS DIP .100 SLD
GCC50DCSN-S36 数据手册
Female Card Edge Sullins Female Card Edge .100” [2.54 mm] Contact Centers, .690” [17.52 mm] Insulator Height, Make Before Break Dip Solder/Card Extender/Right Angle SPECIFICATIONS • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board • PA9T insulator • Molded-in key available • 3 Amps current rating for one contact energized • 30 milli Ohms maximum at rated current • UL Flammability Rating: 94V-0 READOUT MOUNTING STYLE NO MOUNTING EARS (N) DUAL (D) OPEN CARD SLOT (B) TERMINATION TYPE MBB CONTACT, .025” [0.64] SQ. .030” [0.76] .190” [4.82] .425”± .025” [10.80±0.64] FITS Ø .043” [1.09] MIN. .150” [3.81] .200” [5.08] .100”±.025” [2.54±0.64] FORMED TO FIT .062” [1.57] PCB CARD EXTENDER (CS) GBC_ _DCSN-S527 58 FITS Ø .043” [1.09] MIN. DIP SOLDER (CS) GBC_ _DCSN-S36 RIGHT ANGLE (CA) GBC_ _DCAN-S757 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .100” [2.54 mm] Contact Centers, .690” [17.52 mm] Insulator Height, Make Before Break Dip Solder/Card Extender/Right Angle PART NUMBER OPTIONS G B C 10 D CS N - S36 MODIFICATION CODE (Consult Factory) -S757 = MBB, .150” [3.81] Row to Row on Right Angle -S527 = MBB, Card Extender Accepts .062” [1.57 mm] PCB -S36 = MBB, Straight Dip-Solder MOUNTING STYLE N = No Mounting B = Open Card Slot Available for 50 position only H = Clearance Holes TERMINATION TYPE (Opposite Page) Hairpin Bellows CS = .025” [0.64 mm] Square Dip Solder/Card Extender CA = .025” [0.64 mm] Square Right Angle CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface B = .000010” Gold C = .000030” Gold Sullins Female Card Edge MATERIALS (INSULATOR/CONTACT) G = PA9T/Phosphor Bronze (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte CONTACT CENTERS C = .100” [2.54 mm] NUMBER OF CONTACT POSITIONS READOUT (Opposite Page) D = Dual See Chart Below DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. D .370 [9.40] Open Card Slot (B) .515 [13.08] INSERTION DEPTH A B C .025 [0.64] SQ. .690 [17.53] .100 [2.54] TYP. REFER TO TERMINATION TYPE (Opposite Page) F No Mounting (N) POSITIONS/ CONTACTS A±.008 [0.20] B±.008 [0.20] C±.015 [0.38] D±.020 [0.51] F±.020 [0.51] 40/80* in 0.100 0.300 0.500 0.700 0.900 1.100 1.300 1.500 1.700 1.900 2.100 2.300 2.500 2.700 2.900 3.100 3.300 3.500 3.700 3.900 mm 2.54 7.62 12.70 17.78 22.86 27.94 33.02 38.10 43.18 48.26 53.34 58.42 63.50 68.58 73.66 78.74 83.82 88.90 93.98 99.06 in 0.300 0.500 0.700 0.900 1.100 1.300 1.500 1.700 1.900 2.100 2.300 2.500 2.700 2.900 3.100 3.300 3.500 3.700 3.900 4.100 mm 7.62 12.70 17.78 22.86 27.94 33.02 38.10 43.18 48.26 53.34 58.42 63.50 68.58 73.66 78.74 83.82 88.90 93.98 99.06 104.14 in 0.460 0.660 0.860 1.060 1.260 1.460 1.660 1.860 2.060 2.260 2.460 2.660 2.860 3.060 3.260 3.460 3.660 3.860 4.060 4.260 mm 11.68 16.76 21.84 26.92 32.00 37.08 42.16 47.24 52.32 57.40 62.48 67.56 72.64 77.72 82.80 87.88 92.96 98.04 103.12 108.20 in 0.250 0.450 0.650 0.850 1.050 1.250 1.450 1.650 1.850 2.050 2.250 2.450 2.650 2.850 3.050 3.250 3.450 3.650 3.850 4.050 mm 6.35 11.43 16.51 21.59 26.67 31.75 36.83 41.91 46.99 52.07 57.15 62.23 67.31 72.39 77.47 82.55 87.63 92.71 97.79 102.87 in 0.340 0.540 0.740 0.940 1.140 1.340 1.540 1.740 1.940 2.140 2.340 2.540 2.740 2.940 3.140 3.340 3.540 3.740 3.940 4.140 mm 8.64 13.72 18.80 23.88 28.96 34.04 39.12 44.20 49.28 54.36 59.44 64.52 69.60 74.68 79.76 84.84 89.92 95.00 100.08 105.16 42/84* 4.100 104.14 4.300 109.22 4.460 113.28 4.250 107.95 4.340 110.24 44/88* 4.300 109.22 4.500 114.30 4.660 118.36 4.450 113.03 4.540 115.32 46/92* 4.500 114.30 4.700 119.38 4.860 123.44 4.650 118.11 4.740 120.40 48/96* 4.700 119.38 4.900 124.46 5.060 128.52 4.850 123.19 4.940 125.48 50/100 4.900 124.46 5.100 129.54 5.260 133.60 5.050 128.27 5.140 130.56 02/04* 04/08* 06/12* 08/16* 10/20* 12/24* 14/28 16/32* 18/36* 20/40* 22/44* 24/48* 26/52* 28/56* 30/60* 32/64* 34/68* 36/72* 38/76* *Consult factory for availability. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 59
GCC50DCSN-S36 价格&库存
很抱歉,暂时无法提供与“GCC50DCSN-S36”相匹配的价格&库存,您可以联系我们找货
